查看: 5134|回復(fù): 9
無字庫LCD12864顯示8個(gè)漢字后面不顯示,為什么?
ID:296837 發(fā)表于 2018-6-11 13:48 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
本帖最后由 hk0506 于 2018-7-6 08:35 編輯
在無字庫LCD12864上面寫字的時(shí)候,寫了八個(gè)字后,后面的不顯示了,然后一步一步調(diào),發(fā)現(xiàn)超過8個(gè)就不顯示了。
顯示程序如下:
void lcd_display_chinese(uchar screen,uchar page,uchar col,uint mun)
{                //screen:選擇屏幕參數(shù),page:選擇頁參數(shù)0-3,col:選擇列參數(shù)0-3,mun:顯示第幾個(gè)漢字的參數(shù)
        int a;
        mun=mun*32;
        select_screen(screen);                                   //選屏
        W_CMD(0xb8+(page*2));                                   //頁:一頁8點(diǎn)行
        W_CMD(0x40+(col*16));                                   //列:一列1點(diǎn)列
        for (a=0;a<16;a++)
                W_DATA(chinese[mun++]);                           //一個(gè)字16x16
        W_CMD(0xb8+(page*2)+1);                                   //兩頁一行
        W_CMD(0x40+(col*16));                                   //行列指針自加1
        for (        a=0;a<16;a++)
主函數(shù)如下:
        initLCD();                                                  //LCD初始化
        clear_screen(0);                                            //LCD清屏幕
        lcd_display_chinese(1,0,1,0);                  //LCD顯示漢字///一
        lcd_display_chinese(1,0,2,1);                  //LCD顯示漢字//
        lcd_display_chinese(1,0,3,2);                  //LCD顯示漢字//
        lcd_display_chinese(2,0,0,3);                  //LCD顯示漢字//
        lcd_display_chinese(2,0,1,4);                  //LCD顯示漢字//
        lcd_display_chinese(2,0,2,5);                  //LCD顯示漢字//六
        lcd_display_chinese(2,0,3,6);                  //LCD顯示漢字//
        lcd_display_chinese(1,1,0,7);                  //LCD顯示漢字//八
        lcd_display_chinese(1,1,1,8);                  //LCD顯示漢字//
        lcd_display_chinese(1,1,2,9);                  //LCD顯示漢字//
        lcd_display_chinese(1,1,3,10);                  //LCD顯示漢字//
        lcd_display_chinese(2,1,0,11);                  //LCD顯示漢字//
        delay(10);
字庫程序如下:
uchar code chinese[]={
/*0*/
/**-宋體16 縱向取模下高位,數(shù)據(jù)排列:從左到右從上到下-寬x高=16x16**/
0x20,0x20,0x24,0x24,0x24,0xE4,0x26,0x24,0x20,0xFF,0x20,0x22,0x2C,0x20,0x20,0x00,
0x20,0x60,0x3F,0x20,0x20,0x1F,0x11,0x11,0x10,0x03,0x1C,0x20,0x40,0x80,0xE0,0x00,
/*1*/
0x10,0x22,0x64,0x0C,0x80,0x04,0x74,0x84,0x04,0x04,0x04,0xC4,0x3E,0x04,0x00,0x00,
0x04,0x04,0x7E,0x01,0x80,0x40,0x20,0x11,0x0A,0x04,0x0B,0x10,0x60,0xC0,0x40,0x00,
/*2*/
0x40,0x42,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x43,0x62,0x40,0x00,
0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0xC0,0x40,0x00,
/*3*/
0x00,0x10,0x10,0x90,0x10,0x10,0x11,0x16,0x10,0x10,0x10,0xD0,0x18,0x10,0x00,0x00,
0x40,0x40,0x40,0x40,0x43,0x5C,0x40,0x40,0x50,0x4C,0x43,0x40,0x40,0x60,0x40,0x00,
/*4*/
0x00,0x40,0x20,0x10,0xFC,0x03,0x40,0x20,0x10,0xFF,0x08,0x04,0x06,0xC0,0x00,0x00,
0x04,0x04,0x04,0x04,0x05,0x04,0x04,0xFF,0x04,0x04,0x05,0x05,0x05,0x05,0x04,0x00,
/*5*/
0x04,0x04,0x04,0xF4,0x94,0x94,0x95,0x96,0x94,0x94,0x94,0xF4,0x04,0x06,0x04,0x00,
0x00,0xFE,0x02,0x02,0x7A,0x4A,0x4A,0x4A,0x4A,0x4A,0x7A,0x02,0x82,0xFF,0x02,0x00,
/*6*/
0x00,0xF8,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xFC,0x08,0x00,0x00,0x00,
0x00,0x07,0x02,0x02,0x02,0x02,0x3F,0x42,0x42,0x42,0x42,0x47,0x40,0x70,0x00,0x00,
/*7*/
0x40,0x20,0x58,0x47,0x54,0x54,0x54,0x54,0x54,0x54,0xD4,0x14,0x06,0x04,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x40,0x80,0x70,0x00,
/*8*/
0x40,0x40,0x42,0xCC,0x00,0x40,0xA0,0x9F,0x81,0x81,0x81,0x9F,0xA0,0x20,0x20,0x00,
0x00,0x00,0x00,0x7F,0xA0,0x90,0x40,0x43,0x2C,0x10,0x28,0x26,0x41,0xC0,0x40,0x00,
/*9*/
0x00,0x00,0x90,0x88,0x44,0x4B,0x32,0x12,0x32,0x4A,0x46,0x82,0x80,0x80,0x80,0x00,
0x01,0x01,0x00,0xFF,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0xFF,0x00,0x01,0x00,0x00,
/*10*/
0x04,0x04,0x04,0x84,0xE4,0x3C,0x27,0x24,0x24,0x24,0x24,0xF4,0x24,0x06,0x04,0x00,
0x04,0x02,0x01,0x00,0xFF,0x09,0x09,0x09,0x09,0x49,0x89,0x7F,0x00,0x00,0x00,0x00,
/*11*/
0x00,0xFE,0x02,0x22,0xDA,0x06,0x00,0xFE,0x92,0x92,0x92,0x92,0xFF,0x02,0x00,0x00,
0x00,0xFF,0x08,0x10,0x08,0x07,0x00,0xFF,0x42,0x24,0x08,0x14,0x22,0x61,0x20,0x00,
/*12*/
0x00,0x00,0x80,0x40,0x30,0x0C,0x00,0xC0,0x06,0x18,0x20,0x40,0x80,0x80,0x80,0x00,
0x01,0x01,0x00,0x30,0x28,0x24,0x23,0x20,0x20,0x28,0x30,0x60,0x00,0x01,0x00,0x00,
/*13*/
0x10,0x10,0x92,0x92,0x92,0x92,0x92,0x92,0xD2,0x9A,0x12,0x02,0xFF,0x02,0x00,0x00,
0x00,0x00,0x3F,0x10,0x10,0x10,0x10,0x10,0x3F,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,
/*14*/
0x00,0x10,0x17,0xD5,0x55,0x57,0x55,0x7D,0x55,0x57,0x55,0xD5,0x17,0x10,0x00,0x00,
0x40,0x40,0x40,0x7F,0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x7F,0x40,0x60,0x40,0x00,
/*15*/
/*16*/
0x10,0x22,0x64,0x0C,0x80,0x44,0x44,0x64,0x55,0x4E,0x44,0x54,0x66,0xC4,0x00,0x00,
0x04,0x04,0xFE,0x01,0x00,0x80,0x40,0x3F,0x00,0xFF,0x00,0x3F,0x40,0x40,0x70,0x00,
/*17*/
0x00,0xFC,0x84,0x84,0x84,0xFE,0x14,0x10,0x90,0x10,0x10,0x10,0xFF,0x10,0x10,0x00,
0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x23,0x40,0x80,0x7F,0x00,0x00,0x00,
/*18*/
0x00,0xF8,0x01,0x02,0xF6,0x10,0x12,0x12,0x12,0x12,0xFA,0x12,0x02,0xFF,0x02,0x00,
0x00,0xFF,0x00,0x00,0x3F,0x11,0x11,0x11,0x11,0x11,0x3F,0x40,0x80,0x7F,0x00,0x00,
/*19*/
0x10,0x22,0x64,0x0C,0x80,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFF,0x02,0x00,0x00,
0x04,0x04,0xFE,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00,
/*20*/
0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0xA5,0xA6,0xA4,0xFC,0x24,0x34,0x26,0x04,0x00,
0x40,0x20,0x9F,0x80,0x42,0x42,0x26,0x2A,0x12,0x2A,0x26,0x42,0x40,0xC0,0x40,0x00,
/*21*/
0x04,0x84,0xE4,0x5C,0x44,0xC4,0x20,0x10,0xE8,0x27,0x24,0xE4,0x34,0x2C,0xE0,0x00,
0x02,0x01,0x7F,0x10,0x10,0x3F,0x80,0x60,0x1F,0x09,0x09,0x3F,0x49,0x89,0x7F,0x00,
/*22*/
0x10,0x0C,0x44,0x44,0x44,0x44,0x45,0xC6,0x44,0x44,0x44,0x44,0x44,0x14,0x0C,0x00,
0x80,0x40,0x20,0x1E,0x20,0x40,0x40,0x7F,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00,
/*23*/
0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x24,0xA4,0x24,0x22,0x22,0xA3,0x62,0x00,0x00,
0x00,0x40,0x20,0x1F,0x20,0x58,0x47,0x50,0x48,0x45,0x42,0x45,0x48,0x50,0x40,0x00,
/*24*/
0x00,0x00,0xFE,0x02,0x02,0xF2,0x12,0x12,0x12,0xF2,0x02,0x02,0xFE,0x00,0x00,0x00,
0x00,0x00,0x7F,0x20,0x20,0x27,0x24,0x24,0x24,0x27,0x20,0x20,0x7F,0x00,0x00,0x00,
/*25*/
0x00,0x82,0x82,0xBA,0xAA,0xAA,0xAA,0xAB,0xAA,0xAA,0xAA,0xBA,0x82,0x82,0x80,0x00,
0x02,0x41,0x54,0x54,0x54,0x54,0x7C,0xAA,0xAA,0xAA,0xAA,0xAA,0xA0,0x82,0xE1,0x00,
/*26*/
0x24,0x24,0xA4,0xFE,0x23,0x22,0x00,0xC0,0x38,0x00,0xFF,0x00,0x08,0x10,0x60,0x00,
0x08,0x06,0x01,0xFF,0x01,0x06,0x81,0x80,0x40,0x40,0x27,0x10,0x0C,0x03,0x00,0x00,
/*27℃*/
0x06,0x09,0x09,0xE6,0xF8,0x0C,0x04,0x02,0x02,0x02,0x02,0x02,0x04,0x1E,0x00,0x00,
0x00,0x00,0x00,0x07,0x1F,0x30,0x20,0x40,0x40,0x40,0x40,0x40,0x20,0x10,0x00,0x00,
/*28*/
0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x8C,0x9C,0xB8,0xF0,0xE0,0xC0,0x80,0x00,0x00,
0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x31,0x39,0x1D,0x0F,0x07,0x03,0x01,0x00,0x00,
顯示期望如下:(“口”為空白)
口一二三四五六口
七八九十壹貳叁肆
實(shí)際顯示如下:
口一二三四五六口
七八口口一口一二
各位大神有沒有知道為什么的?謝謝!
ID:325966 發(fā)表于 2018-6-11 15:23 | 只看該作者
都說了無字庫,自己不會(huì)添加一下嗎
ID:349541 發(fā)表于 2018-6-11 15:52 | 只看該作者
就是字庫的問題?
ID:349564 發(fā)表于 2018-6-11 17:40 | 只看該作者
字庫的問題,自己重新添加一下
ID:349564 發(fā)表于 2018-6-11 17:41 | 只看該作者
字庫的問題,自己重新添加一下
ID:272158 發(fā)表于 2018-6-11 18:47 | 只看該作者
你取模的字體有出錯(cuò),定義位置也不對
ID:349753 發(fā)表于 2018-6-11 20:07 | 只看該作者
可以百度一下
ID:296837 發(fā)表于 2018-6-29 08:57 | 只看該作者
ARM學(xué)習(xí)能手 發(fā)表于 2018-6-11 15:23
無字庫  你沒看到后面有字庫嗎?
ID:296837 發(fā)表于 2018-6-29 08:59 | 只看該作者
feixue2007 發(fā)表于 2018-6-11 18:47
怎么不對了?大概的說一下,,,,,前面幾個(gè)都是混經(jīng)驗(yàn)的,就您這里有可能知道原因
百度過,謝謝。
