查看: 1414|回復(fù): 0
vb編程題目
ID:354514 發(fā)表于 2018-6-19 18:39 | 顯示全部樓層 |閱讀模式
VB2.png Dim a(5, 40)
Private Sub Command1_Click()
    Dim ch As String
    ch$ = ""
    Open App.Path & "\in5.dat" For Input As #1
    For i = 1 To 5
        For j = 1 To 40
            Input #1, a(i, j)
            ch = ch & a(i, j) & " "
        Next j
        ch = ch & Chr(13) & Chr(10)
    Next i
    Close #1
    Text1.Text = ch
End Sub
Private Sub Command2_Click()
'===================考生編寫的程序==============
    Dim sum(1 To 5) As Double, avg(1 To 5) As Double
    For i = 1 To 5
        For j = 1 To 40
            If a(i, j) < 50 Then
                sum(i) = sum(i) + a(i, j)
                k = k + 1
            End If
        Next j
        avg(i) = sum(i) / k
    Next i
    For i = 1 To 5
        Label1(i - 1) = sum(i)
        Text2(i - 1) = Format(avg(i), "##.00")
    Next i
End Sub
Private Sub Command3_Click()
    Open App.Path & "\out5.dat" For Output As #1
    For k = 0 To 4
        Print #1, Label1(k)
    Next k
    For k = 0 To 4
        Print #1, Text2(k)
    Next k
    Close #1
End Sub
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
