查看: 1699|回復: 0
電子表匯編實現
HOUR DATA 30H
MIN  DATA 31H
SEC  DATA 32H
cont data 33h
CNTH equ  high(15536)
CNTL equ  low(15536)
NUM  equ  20
        ORG 0
        LJMP START
        org 000bh
        ljmp t0int
START:         MOV HOUR,#23H
        MOV MIN,#58H
        MOV SEC,#56H
        mov tmod,#01
        mov ie,#82h
        mov th0,#CNTH
        mov tl0,#CNTL
        mov cont,#num
        setb tr0
MAIN0:        LCALL DISP
        SJMP MAIN0
t0int:        push acc
        clr tr0
        mov a,#CNTL
        add a,#7
        mov tl0,a
        mov a,#CNTH
        addc a,#0
        mov th0,a
        setb tr0
        djnz cont,quit
        mov cont,#num
        mov a,sec
        add a,#1
        da a
        mov sec,a
        cjne a,#60h,quit
        mov sec,#0
        mov a,min
        add a,#1
        da a
        mov min,a
        cjne a,#60h,quit
        mov min,#0
        mov a,hour
        add a,#1
        da a
        mov hour,a
        cjne a,#24h,quit
        mov hour,#0
quit:        pop acc
        reti
DISP:        MOV DPTR,#TAB
        MOV R7,#3
        MOV R1,#HOUR
        MOV R4,#1H
LOP0:        MOV A,@R1
        ANL A,#0F0H
        SWAP A
        MOVC A,@A+DPTR
        CPL A
        MOV P1,A
        MOV A,R4
        MOV P3,A
        LCALL DELAY
        MOV P1,#0FFH
        RL A
        MOV P3,A
        RL A
        MOV R4,A
        MOV A,@R1
        ANL A,#0FH
        MOVC A,@A+DPTR
        orl a,#80h
        CPL A
        MOV P1,A
        LCALL DELAY
        MOV P1,#0FFH
        INC R1
        DJNZ R7,LOP0
        RET
DELAY:        MOV R5,#10H
        MOV R6,#0
DEL0:        DJNZ R6,$
        DJNZ R5,DEL0
        RET
TAB:        DB 3FH,6,5BH,4FH,66H,6DH,7DH,7,7FH,6FH
;          0 1  2   3   4   5   6  7  8   9
        END
電路圖
電路圖
