查看: 3212|回復(fù): 0
基于MIMO-OFDM時(shí)間同步用LS算法實(shí)現(xiàn)matlab源碼
基于MIMO-OFDM時(shí)間同步用LS算法實(shí)現(xiàn)Timing-synchronization
matlab源程序如下:
  1. %...................................................................
  2. clear all;
  3. clc;
  4.   nloop=100;
  5.   SNR_loop = [-10:5:25];
  6. for i = 1:1:length(SNR_loop)
  7.     SNR1 = SNR_loop(i);
  8.     [n01(i)]=conventional22(SNR1)
  9.     pe(i)=(nloop-n01(i))/nloop;
  10. end
  11. pe
  12. grid on;
  13. semilogy(SNR_loop ,pe,'*-- g','Linewidth', 2)
  14. axis([-15 20 0.1 1 ])
  15. hold on;
  16. %................................................................
  17. clear all;
  18. clc;
  19.   nloop=100;
  20.   SNR_loop = [-10:5:25];
  21. for i = 1:1:length(SNR_loop)
  22.     SNR1 = SNR_loop(i);
  23.     [n01(i)]=conventional33(SNR1)
  24.     pe(i)=(nloop-n01(i))/nloop;
  25. end
  26. pe
  27. grid on;
  28. semilogy(SNR_loop ,pe,'o-- g','Linewidth', 2)
  29. axis([-10 25 0.1 1 ])
  30. hold on;
  31. %................................................................
  32. clear all;
  33. clc;
  34.   nloop=100;
  35.   SNR_loop = [-10:5:25];
  36. for i = 1:1:length(SNR_loop)
  37.     SNR1 = SNR_loop(i);
  38.     [n01(i)]=proposed22(SNR1)
  39.     pe(i)=(nloop-n01(i))/nloop;
  40. end
  41. pe
  42. grid on;
  43. semilogy(SNR_loop ,pe,'*- r','Linewidth', 2)
  44. axis([-10 25 0.1 1 ])
  45. hold on;
  46. %.........................................................................
  47. clear all;
  48. clc;
  49.   nloop=100;
  50.   SNR_loop = [-10:5:25];
  51. for i = 1:1:length(SNR_loop)
  52.     SNR1 = SNR_loop(i);
  53.     [n01(i)]=proposed33(SNR1)
  54.     pe(i)=(nloop-n01(i))/nloop;
  55. end
  56. pe
  57. grid on;
  58. semilogy(SNR_loop ,pe,'o- r','Linewidth', 2)
  59. axis([-10 25 0.1 1 ])
  60. hold on;
  61. %................................................................
  62. legend('2*2 conventional time est','3*3 conventional time est','2*2 proposed time est','3*3 proposed time est')
  63. xlabel('SNR dB')
  64. ylabel('right probability of timing estimation')
基于MIMO-OFDM時(shí)間同步用LS算法實(shí)現(xiàn)Timing-synchronization.rar (59.47 KB, 下載次數(shù): 13)
