//請教!為什么這個程序無法運行?
- #include "stm32f10x.h"
- void GPIO_Config(void)//GPIO配置
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);//使能gpioc的時
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; //選擇管腳PC.13作LED燈
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管腳速度為50M
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //設置輸出模式為推挽輸出
- GPIO_Init(GPIOC, &GPIO_InitStructure); //將上述設置寫入到GPIOC里去
- void NVIC_Config(void) //中斷控制器的配置
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); //優先組設置
- NVIC_InitStructure.NVIC_IRQChannel =TIM2_IRQn ; //TIM2中斷選通
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //搶占優先級
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //子優先級
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能中斷控制
- NVIC_Init(&NVIC_InitStructure);
- void Timer_Config(void) //定時器的配置
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE); //Timer2 時鐘使能
- TIM_DeInit(TIM2); //復位TIM2定時器
- TIM_TimeBaseStructure.TIM_Period=1000; //定時器周期
- TIM_TimeBaseStructure.TIM_Prescaler=36000-1; //預分頻數
- TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1; //TIM2時鐘分頻,為1表示不分頻
- TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//定時器計數為向上計數模式
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
- TIM_ClearFlag(TIM2, TIM_FLAG_Update); //清除定時器2的溢出標志位
- TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE); //使能定時器2溢出中斷
- TIM_Cmd(TIM2, ENABLE); //定時器2使能
- int main(void)
- SystemInit();//初始化時鐘,配置為72MHz,我試過將這句注釋掉,好像不影響結果。查了一下,在配置
- //main函數之前的啟動代碼有這樣一句 LDR R0, =SystemInit,我疑惑的是難道啟動的時候就配成72Mhz?
- GPIO_Config();
- NVIC_Config();
- Timer_Config();
- while(1)
- void TIM2_IRQHandler(void)
- static int flag_bit=0;//定義一個標志位
- if ( TIM_GetITStatus(TIM2 , TIM_IT_Update) != RESET ) //判斷中斷溢出標志為是否為1
- TIM_ClearITPendingBit(TIM2 , TIM_FLAG_Update); //清除溢出中斷標志位
- flag_bit = !flag_bit;
- if(flag_bit == 1)
- GPIO_SetBits(GPIOC, GPIO_Pin_13); //熄滅LED
- if(flag_bit == 0)
- GPIO_ResetBits(GPIOC, GPIO_Pin_13); //點亮LED
