查看: 2321|回復: 1
15W4K58S4單片機ADC鍵盤控制數碼管顯示鍵值
ID:367809 發表于 2018-7-9 11:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
15W4K58S4單片機ADC鍵盤控制數碼管顯示鍵值的工程源碼,用keil打開即可
  1. #define         MAIN_Fosc                22118400L        //定義主時鐘
  2. #include        "STC15Fxxxx.H"
  3. #define        Timer0_Reload        (65536UL -(MAIN_Fosc / 2000))                //Timer 0 中斷頻率, 1000次/秒
  4. u8 code t_display[]={                                                //標準字庫
  5. //         0    1    2    3    4    5    6    7    8    9    A    B    C    D    E    F
  6.         0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,
  7. //black         -     H    J         K          L           N        o   P         U     t    G    Q    r   M    y
  8.         0x00,0x40,0x76,0x1E,0x70,0x38,0x37,0x5C,0x73,0x3E,0x78,0x3d,0x67,0x50,0x37,0x6e,
  9.         0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0x46};        //0. 1. 2. 3. 4. 5. 6. 7. 8. 9. -1
  10. u8 code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};                //位碼
  11. sbit        P_HC595_SER   = P4^0;        //pin 14        SER                data input
  12. sbit        P_HC595_RCLK  = P5^4;        //pin 12        RCLk        store (latch) clock
  13. sbit        P_HC595_SRCLK = P4^3;        //pin 11        SRCLK        Shift data clock
  14. u8         LED8[8];                //顯示緩沖
  15. u8        display_index;        //顯示位索引
  16. bit        B_1ms;                        //1ms標志
  17. u8        ADC_KeyState,ADC_KeyState1,ADC_KeyState2,ADC_KeyState3;        //鍵狀態
  18. u8        ADC_KeyHoldCnt;        //鍵按下計時
  19. u8        KeyCode;        //給用戶使用的鍵碼, 1~16有效
  20. u8        cnt10ms;
  21. void        CalculateAdcKey(u16 adc);
  22. u16                Get_ADC10bitResult(u8 channel);        //channel = 0~7
  23. void        DisplayScan();
  24. void main(void)
  25. {
  26.         u16        j;
  27.         u16        i;
  28.         P0M1 = 0;        P0M0 = 0;        //設置為準雙向口
  29.         P1M1 = 0;        P1M0 = 0;        //設置為準雙向口
  30.         P2M1 = 0;        P2M0 = 0;        //設置為準雙向口
  31.         P3M1 = 0;        P3M0 = 0;        //設置為準雙向口
  32.         P4M1 = 0;        P4M0 = 0;        //設置為準雙向口
  33.         P5M1 = 0;        P5M0 = 0;        //設置為準雙向口
  34.         P6M1 = 0;        P6M0 = 0;        //設置為準雙向口
  35.         P7M1 = 0;        P7M0 = 0;        //設置為準雙向口
  36.
  37.         display_index = 0;
  38.         P1ASF = 0x10;                //P1.4做ADC
  39.         ADC_CONTR = 0xE0;        //90T,90個周期轉換一次, ADC power on,ADC電源打開
  40.         AUXR = 0x80;        //Timer0 set as 1T, 16 bits timer auto-reload,
  41.         ET0 = 1;        //Timer0 interrupt enable
  42.         TR0 = 1;        //Tiner0 run
  43.         EA = 1;                //打開總中斷
  44.         ADC_KeyState  = 0;
  45.         ADC_KeyState1 = 0;
  46.         ADC_KeyState2 = 0;
  47.         ADC_KeyState3 = 0;        //鍵狀態
  48.         ADC_KeyHoldCnt = 0;
  49.         KeyCode = 0;        //鍵碼 1~16有效
  50.         cnt10ms = 0;
  51.         for(i=0;i<8;i++)
  52.         {
  53.                 LED8[i] = 0x10;
  54.         }
  55.         while(1)
  56.         {
  57.                 DisplayScan();
  58.                 if(B_1ms)        //1ms到
  59.                 {
  60.                         B_1ms = 0;
  61.                         j=Get_ADC10bitResult(4);
  62.                         CalculateAdcKey(j);
  63.                         if(KeyCode > 0)                //有鍵按下
  64.                         {
  65.                                 LED8[6] = KeyCode / 10;        //顯示鍵碼
  66.                                 LED8[7] = KeyCode % 10;        //顯示鍵碼
  67.                                 KeyCode = 0;
  68.                   }
  69.
  70. }
  71. }
  72. }
  73. u16 Get_ADC10bitResult(u8 channel)        //channel = 0~7
  74. {
  75.         ADC_RES = 0;  //ADC結果高位寄存器
  76.         ADC_RESL = 0;   //ADC結果低位寄存器
  77.         ADC_CONTR = (ADC_CONTR & 0xe0) | 0x08 | channel;         //start the ADC,將P1.4引腳作為內部ADC模塊采樣輸入
  78.         NOP(4);
  79.         while((ADC_CONTR & 0x10) == 0)        ;        //wait for ADC finish,如果adc轉換你未完成,就空操作,轉換完成就執行下一句
  80.         ADC_CONTR &= ~0x10;                //清除ADC結束標志,就是讓adc轉換不結束,一直處于運行狀態
  81.         return        (((u16)ADC_RES << 2) | (ADC_RESL & 3));  //10位ADC結果,取ADC_RES的八位和ADC_RESL的低兩位
  82. }
  83. #define        ADC_OFFSET        16
  84. void        CalculateAdcKey(u16 adc)
  85. {
  86.         u8        i;
  87.         u16        j;
  88.
  89.         if(adc < (64-ADC_OFFSET))  //判斷無鍵按下,然后讓鍵狀態歸0
  90.         {
  91.                 ADC_KeyState = 0;        //鍵狀態歸0
  92.                 ADC_KeyHoldCnt = 0;
  93.         }
  94.         j = 64;   //鍵值1所對應的ADC值
  95.         for(i=1; i<=16; i++)   //讓i值輪詢去判斷鍵值i
  96.         {
  97.                 if((adc >= (j - ADC_OFFSET)) && (adc <= (j + ADC_OFFSET)))        break;        //判斷是否在偏差范圍內
  98.                 j += 64;
  99.         }
  100.         ADC_KeyState3 = ADC_KeyState2;
  101.         ADC_KeyState2 = ADC_KeyState1;
  102.         if(i > 16)        ADC_KeyState1 = 0;        //鍵無效
  103.         else                                                //鍵有效
  104.         {
  105.                 ADC_KeyState1 = i;
  106.                 if((ADC_KeyState3 == ADC_KeyState2) && (ADC_KeyState2 == ADC_KeyState1) &&
  107.                    (ADC_KeyState3 > 0) && (ADC_KeyState2 > 0) && (ADC_KeyState1 > 0))
  108.                 {
  109.                         if(ADC_KeyState == 0)        //第一次檢測到
  110.                         {
  111.                                 KeyCode  = i;        //保存鍵碼
  112.                                 ADC_KeyState = i;        //保存鍵狀態
  113.                                 ADC_KeyHoldCnt = 0;
  114.                         }
  115.                         if(ADC_KeyState == i)        //連續檢測到同一鍵按著
  116.                         {
  117.                                 if(++ADC_KeyHoldCnt >= 100)        //按下1秒后,以10次每秒為周期的速度Repeat Key
  118.                                 {
  119.                                         ADC_KeyHoldCnt = 90;
  120.                                         KeyCode  = i;        //保存鍵碼
  121.                                 }
  122.                         }
  123.                         else        ADC_KeyHoldCnt = 0;        //按下時間計數歸0
  124.                 }
  125.         }
  126. }
  127. /**************** 向HC595發送一個字節函數 ******************/
  128. void Send_595(u8 dat)
  129. {
  130.         u8        i;
  131.         for(i=0; i<8; i++)
  132.         {
  133.                 dat <<= 1;
  134.                 P_HC595_SER   = CY;
  135.                 P_HC595_SRCLK = 1;
  136.                 P_HC595_SRCLK = 0;
  137.         }
  138. }
  139. /********************** 顯示掃描函數 ************************/
  140. void DisplayScan(void)
  141. {
  142.         Send_595(~T_COM[display_index]);                                //輸出位碼
  143.         Send_595(t_display[LED8[display_index]]);        //輸出段碼
  144.         P_HC595_RCLK = 1;
  145.         P_HC595_RCLK = 0;                                                        //鎖存輸出數據
  146.         if(++display_index >= 8)        display_index = 0;        //8位結束回0
  147. }
  148. /********************** Timer0 1ms中斷函數 ************************/
  149. void timer0 (void) interrupt TIMER0_VECTOR
  150. {
  151.         B_1ms = 1;                //1ms標志
  152. }
ad.zip (44.6 KB, 下載次數: 21)
ID:1 發表于 2018-7-9 17:43 | 只看該作者
本帖需要補全原理圖后才可獲得積分.
