查看: 4494|回復(fù): 1
新人求助,關(guān)于pcf8951測電壓(設(shè)置電壓檢測范圍)并用lcd1602顯示的問題
ID:357135 發(fā)表于 2018-6-23 11:33 | 顯示全部樓層 |閱讀模式
pcf8951得到的val沒法和我設(shè)置的值比較大小該怎么修改。怎么用鍵盤設(shè)置檢測的電壓上下限范圍?
#include <reg52.h>
#include <intrins.h>
#define LCD1602_DB P0
sbit LCD1602_RS=P2^0;
sbit LCD1602_RW=P2^1;
sbit LCD1602_E=P2^2;
void LcdWaitReady()  //等待液晶準備好
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復(fù)檢測直到其等于0為止
void LcdWriteCmd(unsigned char cmd)  //寫入命令函數(shù)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
void LcdWriteDat(unsigned char dat)  //寫入數(shù)據(jù)函數(shù)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str)  //顯示字符串,屏幕起始坐標(x,y),字符串指針str
    unsigned char addr;
    //由輸入的顯示坐標計算顯示RAM的地址
    if (y == 0)
        addr = 0x00 + x; //第一行字符地址從0x00起始
        addr = 0x40 + x; //第二行字符地址從0x40起始
    //由起始顯示RAM地址連續(xù)寫入字符串
    LcdWriteCmd(addr | 0x80); //寫入起始地址
    while (*str != '\0')      //連續(xù)寫入字符串數(shù)據(jù),直到檢測到結(jié)束符
        LcdWriteDat(*str);
        str++;
void LcdInit()  //液晶初始化函數(shù)
          LcdWriteCmd(0x38);  //16*2顯示,5*7點陣,8位數(shù)據(jù)接口
    LcdWriteCmd(0x0C);  //顯示器開,光標關(guān)閉
    LcdWriteCmd(0x06);  //文字不動,地址自動+1
    LcdWriteCmd(0x01);  //清屏
/***********************I2C.c文件程序源代碼*************************/
#include <reg52.h>
#define I2CDelay()  {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^7;
sbit I2C_SDA = P3^6;
void I2CStart()  //產(chǎn)生總線起始信號
    I2C_SDA = 1; //首先確保SDA、SCL都是高電平
    I2C_SCL = 1;
    I2CDelay();
    I2C_SDA = 0; //先拉低SDA
    I2CDelay();
    I2C_SCL = 0; //再拉低SCL
void I2CStop()   //產(chǎn)生總線停止信號
    I2C_SCL = 0; //首先確保SDA、SCL都是低電平
    I2C_SDA = 0;
    I2CDelay();
    I2C_SCL = 1; //先拉高SCL
    I2CDelay();
    I2C_SDA = 1; //再拉高SDA
    I2CDelay();
bit I2CWrite(unsigned char dat) //I2C總線寫操作,待寫入字節(jié)dat,返回值為應(yīng)答狀態(tài)
    bit ack;  //用于暫存應(yīng)答位的值
    unsigned char mask;  //用于探測字節(jié)內(nèi)某一位值的掩碼變量
    for (mask=0x80; mask!=0; mask>>=1) //從高位到低位依次進行
        if ((mask&dat) == 0)  //該位的值輸出到SDA上
            I2C_SDA = 0;
            I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;          //拉高SCL
        I2CDelay();
        I2C_SCL = 0;          //再拉低SCL,完成一個位周期
    I2C_SDA = 1;   //8位數(shù)據(jù)發(fā)送完后,主機釋放SDA,以檢測從機應(yīng)答
    I2CDelay();
    ack = I2C_SDA; //讀取此時的SDA值,即為從機的應(yīng)答值
    I2CDelay();
    I2C_SCL = 0;   //再拉低SCL完成應(yīng)答位,并保持住總線
    return (~ack); //應(yīng)答值取反以符合通常的邏輯:0=不存在或忙或?qū)懭胧。?=存在且空閑或?qū)懭氤晒?br /> }
unsigned char I2CReadNAK() //I2C總線讀操作,并發(fā)送非應(yīng)答信號,返回值為讀到的字節(jié)
    unsigned char mask;
    unsigned char dat;
    I2C_SDA = 1;  //首先確保主機釋放SDA
        I2CDelay();
        if(I2C_SDA == 0)  //讀取SDA的值
            dat &= ~mask; //為0時,dat中對應(yīng)位清零
            dat |= mask;  //為1時,dat中對應(yīng)位置1
        I2CDelay();
        I2C_SCL = 0;      //再拉低SCL,以使從機發(fā)送出下一位
    I2C_SDA = 1;   //8位數(shù)據(jù)發(fā)送完后,拉高SDA,發(fā)送非應(yīng)答信號
    I2CDelay();
    I2CDelay();
    I2C_SCL = 0;   //再拉低SCL完成非應(yīng)答位,并保持住總線
    return dat;
unsigned char I2CReadACK() //I2C總線讀操作,并發(fā)送應(yīng)答信號,返回值為讀到的字節(jié)
    unsigned char mask;
    unsigned char dat;
        I2CDelay();
        I2CDelay();
    I2C_SDA = 0;   //8位數(shù)據(jù)發(fā)送完后,拉低SDA,發(fā)送應(yīng)答信號
    I2CDelay();
    I2CDelay();
    return dat;
/***********************main.c文件程序源代碼*************************/
#include <reg52.h>
bit flag300ms = 1;       //300ms定時標志
unsigned char T0RH = 0;  //T0重載值的高字節(jié)
unsigned char T0RL = 0;  //T0重載值的低字節(jié)
unsigned char GetADCValue(unsigned char chn);
void ValueToString(unsigned char *str, unsigned char val);
void ConfigTimer0(unsigned int ms);
extern void LcdInit();
extern void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str);
extern void I2CStart();
extern void I2CStop();
extern unsigned char I2CReadACK();
extern unsigned char I2CReadNAK();
extern bit I2CWrite(unsigned char dat);
void main ()
    unsigned char val;
    unsigned char str[10];
    EA = 1;           //開總中斷
    ConfigTimer0(10); //配置T0定時10ms
    LcdInit();        //初始化液晶
    LcdShowStr(2,0, "Volt   Volt");  //顯示通道指示
        if (flag300ms)
            flag300ms = 0;
            //顯示通道3的電壓
            val = GetADCValue(3);     //獲取ADC通道3的轉(zhuǎn)換值
                                                ValueToString(str, val);  //轉(zhuǎn)為字符串格式的電壓值
                                        if(val<1.2)
                LcdShowStr(2,1, "Low ");
        else if(val>=1.2&&val<=2.1)
        LcdShowStr(2, 1, str);    //顯示到液晶上
                LcdShowStr(2,1, "High");
                        val = GetADCValue(0);     //獲取ADC通道0的轉(zhuǎn)換值
        if(str[0]==str[5]||str[0]==str[6])
        LcdShowStr(9, 1, str);    //顯示到液晶上
                LcdShowStr(9,1, "High");
unsigned char GetADCValue(unsigned char chn)  //讀取當前的ADC轉(zhuǎn)換值,chn為ADC通道號0-3
    unsigned char val;
                    I2CStart();
            if (!I2CWrite(0x48<<1))   //尋址PCF8591,如未應(yīng)答,則停止操作并返回0
                I2CStop();
                        return 0;
    I2CWrite(0x40|chn);       //寫入控制字節(jié),選擇轉(zhuǎn)換通道
    I2CStart();
    I2CWrite((0x48<<1)|0x01); //尋址PCF8591,指定后續(xù)為讀操作
            I2CReadACK();             //先空讀一個字節(jié),提供采樣轉(zhuǎn)換時間
            val = I2CReadNAK();       //讀取剛剛轉(zhuǎn)換完的值
            I2CStop();
    return val;
void ValueToString(unsigned char *str, unsigned char val)  //ADC轉(zhuǎn)換值轉(zhuǎn)為實際電壓值的字符串形式
        val = (val*25) / 255;    //電壓值=轉(zhuǎn)換結(jié)果*2.5V/255
    str[0] = (val/10) + '0'; //整數(shù)位字符
    str[1] = '.';            //小數(shù)點
    str[2] = (val%10) + '0'; //小數(shù)位字符
    str[3] = 'V';            //電壓單位
    str[4] = '\0';           //結(jié)束符
          str[5]='1';  //設(shè)置通道3電壓上限
        str[6]='0';  //設(shè)置通道3電壓下限
void ConfigTimer0(unsigned int ms)  //T0配置函數(shù)
    unsigned long tmp;
    tmp = 11059200 / 12;      //定時器計數(shù)頻率
    tmp = (tmp * ms) / 1000;  //計算所需的計數(shù)值
    tmp = 65536 - tmp;        //計算定時器重載值
    tmp = tmp + 12;           //修正中斷響應(yīng)延時造成的誤差
    T0RH = (unsigned char)(tmp >> 8);  //定時器重載值拆分為高低字節(jié)
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = T0RH;     //加載T0重載值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動T0
void InterruptTimer0() interrupt 1  //T0中斷服務(wù)函數(shù)
    static unsigned char tmr300ms = 0;
    TH0 = T0RH;  //定時器重新加載重載值
    TL0 = T0RL;
    tmr300ms++;
    if (tmr300ms >= 30)  //定時300ms
        tmr300ms = 0;
        flag300ms = 1;
ID:357135 發(fā)表于 2018-6-23 13:06 | 顯示全部樓層
還有我仿真的時候lcd還能顯示 燒錄到開發(fā)板之后就不行了,用的是普中科技的開發(fā)板EM3 V3.0
