查看: 1494|回復: 0
控制電機轉動程序
ID:360164 發表于 2018-6-27 12:42 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
#include <intrins.h>
sbit YELLOW=P0^7;
sbit GREEN=P2^0;
sbit RED=P2^1;
sbit BLUE =P2^2;
sbit ENA=P2^7;
sbit ENB=P3^0;
sbit IN1 = P2^3;
sbit IN2 = P2^4;
sbit IN3 = P2^5;
sbit IN4 = P2^6;
uchar cycle=100;
uchar speed=80;
   void Delay(uint t)            //延時函數
         int i,j;
         for(i=110;i>0;i--)
         for(j=t;j>0;j--);
   void t0(void) interrupt 1
     if(cycle>100)
            cycle=0;
         if(speed<cycle)
            ENA=ENB=0;
                ENA=ENB=1;
                cycle++;
    void main()             //主函數
           EA=1;
           ET0=1;
       TMOD=0X02;
           TH0=0XA3;
           TL0=0XA3;
           TR0=1;
           Delay(5);
           P1=0XFF;
          if(P1==0XFE)            //前進
                         GREEN=0;
                  IN1 = 0;  //電機轉動函數
                  IN2 = 1;
                  IN3 = 0;
                  IN4 = 1;
                GREEN=1
           if(P1==0XFD)            //后退
      RED=0;
                  IN1 = 1;  //電機轉動函數
                  IN2 = 0;
                  IN3 = 1;
                  IN4 = 0;
      RED=1;
          if(P1==0XFB)            //左轉
      BLUE =0;
                  IN1 = 0;  //電機轉動函數
                  IN2 = 0;
                  IN3 = 0;
                  IN4 = 1;
                        BLUE =1;
           if(P1==0XF7)           //右轉
      YELLOW=0;
                  IN1 = 0;  //電機轉動函數
                  IN2 = 1;
                  IN3 = 0;
                  IN4 = 0;
                YELLOW=1;
           if(P1==0XEF)           //停止
                         IN1 = 0;  //電機轉動函數
                  IN2 = 0;
                  IN3 = 0;
                  IN4 = 0;
