詳情見附件,所用語言為verilog。
源碼- module AM_Sine
- input clk,
- input [15:0]Usine_1k,
- input [15:0]Sine_Range,
- input [15:0] M, //調(diào)制度0.1~1,設(shè)為0~65536,最后除以65536 用位移來操作2^16次方
- output [15:0]AM_OUT,
- output [15:0]AM_Tiaozhi,
- output [15:0]Reg_Zai
- wire [15:0]Sine_sign=Sine_Range+16'h8000;//有符號數(shù)
- wire [15:0]Zaibo;
- reg [2:0]zero=0;
- //assign Zaibo[15:0]=zero[0]+Sine_Range[14:0];
- assign Zaibo=Sine_Range>>1;
- reg [15:0]Reg_Zaibo=0;
- always @(clk)
- begin
- if(Sine_Range[15])begin
- Reg_Zaibo=Zaibo;
- end
- else begin
- Reg_Zaibo=32768-Zaibo; //最高位為0時是正數(shù)
- end
- end
- assign Reg_Zai=Reg_Zaibo;
- wire [15:0]Sine_1k;
- assign Sine_1k=Usine_1k>>1;
- wire [31:0]Ma_Tiaozhi;
- wire [15:0]TiaoZhi;
- wire [15:0]M_1=65535-M;
- wire [15:0]constant=32768;
- wire [31:0]result1;
- wire [31:0]result2;
- wire [31:0]RMa_Tiaozhi;
- assign Ma_Tiaozhi=result1+result2;
- assign RMa_Tiaozhi=Ma_Tiaozhi>>16;
- //assign TiaoZhi[15:0]=RMa_Tiaozhi[15:0];
- assign TiaoZhi[15:0]=Ma_Tiaozhi[31:16];//加一個偏移
- assign AM_Tiaozhi=TiaoZhi;
- wire [31:0]AM_OUT32;
- wire [31:0]AM_OUT16;
- assign AM_OUT16=AM_OUT32>>16;
- wire [15:0]UAM_OUT;
- assign {UAM_OUT[15:0]}=Sine_Range[15]+AM_OUT16[14:0];
- //assign {UAM_OUT[15:0]}=AM_OUT32[31:16];
- //assign AM_OUT=UAM_OUT+16'h8000;
- //assign AM_OUT=UAM_OUT;
- //always @(clk)begin
- //RMa_Tiaozhi=Ma_Tiaozhi>>16;
- //end
- Mult16_16_clk Mult1 (
- .clock ( clk),
- .dataa ( Usine_1k), //Usine_1k--->Sine_1k
- .datab ( M),
- .result ( result1 )
- Mult16_16_clk Mult2 (
- .clock ( clk ),
- .dataa ( constant),
- .datab ( M_1 ),
- .result ( result12)
- Mult16_16_clk Mult3 (
- .clock ( clk ),
- .dataa ( Reg_Zaibo), //Zaibo->Reg_Zaibo
- .datab ( TiaoZhi),//Tiaozhi->Usine_1k
- .result ( AM_OUT32)
- Mult_Sign Mult4 (
- .clock ( clk ),
- .dataa ( test ),
- .datab ( Sine_sign ),
- .result ( result_sig )
- wire [16:0]Tiaozhi_17=RMa_Tiaozhi[16:0];
- //assign Tiaozhi_17=RMa_Tiaozhi[;
- wire [32:0]result_sig;
- wire [32:0]result_sign;
- assign result_sign=result_sig-33'h100000000;
- assign {AM_OUT[15:0]}=result_sign[32:17];
- wire [31:0]tiao=((Usine_1k*M)+(16'h8000*M_1))>>16;
- wire [16:0]test=tiao[16:0];
- endmodule
AM_Sine.rar
2018-7-6 15:19 上傳
下載積分: 黑幣 -5
927 Bytes, 下載次數(shù): 22, 下載積分: 黑幣 -5
產(chǎn)生調(diào)幅信號
