只需一步,快速開(kāi)始
查看: 1676|回復(fù): 1
藍(lán)牙遙控小車 前進(jìn),后退,避障,左右沒(méi)問(wèn)題但是按加速和減速時(shí)小車不動(dòng)了怎么回事
ID:360580 發(fā)表于 2018-6-27 21:05 | 顯示全部樓層 |閱讀模式
藍(lán)牙APP圖
藍(lán)牙APP圖
藍(lán)牙APP圖
  1.
  2.     #include<AT89x51.H>
  3.     #define Left_moto_go      {P2_7=1,P2_6=0;}  //?????????
  4.         #define Left_moto_back    {P2_7=0,P2_6=1;}         //?????????
  5.         #define Left_moto_Stop    {P2_7=0,P2_6=0;}         //???????
  6.         #define Right_moto_go     {P2_4=1,P2_5=0;}        //??????????
  7.         #define Right_moto_back   {P2_4=0,P2_5=1;}        //??????????
  8.         #define Right_moto_Stop   {P2_4=0,P2_5=0;}              //???????
  9.         #define left     'C'
  10.     #define right    'D'
  11.         #define up       'A'
  12.     #define down     'B'
  13.         #define stop     'F'
  14.         #define        jia      '1'
  15.         #define        jian     '2'
  16.         #define uint    unsigned int                          //??????????????????
  17.     #define uchar   unsigned char                         //?????????????????
  18.         char code str[] =  "?????????!\n";
  19.         char code str1[] = "?????????!\n";
  20.         char code str2[] = "??????????!\n";
  21.         char code str3[] = "??????????!\n";
  22.         char code str4[] = "????????!\n";
  23.         char code str5[] = "??????????!\n";
  24.         char code str6[] = "??????????!\n";
  25.         bit  flag_REC=0;
  26.         bit  flag    =0;
  27.         bit  flag_bz =0;
  28.         unsigned char  i=0;
  29.         unsigned char  dat=0;
  30.     unsigned char  buff[5]=0; //??????????
  31.         #define Left_1_led        P1_0         //??????
  32.
  33.     #define Right_1_led       P1_1         //???????
  34.
  35. /************************************************************************/
  36. //???????
  37.    void delay(unsigned int k)
  38. {
  39.      unsigned int x,y;
  40.          for(x=0;x<k;x++)
  41.            for(y=0;y<2000;y++);
  42. }
  43. /************************************************************************/
  44. //????????????
  45.           void send_str( )
  46.                    // ???????
  47.     {
  48.             unsigned char i = 0;
  49.             while(str[i] != '\0')
  50.            {
  51.                 SBUF = str[i];
  52.                 while(!TI);                                // ???????????
  53.                 TI = 0;                                        // ????????????
  54.                 i++;                                        // ????????
  55.            }
  56.     }
  57.
  58.                   void send_str1( )
  59.                    // ???????
  60.     {
  61.             unsigned char i = 0;
  62.             while(str1[i] != '\0')
  63.            {
  64.                 SBUF = str1[i];
  65.                 while(!TI);                                // ???????????
  66.                 TI = 0;                                        // ????????????
  67.                 i++;                                        // ????????
  68.            }
  69.     }
  70.                           void send_str2( )
  71.                    // ???????
  72.     {
  73.             unsigned char i = 0;
  74.             while(str2[i] != '\0')
  75.            {
  76.                 SBUF = str2[i];
  77.                 while(!TI);                                // ???????????
  78.                 TI = 0;                                        // ????????????
  79.                 i++;                                        // ????????
  80.            }
  81.     }
  82.
  83.                           void send_str3()
  84.                    // ???????
  85.     {
  86.             unsigned char i = 0;
  87.             while(str3[i] != '\0')
  88.            {
  89.                 SBUF = str3[i];
  90.                 while(!TI);                                // ???????????
  91.                 TI = 0;                                        // ????????????
  92.                 i++;                                        // ????????
  93.            }
  94.     }
  95.          void send_str4()
  96.                    // ???????
  97.     {
  98.             unsigned char i = 0;
  99.             while(str4[i] != '\0')
  100.            {
  101.                 SBUF = str4[i];
  102.                 while(!TI);                                // ???????????
  103.                 TI = 0;                                        // ????????????
  104.                 i++;                                        // ????????
  105.            }
  106.     }
  107.           void send_str5()
  108.                    // ???????
  109.     {
  110.             unsigned char i = 0;
  111.             while(str5[i] != '\0')
  112.            {
  113.                 SBUF = str5[i];
  114.                 while(!TI);                                // ???????????
  115.                 TI = 0;                                        // ????????????
  116.                 i++;                                        // ????????
  117.            }
  118.     }
  119.          void send_str6()
  120.                    // ???????
  121.     {
  122.             unsigned char i = 0;
  123.             while(str6[i] != '\0')
  124.            {
  125.                 SBUF = str6[i];
  126.                 while(!TI);                                // ???????????
  127.                 TI = 0;                                        // ????????????
  128.                 i++;                                        // ????????
  129.            }
  130.     }
  131.
  132. //PWM????????????
  133. void timer(unsigned int t)   //?ж???
  134. {
  135. unsigned int i;
  136. for(i=0;i<t;i++) /*????t*50*/
  137. {
  138.   TMOD=0X10;
  139.   TH0=0x3C;
  140.   TL0=0xB0;
  141.   TR1=1;
  142.   while(!TF1);
  143.   TR1=0;
  144. }}
  145.
  146.
  147. /************************************************************************/
  148. //??????
  149.      void  run(void)
  150. {
  151.
  152.          Left_moto_go ;   //?????????
  153.          Right_moto_go ;  //?????????
  154.
  155. }
  156. void jiasu()
  157. {
  158.          P2_7=1;P2_6=0,P2_4=1;P2_5=0;
  159.          timer(50);//???2.2ms
  160.          P2_7=0;P2_4=0;
  161.          timer(450);//8.8ms
  162. }
  163. void jiansu()
  164. {
  165.      P2_7=1;P2_6=0,P2_4=1;P2_5=0;
  166.          timer(450);//???2.2ms
  167.          P2_7=0;P2_4=0;
  168.          timer(50);//8.8ms
  169. }
  170. //??????
  171.      void  backrun(void)
  172. {
  173.
  174.          Left_moto_back ;   //??????????
  175.          Right_moto_back ;  //??????????
  176. }
  177. //???
  178.      void  rightrun(void)
  179. {
  180.
  181.           Left_moto_go ;   //?????????
  182.          Right_moto_back ;  //??????
  183. }
  184. //???
  185.      void   leftrun(void)
  186. {
  187.
  188.
  189.          Left_moto_back ;   //??????
  190.          Right_moto_go;  //?????????
  191. }
  192. //STOP
  193.      void  stoprun(void)
  194. {
  195.
  196.          Left_moto_Stop ;   //??????
  197.          Right_moto_Stop ;  //??????
  198. }
  199. /************************************************************************/
  200. void sint() interrupt 4          //?ж????3?????
  201. {
  202.     if(RI)                         //???????ж?
  203.     {
  204.        RI=0;
  205.        dat=SBUF;
  206.        if(dat=='O'&&(i==0)) //???????????
  207.          {
  208.             buff[i]=dat;
  209.             flag=1;        //???????????
  210.          }
  211.        else
  212.       if(flag==1)
  213.      {
  214.       i++;
  215.       buff[i]=dat;
  216.       if(i>=2)
  217.       {i=0;flag=0;flag_REC=1 ;}  // ??????
  218.      }
  219.          }
  220. }
  221. /*********************************************************************/
  222. /*--??????--*/
  223.         void main(void)
  224. {
  225.         TMOD=0x20;
  226.     TH1=0xFd;                     //11.0592M????9600??????
  227.     TL1=0xFd;
  228.     SCON=0x50;
  229.     PCON=0x00;
  230.     TR1=1;
  231.         ES=1;
  232.     EA=1;
  233.
  234.         while(1)                                                        /*???????*/
  235.         {
  236.            if(flag_bz == 1)//?л?????????
  237.       {
  238.          if(Left_1_led==1&&Right_1_led==1)
  239.                          run();         //???????????
  240.                           else
  241.                          {
  242.                                       if(Left_1_led==1&&Right_1_led==0)            //????????????
  243.                                   {
  244.                                             leftrun();          //????С?????????
  245.                                            delay(40);
  246.                              }
  247.
  248.                                            if(Right_1_led==1&&Left_1_led==0)                //????????????
  249.                                   {
  250.
  251.
  252.                                            rightrun();         //????С?????????
  253.                                           delay(40);
  254.                                   }
  255.        if(Right_1_led==0&&Left_1_led==0)                //??????????????????
  256.                                   {
  257.                                     backrun();                //?????????????
  258.                                         delay(40);                //????050????
  259.                                         rightrun();                //?????????????
  260.                                         delay(90);
  261.                                   }
  262.                         }
  263.         }
  264.
  265.           if(flag_REC==1)                                    //
  266.            {
  267.                 flag_REC=0;
  268.                 if(buff[0]=='O'&&buff[1]=='N')        //?????????O???????????N??????????????????
  269.                 switch(buff[2])
  270.              {
  271.                       case up :                                                    // ???
  272.                           send_str( );
  273.                           //run();
  274.                           jiasu();
  275.                           flag_bz = 1;
  276.
  277.                           break;
  278.                       case down:                                                // ????
  279.                            send_str1( );
  280.                            flag_bz = 0;
  281.                           //backrun();
  282.                           jiansu();
  283.
  284.                           break;
  285.                       case left:                                                // ???
  286.                            send_str2( );
  287.                           leftrun();
  288.                           flag_bz = 0;
  289.
  290.                           break;
  291.                       case right:                                                // ???
  292.                           send_str3( );
  293.                           rightrun();
  294.                           flag_bz = 0;
  295.
  296.                           break;
  297.                       case stop:                                                // ??
  298.                            send_str4( );
  299.                           stoprun();
  300.                           flag_bz = 0;
  301.
  302.                           break;
  303.               case         jia:
  304.                                   send_str5( );
  305.                                   jiasu();
  306.                                   flag_bz = 0;
  307.                           break;
  308.                           case jian:
  309.                                     send_str6( );
  310.                                    jiansu();
  311.                                    flag_bz = 0;
  312.                           break;
  313.              }
  314.
  315.
  316.          }
  317.         }
  318. }
代碼在上面 ,
有沒(méi)有大神告訴小白哪里有問(wèn)題 ,感謝感謝!!!!
ID:360580 發(fā)表于 2018-6-27 21:06 | 顯示全部樓層
漢字傳上去變?號(hào)了欸
藍(lán)牙 APP1 ,2 是加速和減速
