STM32F030-UART1_DMA使用提示前言: 今天把STM32F030C8T6的串口DMA學習了一下,為了加快各位研發人員的開發進度,避免浪費大量的時間在硬件平臺上,寫出個人代碼調試的經驗。個人水平有限,如有錯誤,還請指正mr.li.ming@qq.com。 提示:使用的內部RC時鐘,最大速度48MHz;使用USART1-PA9/PA10. 第一步:初始化端口/******************************************************************************* *@brief 串口1端口初始化 *@param None * @retvalNone ****************************************************************Author:Liming**/ void USART1_GPIO_Init(void) { GPIO_InitTypeDef GPIO_Initstructure; RCC_AHBPeriphClockCmd(USART1_GPIO_CLK,ENABLE); /*Connect pin to Periph */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_1); // 注意這里是GPIO_PinSource9 GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_1); GPIO_Initstructure.GPIO_Pin=USART1_TX_PIN; GPIO_Initstructure.GPIO_Mode=GPIO_Mode_AF; GPIO_Initstructure.GPIO_OType=GPIO_OType_PP; // 推挽輸出 GPIO_Initstructure.GPIO_PuPd=GPIO_PuPd_UP; GPIO_Initstructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_Init(USART1_GPIO_PORT,&GPIO_Initstructure); GPIO_Initstructure.GPIO_Pin = USART1_RX_PIN; // 浮空輸入 GPIO_Init(USART1_GPIO_PORT,&GPIO_Initstructure); } 第二步:初始化UART1/******************************************************************************* * @brief 串口1初始化 * @param None * @retval None ****************************************************************Author:Liming**/ void USART1_Init(uint32_t BaudRate) { USART_InitTypeDef USART_Initstructure; RCC_APB2PeriphClockCmd(USART1_CLK,ENABLE); USART1_GPIO_Init(); // 調用了上面的端口初始化,故主函數里調用此函數即可。 USART_Initstructure.USART_BaudRate = BaudRate; USART_Initstructure.USART_Parity =USART_Parity_No; USART_Initstructure.USART_WordLength =USART_WordLength_8b; USART_Initstructure.USART_StopBits =USART_StopBits_1; USART_Initstructure.USART_Mode = USART_Mode_Rx|USART_Mode_Tx; USART_Initstructure.USART_HardwareFlowControl =USART_HardwareFlowControl_None; USART_Init(USART1,&USART_Initstructure); USART_ClearFlag(USART1,USART_FLAG_TC); USART_DMACmd(USART1,USART_DMAReq_Tx,ENABLE); USART_Cmd(USART1,ENABLE); // 使能串口 }
第三步:DMA1中斷配置/******************************************************************************* * @brief DMA1中斷配置 * @param None * @retval None ****************************************************************Author:Liming**/ void DMA1_NVIC_Init(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel2_3_IRQn; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_InitStructure.NVIC_IRQChannelPriority = 2; NVIC_Init(&NVIC_InitStructure); } 注意事項:1. USART1發送數據使用的是DMA1的第二通道。查表可知,為什么還有第四通道呢,那是給USART1端口重映射了之后使用的。
第四步:DMA1配置/******************************************************************************* *@brief DMA1配置 *@param None *@retval None ****************************************************************Author:Liming**/ void DMA1_Init(void) { DMA_InitTypeDef DMA_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE); DMA_InitStructure.DMA_BufferSize = 12; // 緩存大小 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; // 內存到內存關閉 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; // 普通模式 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; // 內存到外設 DMA_InitStructure.DMA_Priority = DMA_Priority_High; // DMA通道優先級 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;// 內存地址遞增 DMA_InitStructure.DMA_PeripheralBaseAddr =(uint32_t)&USART1->TDR; // 外設地址 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;// 外設地址不變 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; // 內存數據長度 DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)UART1_TXBUFFER; // 定義內存基地址 DMA_InitStructure.DMA_PeripheralDataSize =DMA_PeripheralDataSize_Byte;//外設數據長度 DMA_Init(DMA1_Channel2,&DMA_InitStructure); DMA_ClearITPendingBit(DMA1_IT_TC2); // 清除一次DMA中斷標志 DMA_ITConfig(DMA1_Channel2,DMA_IT_TC,ENABLE);// 使能DMA傳輸完成中斷 DMA1_NVIC_Init(); // 調用了上面的中斷配置,故主函數里調用此函數即可 DMA_Cmd(DMA1_Channel2,ENABLE); } 注意事項:1. 緩存大小:就是你一次要發送多長的數據。2. DMA方向:因為是串口發送數據,所以是從內存到外設,USART1對于單片機來講是個外設。定義的發送數組是內存。3. 內存地址遞增:其實不難理解,從發送數組的UART1_TXBUFFER[0]- UART1_TXBUFFER[n]肯定是遞增的。4. 外設地址不遞增:所有的數據都是通過串口發送寄存器發出去,所以外設地址不變。5. 內存/外設數據長度:串口發送的數據都是字節為單位,所以長度是Byte6. DMA_ITConfig(DMA1_Channel2,DMA_IT_TC,ENABLE);注意這一句不要寫錯。
第五步:DMA1的中斷處理函數/** *@brief DMA1_Channel1中斷服務函數 *@param 無 *@retval 無 */ void DMA1_Channel2_3_IRQHandler(void) { /*判斷DMA傳輸完成中斷*/ if(DMA_GetITStatus(DMA1_IT_TC2)!= RESET) { UART1_STATE = 2;// send over } /*清除DMA中斷標志位*/ DMA_ClearITPendingBit(DMA1_IT_TC2); } 這里使用了一個變量UART1_STATE作為標志位
第六步:使用DMA1發送串口數據 USART1_Init(115200); DMA1_Init(); while(1) { if(UART1_STATE==2) { UART1_STATE = 1; DMA_Cmd(DMA1_Channel2,DISABLE); // 發送完成先關掉DMA通道 DMA_SetCurrDataCounter(DMA1_Channel2,12); // 設置需要發送的長度 DMA_Cmd(DMA1_Channel2,ENABLE); // 再打開DMA通道 } GPIO_SetBits(GPIOA,GPIO_Pin_4);Delay(500); GPIO_SetBits(GPIOA,GPIO_Pin_3);Delay(500); GPIO_ResetBits(GPIOA,GPIO_Pin_4);Delay(500); GPIO_ResetBits(GPIOA,GPIO_Pin_3);Delay(500); } 注意事項:1. 一定要注意,DMA的傳輸有個長度計數器,DMA傳輸完成后,計數器里的值就變成了0;數據是不傳了,但是通道并沒有關閉。所以想要再次傳輸就需要修改這個長度計數器的值,但是這個值的修改必須要關閉通道后修改。所以就有了上面的步驟,關閉通道—修改計數值—打開通道 希望對各位看官有所幫助,并能觸類旁通,對于外設到內存啊,內存到內存啊,ADC與DMA啊,SPI與DMA都能輕松的應用。
