查看: 3406|回復(fù): 0
單片機(jī)交通燈keil程序
ID:355964 發(fā)表于 2018-6-21 13:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#define uint  unsigned int
sbit RED_A    = P0^0;
sbit YELLOW_A = P0^1;
sbit GREEN_A  = P0^2;
sbit RED_B    = P0^3;
sbit YELLOW_B = P0^4;
sbit GREEN_B  = P0^5;
uchar Flash_Count = 0, Operation_Type=1;
void DelayMS(uint x)
uchar i;
while (x--) for (i=0;i<120;i++);
void Traffic_Light()
switch (Operation_Type)
  case 1:
   RED_A=1;YELLOW_A=1;GREEN_A=0;
   RED_B=0;YELLOW_B=1;GREEN_B=1;
   DelayMS(2000);
   Operation_Type=2;
   break;
  case 2:
   DelayMS(300);
   YELLOW_A=!YELLOW_A;GREEN_A=1;
   if(++Flash_Count!=10) return;
   Flash_Count=0;
   Operation_Type=3;
   break;
  case 3:
   RED_A=0;YELLOW_A=1;GREEN_A=1;
   RED_B=1;YELLOW_B=1;GREEN_B=0;
   DelayMS(2000);
   Operation_Type=4;
   break;
  case 4:
   DelayMS(300);
   YELLOW_B=!YELLOW_B;GREEN_B=1;
   Flash_Count=0;
   Operation_Type=1;
   break;
while(1) Traffic_Light();
