查看: 7985|回復: 4
HT66f0025項目單片機程序,ADC例程
這是我第一次用合泰單片機寫程序,里面用到定時器和ADC,分享一下。
  1. #include "HT66F002.h"
  2. #define MS1000HSPINIT 250  //高速模式
  3. unsigned char ms_1000;      //定義1/31S
  4. unsigned int  ms1000set;    //定義1S
  5. unsigned char ms_10000;
  6. unsigned int  minute1;
  7. unsigned int  minute360;
  8. unsigned char chargedetect;
  9. unsigned char chargemode;
  10. unsigned char levelstore;
  11. //設備的實際開關機狀態位,0為關機,1為開機
  12. unsigned char SYS_ON_OFF_SATE;
  13. //燈亮度設置函數
  14. void LightSet(unsigned char setvalue)
  15. {
  16.         _stm0al=setvalue; _stm0ah=0;
  17. }
  18. //AD轉換函數
  19. unsigned int AD_CaiJi()  //unsigned char Channel
  20. {
  21.         unsigned int AD_Data;
  22.
  23.         AD_Data=0;
  24.     //開啟轉換
  25.         _start = 0;
  26.         _start = 1;
  27.         _start = 0;
  28.
  29.
  30.         while(_adbz==1);                    //輪詢轉換
  31.         AD_Data = _sadoh;
  32.         AD_Data <<=4;
  33.         AD_Data += (_sadol>>4);
  34.
  35.     return         AD_Data;
  36. }
  37. void main()
  38. {
  39.         //adc參數定義
  40.         unsigned int  adcx;
  41.         unsigned char ADC_Sate;
  42.         unsigned char ADC_Sate1=0;
  43.
  44.         //adc數據存儲變量
  45.         unsigned int  adcx1;
  46.     unsigned int  adcx2;
  47.     unsigned int  adcx3;
  48.         unsigned int  adcx4;
  49.         unsigned int  adcx5;
  50.
  51.         //I/O口初始化設置
  52.            _papu = 0b11011011;    //上拉設置,1為上拉,0為不上拉
  53.         _pac  = 0b11111011;    //IO口方向設置,0為輸出,1為輸入
  54.
  55.         //引腳功能設置
  56.         _pas4=1; //PA2=STP0
  57.     _pas6=1; //_pas6和_pas7用來設置PA5 功能選擇,選擇為ADC的通道AN3
  58.         _pas7=1;
  59.         //STM PWM 輸出設置
  60.         _stm0c1=0b10101000; //fINT=fSYS/4, PWM Mode 256/2M=pres
  61.         LightSet(0);
  62.         _stm0c0=0b00001010;                            //打開定時器
  63.
  64.     //AD初始化設置,參照數據手冊A/D轉換器章節
  65.     _sadc0 = 0b00100011;                                        //使能ADC        AN3
  66.         _sadc1 = 0b00000010;                                        //fsys/4
  67.         _sadc2 = 0b00000000;                                        //除能OPA
  68.
  69.         //系統參初始化
  70.     _hlclk=1;                  //時鐘初始化
  71.     ms1000set=MS1000HSPINIT;
  72.     ms_10000=31;
  73.     minute1=1860;
  74.     minute360=361;
  75.     SYS_ON_OFF_SATE=0;         //關開機起始狀態設置
  76.     levelstore=125;            //亮度初始化
  77.
  78.    while(1)
  79.   {
  80.
  81.         if(_stmp0f)                   //判斷STM中斷標志位是否為1,everay 1ms/次
  82.         {
  83.                 _clrwdt();         //清除看門狗定時器計數器
  84.                 _stmp0f=0;
  85.
  86.                 if(--ms_1000==0)   //every 1/31s/次
  87.                 {
  88.                         ms_1000=ms1000set;
  89.
  90.                         if(--ms_10000==0)   //every 1s/次
  91.                         {
  92.                                 ms_10000=31;
  93.                                 adcx=AD_CaiJi();
  94.                     adcx1=AD_CaiJi();
  95.                         adcx2=AD_CaiJi();
  96.                         adcx3=AD_CaiJi();
  97.                         adcx4=AD_CaiJi();
  98.
  99.                             if((adcx>=2550)&&(adcx1>=2550)&&(adcx2>=2550)&&(adcx3>=2550)&&(adcx4>=2550))      //1.7V   1800
  100.                             {
  101.                                     ADC_Sate=0;
  102.                                     ADC_Sate1=ADC_Sate;
  103.                                     SYS_ON_OFF_SATE=0;         //關機狀態
  104.
  105.                             }
  106.                             else if((adcx<=2150)&&(adcx1<=2150)&&(adcx2<=2150)&&(adcx3<=2150)&&(adcx4<=2150)) //1.4V   1511
  107.                             {
  108.                                     ADC_Sate=1;
  109.                                     ADC_Sate1=ADC_Sate;
  110.                                     SYS_ON_OFF_SATE=1;         //開機狀態
  111.                             }
  112.                             else
  113.                             {
  114.                                 ADC_Sate=ADC_Sate1;
  115.                             }
  116.
  117.                             if(chargemode==0)
  118.                         {
  119.                                 if(ADC_Sate)   //adc值小于1.6V
  120.                                     {
  121.                                                chargedetect=0;
  122.                                             LightSet(levelstore);
  123.                                     }
  124.                                     else if(++chargedetect>5)
  125.                                     {
  126.                                             chargemode=1;//start charge
  127.                                             LightSet(0);
  128.                                     levelstore=125;
  129.                                         minute1=1860;
  130.                                         minute360=361;
  131.                                     }
  132.                             }
  133.                             else
  134.                             {
  135.                                 if(!ADC_Sate)    //adc值大于1.6V
  136.                                 {
  137.                                             chargedetect=0;
  138.                                             LightSet(0);
  139.                                     }
  140.                                     else if(++chargedetect>5)
  141.                                     {
  142.                                         chargemode=0;//stop charge
  143.                                             LightSet(levelstore);
  144.                                             minute1=1860;
  145.                                         minute360=361;
  146.                                     }
  147.                             }
  148.
  149.                         }
  150.
  151.
  152.
  153.
  154.                 if(--minute1==0)           //everay minute/次
  155.                 {
  156.                                 minute1=1860;
  157.
  158.                                 if(--minute360==0) //everay 6h/次
  159.                                 {
  160.                                         minute360=361;
  161.                             levelstore=30;
  162.                                 }
  163.                 }
  164.
  165.             }
  166.
  167.
  168.
  169.
  170.
  171.         }
  172.
  173.
  174.
  175.   }
  176. }
HT66F0025單片機例程.rar (23.63 KB, 下載次數: 102)
ID:78392 發表于 2018-7-21 22:05 | 只看該作者
謝謝分享
ID:78702 發表于 2019-1-2 15:44 | 只看該作者
有電路圖
ID:78702 發表于 2019-1-2 15:45 | 只看該作者
謝謝你的分享
ID:431827 發表于 2021-5-12 10:18 | 只看該作者
謝謝分享,現在免費能下的網站越來越少了。
