查看: 6308|回復(fù): 0
高速光耦6N137引腳圖與pdf資料下載
ID:69489 發(fā)表于 2018-6-19 11:08 | 顯示全部樓層 |閱讀模式
6N137高速光耦引腳圖:
6N137高速光耦真值表:
The 6N137, EL2601 and EL2611 are consists of an infrared emitting diode optically coupled to a high speed integrated
photo detector logic gate with a strobable output. It is packaged in a 8-pin DIP package and available in wide-lead
spacing and SMD options.
完整的pdf格式文檔51黑下載地址:
6N137_EL26XX.pdf (913.8 KB, 下載次數(shù): 44)
無效樓層,該帖已經(jīng)被刪除
