- #include <reg52.h>
- #include <intrins.h>
- #include <stdlib.h>
- #define uint unsigned int
- #define uchar unsigned char
- uchar code table[]= //共陽數(shù)碼管編碼0~F
- {0xc0,0xf9,0xa4,0xb0,
- 0x99,0x92,0x82,0xf8,
- 0x80,0x90,0x88,0x83,
- 0xc6,0xc0,0x86,0x8e};
- uchar t;
- uint a,b,c;
- sbit key1=P2^0;
- sbit D1=P1^1;
- sbit D2=P1^2;
- sbit D3=P1^3;
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void display()
- bai=num/100; //輸出百位
- shi=num%100/10;//輸出十位
- ge=num%10; //輸出個位
- D1=0;
- P0=table[a];
- delay(10);
- P0=0xff;
- D1=1;
- D2=0;
- P0=table[b];
- delay(10);
- P0=0xff;
- D2=1;
- D3=0;
- P0=table[c];
- delay(10);
- D3=1;
- void key()
- if(key1==0)
- delay(10);
- if(key1==0)
- while(!key1);
- TR0=~TR0;
- srand(t); //初始化種子,函數(shù)srand(t)在stdlib.h
- void main()
- // EX0=1; //使能外部中斷0
- // IT0=1; //設(shè)置外部中斷0觸發(fā)方式為低脈沖
- num=0;
- EA=1; //開總中斷
- ET0=1;
- TMOD=0x01; //設(shè)置T1工作方式
- TH0=(65536-45872)/256; //50ms定時
- TL0=(65536-45872)%256;
- TR0=0;
- while(1)
- key();
- display();
- void T0_time() interrupt 1
- // ET0=0; //首先關(guān)閉中斷
- TH0=(65536-50000)/256; //然后重新裝入預(yù)制值
- TL0=(65536-50000)%256;
- // ET0=1; //打開T0中斷
- t++;
- if(t==20) //如果到了20次,說明1000ms時間到
- t=0; //然后把t清零
- a=rand()%12; //獲得0~12之間的隨機數(shù),函數(shù)rand()在stdlib.h
- b=rand()%12;
- c=rand()%12;
- //randdata=rand()%(300-200+1)+200 //獲得200~300之間的隨機數(shù),函數(shù)rand()在stdlib.h
- EX_INT0() interrupt 0 using 1 //外部中斷0服務(wù)函數(shù)
- if(TR0==1) //判斷當前定時計數(shù)器的狀態(tài)
- TR0=0;
- else
- TR0=1;
復(fù)制代碼 |
