查看: 2530|回復: 0
有沒有單片機斷點保護的應用案例?這程序怎么進行斷點保護?
ID:300079 發表于 2018-6-15 20:56 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define out P0
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
sbit S1=P2^3;
sbit S2=P2^4;
sbit S3=P2^5;
sbit S4=P2^6;
sbit S5=P2^7;
unsigned char keyval;
void forward();
void backward();
void ALter();
void blink();
void key_scan();
void led_delay();
void delay10ms();
void check_busy(void);
void write_command(uchar com);
void write_data(uchar dat);
void string(uchar ad ,uchar *s);
void lcd_test(void);
void LCD_initial( );
void delay(uint);
void main(void)
        LCD_initial( );
                key_scan();
           switch(keyval)
              case 1:forward();
                  break;
                  case 2:backward();
                  break;
                  case 3:ALter();
                  break;
                  case 4:blink();
                  break;
                string(0x85,"I LOVE YOU!");
                string(0xC2,"Fan Li Sheng");
                delay(100);
                write_command(0x01);
                delay(100);
void delay(uint j)
        uchar i=250;
        for(;j>0;j--)
                while(--i);
                i=249;
                while(--i);
                i=250;
        uchar dt;
        do
                dt=0xff;
                E=0;
                RS=0;
                RW=1;
E=1;
dt=out;
}while(dt&0x80);
E=0;
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_( );
E=0;
delay(1);
        check_busy();
        E=0;
        RS=1;
        RW=0;
        out=dat;
        E=1;
        _nop_();
        E=0;
        delay(1);
void LCD_initial(void)
write_command(0x38);
write_command(0x0C);
write_command(0x06);
delay(1);
void string(uchar ad,uchar *s)
write_command(ad);
while(*s>0)
write_data(*s++);
delay(100);
void key_scan(void)
   P2=0xff;
   if((P2&0xf8)!=0xf8)
       delay10ms();
           if(S1==0)
           keyval=1;
           if(S2==0)
           keyval=2;
           if(S3==0)
           keyval=3;
           if(S4==0)
           keyval=4;
           if(S5==0)
           keyval=5;
void forward(void)
    P3=0xfb;
        led_delay();
        P3=0xf7;
        led_delay();
        P3=0xef;
        led_delay();
        P3=0xdf;
        led_delay();
        P3=0xbf;
        led_delay();
        P3=0x7f;
        led_delay();
void backward(void)
    P3=0x7f;
        led_delay();
        P3=0xbf;
        led_delay();
        P3=0xdf;
        led_delay();
        P3=0xef;
        led_delay();
        P3=0xf7;
        led_delay();
        P3=0xfb;
        led_delay();
void Alter(void)
    P3=0x1f;
        led_delay();
        P3=0xe3;
        led_delay();
void blink(void)
    P3=0xff;
        led_delay();
        P3=0x00;
        led_delay();
void led_delay(void)
    unsigned char i,j;
        for(i=0;i<220;i++)
        for(j=0;j<220;j++);
void delay10ms(void)
    unsigned char i,j;
        for(i=0;i<100;i++)
        for(j=0;j<100;j++);
