電子秤程序 仿真
2018-7-3 02:15 上傳
2018-7-3 02:15 上傳
單片機(jī)源程序如下:
- 壓力測試儀
- 系統(tǒng)描述;輸入 15--115kPA壓力信號
- 輸出 00h--ffh數(shù)字信號(adc0832)
- 在LCD上顯示實(shí)際的壓力值,如果超限則報(bào)警
- 線性區(qū)間標(biāo)度變換公式: y=(115-15)/(243-13)*X+15kpa
- 作者:
- 日期:2018.6.27
- #include <reg51.h>
- #include <intrins.h>
- #include <absacc.h>
- #include <math.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define BUSY 0x80 //常量定義
- #define DATAPORT P1
- //ADC0832的引腳
- sbit ADCS =P3^5; //ADC0832 chip seclect
- sbit ADDI =P3^7; //ADC0832 k in
- sbit ADDO =P3^7; //ADC0832 k out
- sbit ADCLK =P3^6; //ADC0832 clock signal
- sbit LCM_RS=P2^5;
- sbit LCM_RW=P2^4;
- sbit LCM_EN=P2^3;
- uchar ad_data; //采樣值存儲
- sbit Alarm_led_red =P3^1; //超過壓力表量程最大值紅色led報(bào)警定義
- sbit Alarm_led_green=P3^2; //低于壓力表量程最小值綠色led報(bào)警定義
- //adc采樣值存儲單元
- char press_data; //標(biāo)度變換存儲單元
- unsigned char ad_alarm; //報(bào)警值存儲單元
- unsigned char press_ge=0; //顯示值百位
- unsigned char press_shifen=0; //顯示值十位
- unsigned char press_baifen=0; //顯示值個位
- unsigned char press_qianfen=0; //顯示值十分位
- uchar code str0[]={"Weight: . Kg "};
- uchar code str1[]={"DianZiCheng WH "};
- void delay(uint);
- void lcd_wait(void);
- void delay_LCM(uint); //LCD延時子程序
- void initLCM( void); //LCD初始化子程序
- void lcd_wait(void); //LCD檢測忙子程序
- void WriteCommandLCM(uchar WCLCM,uchar BusyC); //寫指令到ICM子函數(shù)
- void WriteDataLCM(uchar WDLCM); //寫數(shù)據(jù)到LCM子函數(shù)
- void DisplayOneChar(uchar X,uchar Y,uchar DData); //顯示指定坐標(biāo)的一個字符子函數(shù)
- void DisplayListChar(uchar X,uchar Y,uchar code *DData); //顯示指定坐標(biāo)的一串字符子函數(shù)
- void keyscan();
- void display(void); //系統(tǒng)顯示子函數(shù)
- uchar Adc0832(unsigned char channel);
- void alarm(void);
- void data_pro(void);
- /**********main funcation************/
- void main(void)
- delay(500); //系統(tǒng)延時500ms啟動
- // ad_data=0; //采樣值存儲單元初始化為0
- initLCM( );
- WriteCommandLCM(0x01,1); //清顯示屏
- DisplayListChar(0,0,str0);
- DisplayListChar(0,1,str1);
- while(1)
- ad_data =Adc0832(0); //采樣值存儲單元初始化為0
- alarm();
- data_pro();
- display();
- /*********延時K*1ms,12.000mhz**********/
- void delay(uint k)
- uint i,j;
- for(i=0;i<k;i++)
- for(j=0;j<60;j++)
- /**********寫指令到ICM子函數(shù)************/
- if(BusyC)lcd_wait();
- DATAPORT=WCLCM;
- LCM_RS=0; // 選中指令寄存器
- LCM_RW=0; // 寫模式
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********寫數(shù)據(jù)到LCM子函數(shù)************/
- lcd_wait( ); //檢測忙信號
- DATAPORT=WDLCM;
- LCM_RS=1; // 選中數(shù)據(jù)寄存器
- LCM_RW=0; // 寫模式
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /***********lcm內(nèi)部等待函數(shù)*************/
- DATAPORT=0xff; //讀LCD前若單片機(jī)輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會有顯示邏輯黃色
- LCM_EN=1;
- LCM_RS=0;
- LCM_RW=1;
- _nop_();
- _nop_();
- _nop_();
- while(DATAPORT&BUSY)
- { LCM_EN=0;
- _nop_();
- _nop_();
- LCM_EN=1;
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********LCM初始化子函數(shù)***********/
- void initLCM( )
- DATAPORT=0;
- delay(15);
- WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號
- delay(5);
- delay(5);
- delay(5);
- WriteCommandLCM(0x38,1); //8bit數(shù)據(jù)傳送,2行顯示,5*7字型,檢測忙信號
- WriteCommandLCM(0x08,1); //關(guān)閉顯示,檢測忙信號
- WriteCommandLCM(0x01,1); //清屏,檢測忙信號
- WriteCommandLCM(0x06,1); //顯示光標(biāo)右移設(shè)置,檢測忙信號
- WriteCommandLCM(0x0c,1); //顯示屏打開,光標(biāo)不顯示,不閃爍,檢測忙信號
- /****顯示指定坐標(biāo)的一個字符子函數(shù)****/
- Y&=0x01;
- X&=0x0f;
- if(Y)X|=0x40; //若y為1(顯示第二行),地址碼+0X40
- X|=0x80; //指令碼為地址碼+0X80
- WriteCommandLCM(X,1);
- WriteDataLCM(DData);
- /*******顯示指定坐標(biāo)的一串字符子函數(shù)*****/
- uchar ListLength=0;
- Y&=0x01;
- X&=0x0f;
- while(X<16)
- DisplayOneChar(X,Y,DData[ListLength]);
- ListLength++;
- X++;
- /*****************系統(tǒng)顯示子函數(shù)*****************/
- DisplayOneChar(8,0,press_ge+0x30);
- DisplayOneChar(10,0,press_shifen+0x30);
- DisplayOneChar(11,0,press_baifen+0x30);
- DisplayOneChar(12,0,press_qianfen+0x30);
- delay(1000); //穩(wěn)定顯示
- 讀ADC0832函數(shù)
- //采集并返回
- uchar Adc0832(unsigned char channel) //AD轉(zhuǎn)換,返回結(jié)果
- uchar i=0;
- uchar j;
- uint dat=0;
- uchar ndat=0;
- if(channel==0)channel=2;
- if(channel==1)channel=3;
- ADDI=1;
- _nop_();
- _nop_();
- ADCS=0;//拉低CS端
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿1
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- ADDI=channel&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿2
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- ADDI=(channel>>1)&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿3
- ADDI=1;//控制命令結(jié)束
- _nop_();
- _nop_();
- dat=0;
- for(i=0;i<8;i++)
- dat|=ADDO;//收數(shù)據(jù)
- ADCLK=1;
- _nop_();
- _nop_();
- ADCLK=0;//形成一次時鐘脈沖
- _nop_();
- _nop_();
- dat<<=1;
- if(i==7)dat|=ADDO;
- for(i=0;i<8;i++)
- j=0;
- j=j|ADDO;//收數(shù)據(jù)
- ADCLK=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- j=j<<7;
- ndat=ndat|j;
- if(i<7)ndat>>=1;
- ADCS=1;//拉低CS端
- ADCLK=0;//拉低CLK端
- ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
- dat<<=8;
- dat|=ndat;
- return(dat); //return ad k
- unsigned int temp;
- float press;
- if(14<ad_data<243) //當(dāng)壓力值介于15kpa到115kpa之間時,遵循線性變換
- int vary=ad_data; //y=(115-15)/(243-13)*X+15kpa
- press=((10.0/23.0)*vary)+9.3; //測試時補(bǔ)償值為9.3
- temp=(int)(press*10); //放大10倍,便于后面的計(jì)算
- press_ge=temp/1000; //取壓力值百位
- press_shifen=(temp%1000)/100; //取壓力值十位
- press_baifen=((temp%1000)%100)/10; //取壓力值個位
- press_qianfen=((temp%1000)%100)%10; //取壓力值十分位
- /*****************報(bào)警子函數(shù)*******************/
- void alarm(void)
- if(ad_data>=243) //如果當(dāng)前壓力值大于115kpa,
- { Alarm_led_red=0; } //則啟動red led報(bào)警
- else
- { Alarm_led_red=1; } //關(guān)閉red led 報(bào)警
- if(ad_data<=14) //如果當(dāng)前壓力值小于16kpa
- { Alarm_led_green=0; } //則啟動green led報(bào)警
- else
- { Alarm_led_green=1; } //關(guān)閉green led 報(bào)警
電子秤.zip
(120.63 KB, 下載次數(shù): 61)
2018-7-2 16:20 上傳
點(diǎn)擊文件名下載附件
keil 下載積分: 黑幣 -5
