查看: 1477|回復(fù): 0
這個(gè)匯編代碼 萌新求大神給個(gè)注釋
ID:356219 發(fā)表于 2018-6-24 22:44 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
ORG 0000H
AJMP MAIN
ORG 0003H
AJMP INTX
MAIN:
  MOV DPTR,#7FFFH
  MOV R0,#0FFH
  MOV A,R0
  MOVX @DPTR,A
  SETB EA
  SETB EX0
  L2:
  MOV DPTR,#7FFFH
  MOV A,R0
  MOVX @DPTR,A
MOV TMOD ,#01H
MOV TL0,#00H
MOV TH0,#00H
MOV R1,#30H
JB P1.0,$
SETB TR0
JNB P1.0,$
CLR TR0
MOV @R1,TL0
INC R1
MOV @R1,TH0
LCALL ZH
LCALL DisplayLED
LJMP L2
ZH:
MOV A,30H
ANL A,#0FH
MOV DPTR,#LED
MOVC A,@A+DPTR
MOV 32H,A
MOV A,30H
SWAP A
ANL A,#0FH
MOV DPTR,#LED
MOVC A,@A+DPTR
MOV 33H,A
MOV A,31H
ANL A,#0FH
MOV DPTR,#LED
MOVC A,@A+DPTR
MOV 34H,A
MOV A,31H
SWAP A
ANL A,#0FH
MOV DPTR,#LED
MOVC A,@A+DPTR
MOV 35H,A
RET
LED:
DB 3FH,06H,5BH,4FH,66H,6DH
DB 7DH,07H,7FH,6FH,77H,7CH
DB 39H,5EH,79H,71H;
DisplayLED:
     MOV   A,35H
CLR     P2.0
MOV   P0,A
ACALL   DELAY1
  SETB P2.0
MOV   A,34H
CLR     P2.1
MOV   P0,A
ACALL   DELAY1
  SETB P2.1
  MOV   A,33H
CLR     P2.2
MOV   P0,A
ACALL   DELAY1
  SETB P2.2
  MOV   A,32H
CLR     P2.3
MOV   P0,A
ACALL   DELAY1
  SETB P2.3
RET
DELAY1:
MOV   R2,#20
D4:    MOV   R3,#250
       DJNZ   R3,$
DJNZ    R2,D4
RET
  INTX:
  CLR EA
  JNB P1.4,IN1
  JNB P1.5,INT2
  JNB P1.6,INT3
  JNB P1.7,INT4
  L1:
  SETB EA
  RETI
  IN1:
  MOV DPTR,#7FFFH
  MOV R0,#80H
  MOV A,R0
  MOVX @DPTR,A
   LCALL Delay
  AJMP L1
  INT2:
  MOV DPTR,#7FFFH
  CLR C
  MOV A,#0F0H
  SUBB A,R0
  MOV R0,A
   LCALL Delay
  AJMP L1
  INT3:
  MOV DPTR,#7FFFH
  MOV A,R0
  INC A
  MOV R0,A
  MOVX @DPTR,A
  LCALL Delay
  AJMP L1
  INT4:
MOV DPTR,#7FFFH
  MOV A,R0
  DEC A
  MOV R0,A
  MOVX @DPTR,A
  LCALL Delay
  AJMP L1
  Delay: MOV R7, #02H; 延時(shí)子程序
  DelayLoop1: MOV R6,#0FFH
  DelayLoop2: MOV R5,#0FFH
  DelayLoop3: DJNZ R5,DelayLoop3
  DJNZ R6,DelayLoop2
  DJNZ R7,DelayLoop1
  RET
  END
