查看: 2502|回復(fù): 0
鍵盤設(shè)計行列掃描
ID:360512 發(fā)表于 2018-6-27 19:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//********"鍵盤及其顯示"**************
//"當按下一個鍵的時候顯示按下鍵的鍵值,其余時間顯示字母“P”"
// "P1口作為數(shù)碼管的位選,P0口作為數(shù)碼管的段選"
//"P2口是鍵盤連接口,低4位為列,高4位為行"
#include"reg52.h"
//"下面為數(shù)碼管顯示碼"
unsigned char code table[19]={0x3f,0x06,0x5b,0x4f,0x66,//0~4
                              0x6d,0x7d,0x07,0x7f,0x6f,//5~9
         0x77,0x7c,0x39,0x5e,0x79,//A~E
         0x71,0x73,0xc3,0x00};//F.p.=..
unsigned char key_scan(void);
//*************"鍵盤顯示"********************
//"函數(shù)名稱:void key_display(void)"
//"函數(shù)功能:顯示所按下鍵的鍵值"
//"參數(shù)說明:無  P0口作為段碼,  P1作為位碼"
unsigned char key_value_1=16;
P1=0x00;//"選通所有的數(shù)碼管"
key_value_1=key_scan();//"返回鍵值"
P0=table[key_value_1];//"輸出顯示碼"
//***********"延時"*********************
//"函數(shù)名稱:void delay(unsigned char delay_time)"
//"函數(shù)功能:延時"
//"參數(shù)說明:有 delay_time"
void delay(unsigned int delay_time)
  while(delay_time){delay_time--;}
       //"延時8+6*delay_time  us"
//***********"按鍵掃描"*******************
//"函數(shù)名稱:unsigned char key_scan(void)"
//"函數(shù)功能:用行列掃描方式進行鍵盤掃描,P2口高四位作為行,低四位作為列"
//"參數(shù)說明:無"
  unsigned char key_code;//"鍵盤行編碼"
  unsigned char key_value;//"鍵值"
  unsigned char row=0;//"行值"
  unsigned char line=0;//"列值"
  unsigned char temp=0xfe;//"列掃描碼"
  unsigned char i;
  P2=0xf0;//"P2口賦初值,準備進行行,列掃描"
  if((P2&0xf0)!=0xf0)//"表示有鍵按下"
       delay(2000);//"延時10ms消抖"
               if((P2&0xf0)!=0xf0)//"表明確實有鍵按下,進行鍵盤掃描"
          for(i=0;i<4;i++)//"列掃描"
      P2=temp;//"送列掃描碼"
      if((P2&0xf0)!=0xf0)
        key_code=P2&0xf0;//"得出行編碼"
     row=i;//"計算出列值"
     break;
    temp=(temp<<1)|0x01;//"進行下一列掃描"
    switch(key_code)//"根據(jù)行編碼得出行值"
      case 0xe0: line=0;break;
      case 0xd0: line=1;break;
      case 0xb0: line=2;break;
      case 0x70: line=3;break;
      default:  ;
   key_value=row*4+line;//"根據(jù)行,列值計算出鍵值"
  return(key_value);
        while((P2&0xf0)!=0xf0){key_display();}//"等待按鍵釋放"
//**************"主函數(shù)"***********************
//"函數(shù)名稱:void main(void)"
//"函數(shù)功能:"
//"參數(shù)說明:無"
void main(void)
   key_display();
