有沒有遇到采用中斷方式每隔幾秒種發(fā)送一組數(shù)據(jù)出去之后,調(diào)試助手收到多個同樣的數(shù)據(jù),而在串口發(fā)送后加1秒的延遲程序,收到的就只有一組數(shù)據(jù).
#include "stc15.h"
#include "USART.h"
#include "intrins.H"
unsigned char TxBusy = 0; //發(fā)送忙檢測
unsigned char rxBuff[rxLength]={0}; //接收緩沖區(qū),長度50
unsigned char txBuff[txLength]={0}; //發(fā)送緩沖區(qū),長度50
unsigned char rxcnt = 0; //接收計數(shù)
/* void Uart_Init(void) //115200bps@11.0592MHz
SCON = 0x50; //8位數(shù)據(jù),可變波特率
AUXR |= 0x01; //串口1選擇定時器2為波特率發(fā)生器
AUXR |= 0x04; //定時器2時鐘為Fosc,即1T
T2L = 0xE8; //設(shè)定定時初值
T2H = 0xFF; //設(shè)定定時初值
AUXR |= 0x10; //啟動定時器2
ES = 1; //使能串口中斷
EA = 1; //開總中斷
void Uart_Init(void) //9600bps@11.0592MHz
T2L = 0xE0; //設(shè)定定時初值
T2H = 0xFE; //設(shè)定定時初值
ES = 1; //使能串口中斷
EA = 1; //開總中斷
void Uart1_SendByte(unsigned char dat)
//unsigned int OutTime = 10000;
//TI = 0;
//while((TxBusy)&&(OutTime--));
while(TxBusy);
SBUF = dat;
TxBusy = 1;
while(TxBusy);//等待數(shù)據(jù)發(fā)送完成,進(jìn)入中斷,將TI、TxBusy清0
TxBusy = 1;
SBUF = dat;
void Uart1_SendByte_N(unsigned char *dat,unsigned char N)
while(N--)
Uart1_SendByte(*dat) ;
dat++;
void Uart1_IT_Handle(void) interrupt 4 using 1
unsigned char temp;
if(RI)
RI = 0; //清RI
if(rxcnt<rxLength)
rxBuff[rxcnt++]= SBUF;
temp =SBUF; //讀BUFF
if(TI)
TI = 0 ; //清TI
TxBusy = 0 ; //清BUSY
/*void Uart_SendStr(const char* str)
while(*str)
Uart1_SendByte(*str);
str++;
