#include "TM1638.h"
#include"msp430f6638.h"
/* Private variables ---------------------------------------------------------*/
uint8_t num[8]; //各個數(shù)碼管顯示的值
uint8_t led_flag[8];
const uint8_t tab[] =
{0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void init_port(void){
P3DIR |= BIT5;
P3DIR |= BIT4 + BIT2;
P1DIR |= BIT0;
P1SEL |= BIT0;
int main(void)
unsigned int i = 0;
unsigned char count;
WDTCTL = WDTPW+WDTHOLD; //關(guān)閉看門狗
init_port(); //端口初始化
init_TM1638();
i=Read_key();
if(i<16)
while(Read_key()==i); //等待按鍵釋放
num[0] = tab[ i];
Write_DATA(0*2,num[3]);//寫第i個數(shù)碼管
Write_DATA(1*2,num[2]);
Write_DATA(2*2,num[1]);
Write_DATA(3*2,num[0]);
Write_DATA(4*2,num[7]);
Write_DATA(5*2,num[6]);
Write_DATA(6*2,num[5]);
Write_DATA(7*2,num[4]);
for(count=7;count>0;count--){
num[count] = num[count-1];
