查看: 1895|回復: 2
下降沿中斷打開定時器計算每兩個下降沿的時間
ID:191710 發表于 2018-6-27 09:45 | 顯示全部樓層 |閱讀模式
下降沿中斷打開定時器計算每兩個下降沿的時間。
void exint0_init()
        IT0=1;
        EX0=1;
void exint0_interrupt() interrupt 0
        TR0 = 0;
        SBUF=count_time;
        count_time=0;
        TR0 = 1;
void timer0_init()
        //16us進入一次中斷
        AUXR |= 0x80;
        TMOD &= 0xF0;
        TL0 = 0x4F;
        TH0 = 0xFF;
        TF0 = 0;
        ET0=1;
void timer0_interrupt() interrupt 1
        count_time++;
        if(count_time>=96)
                TR0 = 0;
但是 通過串口 接收的數據發現不正確。有高手可以告訴我問題嗎?
ID:191710 發表于 2018-6-27 09:47 | 顯示全部樓層
00 10 00 F9 0E 40 00 40 00 20 00 00 00 00 40 40 00 10 00 00 00 20 00 00 20 00 00 10 00 A0 21 30 20 40 00 10 00 00 00 00 00 40 40 20 01 00 00 00 00 30 00 00 40 20 00 20 00 00 40 0F 41 00 20 00 00 00 00 41 40 00 00 00 00 08 20 00 00 20 00 20 00 21 00 00 00 00 40 10 00 00 00 00 00 00 40 41 00 00 00 00 00 60 00 00 40 20 00 60 00 00 40 00 40 00 01 00 00 00 00 00 40 40 20 00 00 00 00 00 F1 01 00 00 20 00 60 00 00 00 00 40 00 21 00 00 00 00 40 40 01 00 00 00 00 A0 1F 00 20 00 20 00 A0 00 00 00 00 40 00 10 00 00 00 00 00 40 40 01 00 00 00 00 60 1F 00 40 20 00 60 00 0F 40 00 40 00 10 00 00 00 00 00 40 40 20 00 00 00 00 00 F1 01 00 00 20 00 60 00 00 00 00 40 01 20 00 00 00 00 40 41 00 00 00 10 00 20 00 00 20 40 20 00 A0 00 1F 00 00 40 01 00 01 00 01 20 21 40 43 43 60 73 93 70 93 8C 8F 70 9E 53 73 4C 60 C8 48 CF 5F 60
這是 串口 接收的數據,不正確。
ID:360343 發表于 2018-6-27 15:54 | 顯示全部樓層
這是 串口 接收的數據,不正確。
