查看: 2246|回復: 3
請問大家為什么我的數碼管顯示的不正常啊,是程序哪出問題了嗎
ID:354521 發表于 2018-6-21 23:06 | 顯示全部樓層 |閱讀模式
    本來應該是應該顯示幾個數而且可調節,但是一直在抖動,這是程序
  1. #define uchar unsigned char
  2. #define uint unsigned int
  3. sbit DQ=P1^7;
  4. sbit key1=P1^3;
  5. sbit key2=P1^4;
  6. sbit dianji=P3^1;
  7. float ff;
  8. uint y3;
  9. uchar shi,ge,xiaoshu,sheding=20,gaonum,dinum;
  10. uchar code dispcode[]={    //∂Œ¬Î
  11. 0x3f,0x06,0x5b,0x4f,
  12. 0x66,0x6d,0x7d,0x07,
  13. 0x7f,0x6f,0x77,0x7c,
  14. 0x39,0x5e,0x79,0x71};
  15. uchar code tablel[]={ //¥ˉ–° ˝μ„μƒ∂Œ¬Î
  16. 0xbf,0x86,0xdb,0xcf,
  17. 0xe6,0xed,0xfd,
  18. 0x87,0xff,0xef};
  19. uchar dispbitcode[]={    //Œa—°
  20. 0xfe,0xfd,0xfb,0xf7,
  21. 0xef,0xdf,0xbf,0x7f};
  22. uchar dispbuf[8]={0,0,0,0,0,0,0,0};
  23. void Delay(uint num)// —” ±∫Ø ˝
  24. {
  25.          while(--num);
  26. }
  27. void digitalshow(uchar a4,uchar a3,uchar a2,uchar a1,uchar a0)
  28. {
  29.          dispbuf[0]=a0;
  30.          dispbuf[1]=a1;
  31.           dispbuf[2]=a2;
  32.         dispbuf[3]=a3;
  33.         dispbuf[4]=a4;
  34.
  35.          P2=0xff;
  36.          P0=dispcode[dispbuf[0]];
  37.         P2=dispbitcode[5];
  38.         Delay(1);
  39.
  40.          P2=0xff;
  41.          P0=dispcode[dispbuf[1]];
  42.          P2=dispbitcode[4];
  43.          Delay(1);
  44.          P2=0xff;
  45.          P0=dispcode[dispbuf[2]];
  46.          P2=dispbitcode[2];
  47.         Delay(1);
  48.          P2=0xff;
  49.          P0=tablel[dispbuf[3]];
  50.          P2=dispbitcode[1];
  51.         Delay(1);
  52.          P2=0xff;
  53.          P0=dispcode[dispbuf[4]];
  54.         P2=dispbitcode[0];
  55.         Delay(1);
  56. }
  57. void dmsec(uint count)
  58. {
  59.          uint i;   // 1ms—” ±
  60.          while(count--)
  61.         {
  62.                 for(i=0;i<125;i++){}
  63.         }
  64. }
  65. void tmreset(void)
  66. {
  67.         DQ=0;
  68.         Delay(90);
  69.         DQ=1;
  70.         Delay(4);
  71. }
  72. void tmpre(void)
  73. {
  74.         while(DQ);
  75.          while(~DQ);
  76.          Delay(4);
  77. }
  78. bit tmrbit(void)
  79. {
  80.          uint i;
  81.         bit dat;
  82.         DQ=0;
  83.          i++;    // i++;¥Û∏≈1us
  84.         DQ=1;
  85.         i++;
  86.         i++;
  87.         dat=DQ;
  88.          Delay(8);
  89.         return(dat);
  90. }
  91. uchar tmrbyte(void)  //∂¡“a∏ˆ±»Ãÿ
  92. {
  93.         uchar i,j,dat;
  94.         dat=0;
  95.          for(i=1;i<=8;i++)
  96.         {
  97.                 j=tmrbit();
  98.                 dat=(j<<7)|(dat>>1);
  99.         }
  100.          return(dat);
  101. }
  102. void tmwbyte(uchar dat)  //–¥“a∏ˆ±»Ãÿ
  103. {
  104.         uint i;
  105.         uchar j;
  106.         bit testb;
  107.          for(j=1;j<=8;j++)
  108.         {
  109.                 testb=dat&0x01;
  110.                 dat=dat>>1;  // ¥”μÕŒaø™ o
  111.                 if(testb)       // Write 1
  112.                 {
  113.                         DQ=0;   // œ»¿≠μÕ
  114.                         i++;
  115.                         i++;  // >1us
  116.                         DQ=1;
  117.                         Delay(4);
  118.                 }
  119.                 else            // Write 0
  120.                 {
  121.                         DQ=0;
  122.                            Delay(4);
  123.                         DQ=1;
  124.                         i++;
  125.                         i++;   // ‘Ÿ¿≠∏fl
  126.                 }
  127.         }
  128. }
  129. void tmstart(void)    //ds1820ø™ o◊™aa
  130. {
  131.          dmsec(1);
  132.         tmreset();
  133.         tmpre();
  134.         dmsec(1);
  135.     tmwbyte(0xcc);   // skip rom
  136.         tmwbyte(0x44);   // ◊™aa
  137. }
  138. uchar tmrtemp(void)     //∂¡»°Œ¬∂»
  139. {
  140.         uchar a,b;
  141.         tmreset();
  142.         tmpre();
  143.         dmsec(1);
  144.          tmwbyte(0xcc);   // skip rom
  145.          tmwbyte(0xbe);   // ◊™aa
  146.         a=tmrbyte();   // LSBμÕ8Œa
  147.         b=tmrbyte();  // MSB∏fl8Œa
  148.         y3=b;
  149.         y3<<=8;
  150.         y3=y3|a;
  151.          ff=y3*0.0625;
  152.         y3=ff*10+0.5;
  153.         return(y3);
  154. }
  155. void keyscan(void)
  156. {
  157.          if(key1==0)
  158.         {
  159.                 dmsec(5);
  160.                 if(key1==0)
  161.                 {
  162.                         sheding++;
  163.                         if(sheding==100)
  164.                         sheding=20;
  165.                 }
  166.                 while(!key1);
  167.         }
  168.          else if(key2==0)
  169.         {
  170.                 dmsec(5);
  171.                 if(key2==0)
  172.                 {
  173.                         sheding--;
  174.                         if(sheding==0)
  175.                         sheding=20;
  176.                 }
  177.                 while(!key2);
  178.         }
  179. }
  180. void deal(uint tmp)   //Œ¬∂»¥¶¿ì
  181. {
  182.          if(tmp<=sheding)
  183.         {
  184.                 gaonum=0;
  185.                 dinum=4;
  186.         }
  187.          else if((tmp>sheding)&&(tmp<=(sheding+5)))
  188.         {
  189.                 gaonum=1;
  190.                 dinum=3;
  191.         }
  192.          else if((tmp>(sheding+5))&&(tmp<=(sheding+10)))
  193.         {
  194.                 gaonum=2;
  195.                 dinum=2;
  196.         }
  197.          else if((tmp>(sheding+10))&&(tmp<=(sheding+15)))
  198.         {
  199.                 gaonum=3;
  200.                 dinum=1;
  201.         }
  202.         else
  203.         {
  204.                 gaonum=4;
  205.                  dinum=0;
  206.         }
  207. }
  208. void dianjik()    //μáa˙øÿ÷∆
  209. {
  210.          uchar q,i;
  211.          for(q=0;q<dinum;q++)
  212.         {
  213.                   dianji=0;
  214.                  digitalshow(shi,ge,xiaoshu,sheding/10,sheding%10);
  215.                 for(i=255;i>0;i--)
  216.                 {
  217.                            digitalshow(shi,ge,xiaoshu,sheding/10,sheding%10);
  218.                   }
  219.         }
  220.          for(q=0;q<gaonum;q++)
  221.         {
  222.                   dianji=1;
  223.                   digitalshow(shi,ge,xiaoshu,sheding/10,sheding%10);
  224.                 for(i=255;i>0;i--)
  225.                 {
  226.                            digitalshow(shi,ge,xiaoshu,sheding/10,sheding%10);
  227.                   }
  228.         }
  229. }
  230. void main(void)
  231. {
  232.          uint last;
  233.         dianji=0;
  234.         tmstart();
  235.         dmsec(450);   // ≥ı oaØds18b20
  236.         while(1)
  237.         {
  238.                 tmstart();   // ds1820ø™ o◊™aa
  239.                 dmsec(2);
  240.                 last=tmrtemp()+256; // ∂¡»°Œ¬∂»
  241.                 shi=last/100;
  242.                 ge=(last%100)/10;
  243.                 xiaoshu=(last%100)%10;
  244.                 keyscan();
  245.                 dmsec(2);
  246.                 deal(last/10);
  247.                 dianjik();
  248.         }
  249. }
ID:7485 發表于 2018-6-22 08:36 | 顯示全部樓層
注釋都是亂碼。
電腦軟件仿真正確嗎?
ID:320306 發表于 2018-6-22 08:38 | 顯示全部樓層
延時長了!!!!!!!!!!!!!!!!
ID:305987 發表于 2018-6-22 09:01 | 顯示全部樓層
延時改短點,抖動是因為頻率太低了
