查看: 1610|回復(fù): 0
stm32智能小車源碼
ID:209704 發(fā)表于 2018-6-17 14:50 | 顯示全部樓層 |閱讀模式
stm32智能小車
  1. #include "pwm_output.h"
  2. /*
  3. * 函數(shù)名:TIM3_GPIO_Config
  4. * 描述  :配置TIM3復(fù)用輸出PWM時用到的I/O
  5. * 輸入  :無
  6. * 輸出  :無
  7. * 調(diào)用  :內(nèi)部調(diào)用
  8. */
  9. static void TIM3_GPIO_Config(void)
  10. {
  11.   GPIO_InitTypeDef GPIO_InitStructure;
  12.         /* TIM3 clock enable */
  13.         //PCLK1經(jīng)過2倍頻后作為TIM3的時鐘源等于72MHz
  14.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1|RCC_APB2Periph_GPIOA, ENABLE);
  15.
  16.   /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
  17.   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 ;
  18.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                    // 復(fù)用推挽輸出
  19.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  20.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  21. }
  22. /*
  23. * 函數(shù)名:TIM3_Mode_Config
  24. * 描述  :配置TIM3輸出的PWM信號的模式,如周期、極性、占空比
  25. * 輸入  :無
  26. * 輸出  :無
  27. * 調(diào)用  :內(nèi)部調(diào)用
  28. */
  29. static void TIM3_Mode_Config(void)
  30. {
  31.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  32.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  33.         /* PWM信號電平跳變值 */
  34.         u16 CCR1_Val = 1001;
  35.         u16 CCR2_Val = 1001;
  36.         u16 CCR3_Val = 1001;
  37.         u16 CCR4_Val = 1001;
  38. /* -----------------------------------------------------------------------
  39.     TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
  40.     TIM3CLK = 72 MHz, Prescaler = 0x0, TIM3 counter clock = 72 MHz
  41.     TIM3 ARR Register = 999 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
  42.     TIM3 Frequency = 72 KHz.
  43.     TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
  44.     TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
  45.     TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
  46.     TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
  47.   ----------------------------------------------------------------------- */
  48.   /* Time base configuration */
  49.   TIM_TimeBaseStructure.TIM_Period = 19999;       //當(dāng)定時器從0計數(shù)到999,即為1000次,為一個定時周期
  50.   TIM_TimeBaseStructure.TIM_Prescaler = 71;            //設(shè)置預(yù)分頻:不預(yù)分頻,即為72MHz
  51.   TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        //設(shè)置時鐘分頻系數(shù):不分頻
  52.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上計數(shù)模式
  53.   TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  54.   /* PWM1 Mode configuration: Channel1 */
  55.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;            //配置為PWM模式1
  56.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  57.   TIM_OCInitStructure.TIM_Pulse = CCR1_Val;           //設(shè)置跳變值,當(dāng)計數(shù)器計數(shù)到這個值時,電平發(fā)生跳變
  58.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //當(dāng)定時器計數(shù)值小于CCR1_Val時為高電平
  59.   TIM_OC1Init(TIM1, &TIM_OCInitStructure);         //使能通道1
  60.   TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  61.   /* PWM1 Mode configuration: Channel2 */
  62.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  63.   TIM_OCInitStructure.TIM_Pulse = CCR2_Val;          //設(shè)置通道2的電平跳變值,輸出另外一個占空比的PWM
  64.   TIM_OC2Init(TIM1, &TIM_OCInitStructure);          //使能通道2
  65.   TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  66.   /* PWM1 Mode configuration: Channel3 */
  67.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  68.   TIM_OCInitStructure.TIM_Pulse = CCR3_Val;        //設(shè)置通道3的電平跳變值,輸出另外一個占空比的PWM
  69.   TIM_OC3Init(TIM1, &TIM_OCInitStructure);         //使能通道3
  70.   TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
  71.   /* PWM1 Mode configuration: Channel4 */
  72.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  73.   TIM_OCInitStructure.TIM_Pulse = CCR4_Val;        //設(shè)置通道4的電平跳變值,輸出另外一個占空比的PWM
  74.   TIM_OC4Init(TIM1, &TIM_OCInitStructure);        //使能通道4
  75.   TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);
  76.   TIM_ARRPreloadConfig(TIM1, ENABLE);                         // 使能TIM3重載寄存器ARR
  77.   /* TIM3 enable counter */
  78.   TIM_Cmd(TIM1, ENABLE);                   //使能定時器3
  79. }
  80. /*
  81. * 函數(shù)名:TIM3_PWM_Init
  82. * 描述  :TIM3 輸出PWM信號初始化,只要調(diào)用這個函數(shù)
  83. *         TIM3的四個通道就會有PWM信號輸出
  84. * 輸入  :無
  85. * 輸出  :無
  86. * 調(diào)用  :外部調(diào)用
  87. */
  88. void TIM3_PWM_Init(void)
  89. {
  90.         TIM3_GPIO_Config();
  91.         TIM3_Mode_Config();
  92. }
  93. void TIM3_OUT( u16 CCR1 , u16 CCR2 , u16 CCR3 , u16 CCR4 )
  94. {
  95.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  96.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  97.         /* PWM信號電平跳變值 */
  98.         u16 CCR1_Val;
  99.         u16 CCR2_Val;
  100.         u16 CCR3_Val;
  101.         u16 CCR4_Val;
  102.         CCR1_Val=CCR1;
  103.         CCR2_Val=CCR2;
  104.         CCR3_Val=CCR3;
  105.         CCR4_Val=CCR4;
  106.
  107.   /* PWM1 Mode configuration: Channel1 */
  108.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;            //配置為PWM模式1
  109.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  110.   TIM_OCInitStructure.TIM_Pulse = CCR1;           //設(shè)置跳變值,當(dāng)計數(shù)器計數(shù)到這個值時,電平發(fā)生跳變
  111.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //當(dāng)定時器計數(shù)值小于CCR1_Val時為高電平
  112.   TIM_OC1Init(TIM1, &TIM_OCInitStructure);         //使能通道1
  113.   TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  114.   /* PWM1 Mode configuration: Channel2 */
  115.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  116.   TIM_OCInitStructure.TIM_Pulse = CCR2;          //設(shè)置通道2的電平跳變值,輸出另外一個占空比的PWM
  117.   TIM_OC2Init(TIM1, &TIM_OCInitStructure);          //使能通道2
  118.   TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  119.   /* PWM1 Mode configuration: Channel3 */
  120.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  121.   TIM_OCInitStructure.TIM_Pulse = CCR3;        //設(shè)置通道3的電平跳變值,輸出另外一個占空比的PWM
  122.   TIM_OC3Init(TIM1, &TIM_OCInitStructure);         //使能通道3
  123.   TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
  124.   /* PWM1 Mode configuration: Channel4 */
  125.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  126.   TIM_OCInitStructure.TIM_Pulse = CCR4;        //設(shè)置通道4的電平跳變值,輸出另外一個占空比的PWM
  127.   TIM_OC4Init(TIM1, &TIM_OCInitStructure);        //使能通道4
  128.   TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);
  129.   TIM_ARRPreloadConfig(TIM1, ENABLE);                         // 使能TIM3重載寄存器ARR
  130.   /* TIM3 enable counter */
  131.   TIM_Cmd(TIM1, ENABLE);                   //使能定時器3
  132. }
  133. /******************* (C) COPYRIGHT 2012 WildFire Team *****END OF FILE************/
Keil workspace.rar
410.31 KB, 下載次數(shù): 14, 下載積分: 黑幣 -5
智能小車
