查看: 2809|回復: 2
基于1602液晶屏顯示的PWM測試
ID:366105 發表于 2018-7-6 10:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//設計實現PWM功能,通過按鍵實現占空比10-90%可調,1602液晶屏顯示占空比數據。
#include<reg52.h>
#define  uint unsigned int
sbit  a=P1^0;
sbit  key0=P3^6;
sbit  key1=P3^7;
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
uchar code  table1[]="duty=50%";
uchar duty,num,b;
uchar  number;
void delayms(uint xms)
        uint  i,j;
        for(i=xms;i>0;i--)
         for(j=110;j>0;j--);
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void write_data(uchar date)
        lcdrs=1;
        P0=date;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void LCD1602init()
        dula=0;
        wela=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<8;num++)
                write_data(table1[num]);
                delayms(5);
void write_sfm(uchar add,uchar date)
   uchar shi,ge;
   shi=date/10;
   ge=date%10;
   write_com(0x80+add);
   write_data(0x30+shi);
   write_data(0x30+ge);
void keyscan()
   if(key0==0)
       delayms(10);
           if(key0==0)
                  number--;
                  if(number==9)
                    number=90;
                while(!key0);
   if(key1==0)
       delayms(10);
           if(key1==0)
                  number++;
                  if(number==91)
                    number=10;
                while(!key1);
        LCD1602init();
        TMOD=0x01;
        TH0=(65336)/256;
        TL0=(65336)%256;
        EA=1;
        ET0=1;
        TR0=1;
        number=50;
                keyscan();
                write_sfm(5,number);
void T0_time() interrupt 1
        TH0=65336/256;
        TL0=65336%256;
        a=0;
        num++;
        if(num==100-duty)
           a=1;
        if(num==100)
                num=0;
                a=0;
ID:366460 發表于 2018-7-8 19:43 來自觸屏版 | 只看該作者
有相應的仿真不?
ID:713781 發表于 2020-4-7 12:56 | 只看該作者
想要仿真電路
