查看: 2886|回復: 0
51單片機WIFI通信發射機源碼
ID:349440 發表于 2018-6-11 14:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. #include "timer0.h"
  4. typedef unsigned char BYTE;
  5. typedef unsigned int WORD;
  6. #define FOSC 11059200L      //System frequency  系統頻率
  7. #define BAUD 9600           //UART baudrate     UART波特率
  8. /*Define UART parity mode*/
  9. #define NONE_PARITY     0   //None parity       無奇偶校驗
  10. #define ODD_PARITY      1   //Odd parity        奇校驗
  11. #define EVEN_PARITY     2   //Even parity       偶校驗
  12. #define MARK_PARITY     3   //Mark parity       校驗位始終為1
  13. #define SPACE_PARITY    4   //Space parity      校驗位始終為0
  14. #define PARITYBIT NONE_PARITY   //Testing even parity      偶校驗測試
  15.
  16. bit busy;
  17. void SendData(BYTE dat);
  18. void SendString(char *s);
  19. void Delay500ms()                //@11.0592MHz
  20. {
  21.         unsigned char i, j, k;
  22.         _nop_();
  23.         i = 4;
  24.         j = 129;
  25.         k = 119;
  26.         do
  27.         {
  28.                 do
  29.                 {
  30.                         while (--k);
  31.                 } while (--j);
  32.         } while (--i);
  33. }
  34. void main()
  35. {
  36. #if (PARITYBIT == NONE_PARITY)
  37.     SCON = 0x50;            //8-bit variable UART(8位變量的UART)
  38. #elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
  39.     SCON = 0xda;            //9-bit variable UART, parity bit initial to 1(9位變量的UART,奇偶位初始值為1)
  40. #elif (PARITYBIT == SPACE_PARITY)
  41.     SCON = 0xd2;            //9-bit variable UART, parity bit initial to 0(9位變量的UART,奇偶位初始值為0)
  42. #endif
  43.     TMOD = 0x20;            //Set Timer1 as 8-bit auto reload mode(設置定時器18位自動重載模式)
  44.     TH1 = TL1 = -(FOSC/12/32/BAUD); //Set auto-reload vaule(設置自動加載值)
  45.     TR1 = 1;                //Timer1 start run(打開定時器1)
  46.     ES = 1;                 //Enable UART interrupt(開UART中斷)
  47.     EA = 1;                 //Open master interrupt switch(開主中斷開關)
  48.     while(1)
  49.         {
  50.                 Delay500ms();
  51.                 SendString("1");
  52.         }
  53. }
  54. /*----------------------------
  55. UART interrupt service routine(中斷服務程序)
  56. ----------------------------*/
  57. void Uart_Isr() interrupt 4 using 1
  58. {
  59.     if (RI)
  60.     {
  61.         RI = 0;             //Clear receive interrupt flag(清除接收中斷標志)
  62. //        P0 = SBUF;          //P0 show UART data
  63.     }
  64.     if (TI)
  65.     {
  66.         TI = 0;             //Clear transmit interrupt flag(清除傳輸中斷標志)
  67.         busy = 0;           //Clear transmit busy flag(清除傳輸繁忙標志)
  68.     }
  69. }
  70. /*----------------------------
  71. Send a byte data to UART     將字節數據發送到UATR
  72. Input: dat (data to be sent)   輸入:dat(要發送的數據)
  73. Output:None                    輸出:無
  74. ----------------------------*/
  75. void SendData(BYTE dat)
  76. {
  77.     while (busy);           //Wait for the completion of the previous data is sent  等待前一個數據完成發送
  78.     ACC = dat;              //Calculate the even parity bit P (PSW.0)        計算奇偶校驗位P(PSW.0)
  79.     if (P)                  //Set the parity bit according to P              根據P設置奇偶校驗位
  80.     {
  81. #if (PARITYBIT == ODD_PARITY)
  82.         TB8 = 0;            //Set parity bit to 0               將奇偶校驗位設置為0
  83. #elif (PARITYBIT == EVEN_PARITY)
  84.         TB8 = 1;            //Set parity bit to 1               將奇偶校驗位設置為1
  85. #endif
  86.     }
  87.     else
  88.     {
  89. #if (PARITYBIT == ODD_PARITY)
  90.         TB8 = 1;            //Set parity bit to 1               將奇偶校驗位設置為1
  91. #elif (PARITYBIT == EVEN_PARITY)
  92.         TB8 = 0;            //Set parity bit to 0               將奇偶校驗位設置為0
  93. #endif
  94.     }
  95.     busy = 1;
  96.     SBUF = ACC;             //Send data to UART buffer          發送數據到UART緩沖區
  97. }
  98. /*----------------------------
  99. Send a string to UART            發送字符串到UART
  100. Input: s (address of string)     輸入:s(字符串抵地址)
  101. Output:None                      輸出:無
  102. ----------------------------*/
  103. void SendString(char *s)
  104. {
  105.     while (*s)              //Check the end of the string         檢查字符串結尾
  106.     {
  107.         SendData(*s++);     //Send current char and increment string ptr   發送當前字符和字符串指針增量
  108.     }
  109. }
發射機.zip (29.7 KB, 下載次數: 21)
