PC中控系統(tǒng)程序加電路仿真
單片機(jī)源程序如下:
- #include <AT89X52.h>
- #define ON 0
- #define OFF 1
- sbit Relay = P2^7; //繼電器控制引腳
- //初始化串口
- void InitUART(void)
- TMOD = 0x20; //9600bps
- SCON = 0x50;
- TH1 = 0xFD;
- TL1 = TH1;
- PCON = 0x00;
- EA = 1;
- ES = 1;
- TR1 = 1;
- //發(fā)送一個(gè)字節(jié)的數(shù)據(jù)
- void Send(unsigned char x)
- SBUF = x;
- while(TI==0);
- TI = 0;
- void Serial(void) interrupt 4 using 0
- unsigned char temp;
- if(RI == 1) //接收數(shù)據(jù)
- RI = 0;
- temp = SBUF;
- if(temp == 0x01) //如果是打開(kāi)繼電器
- Relay = ON; //打開(kāi)繼電器
- Send(0x01); //反饋繼電器狀態(tài)信息
- else if(temp == 0x02) //如果是關(guān)閉繼電器
- Relay = OFF;
- Send(0x02); //反饋繼電器狀態(tài)
- else
- Send(0x03);//無(wú)動(dòng)作
- main()
- InitUART();
- Relay = OFF; //繼電器斷開(kāi)
- while(1)
PC中控系統(tǒng).zip
(50.53 KB, 下載次數(shù): 12)
2018-7-1 17:14 上傳
點(diǎn)擊文件名下載附件
