查看: 7603|回復: 4
博通B50610引腳圖與pdf規格書資料下載
ID:349170 發表于 2018-6-11 08:54 | 顯示全部樓層 |閱讀模式
千兆網口芯片B50610規格書,在網上下不了的,無私奉獻出來給大家
B50610引腳圖:
GENERAL DESCRIPTION
The Broadcom® B50610 is a triple-speed 1000BASE-T/
100BASE-TX/10BASE-T Gigabit Ethernet (GbE)
transceiver integrated into a single monolithic CMOS chip.
The device performs all physical-layer functions for
1000BASE-T, 100BASE-TX, and 10BASE-T Ethernet on
standard category 5 UTP cable. 10BASE-T can also run
on standard category 3, 4, and 5 UTP. The B50610 is a
highly integrated solution combining digital adaptive
equalizers, ADCs, phase-locked loops, line drivers,
encoders, decoders, echo cancellers, crosstalk
cancellers, and all required support circuitry. Based on
Broadcom’s proven Digital Signal Processor technology,
the B50610 is designed to be fully compliant with RGMII,
allowing compatibility with industry-standard Ethernet
MACs and switch controllers.
Designed for reliable operation over worst-case
category 5 cable, the B50610 automatically negotiates
with its link partner to determine the highest possible
operating speed. The device detects and corrects most
common wiring problems. The B50610 features
CableChecker™ diagnostics, which detects common
cable problems including shorts, opens, and cable length.
完整的pdf格式文檔51黑下載地址:
B50610-DS07-RDS.pdf (1.89 MB, 下載次數: 56)
ID:437947 發表于 2018-12-2 21:12 | 顯示全部樓層
謝謝分享
ID:439893 發表于 2018-12-5 11:37 | 顯示全部樓層
謝謝分享~~
ID:617297 發表于 2019-9-27 17:25 | 顯示全部樓層
謝謝拉
ID:669183 發表于 2019-12-20 14:50 | 顯示全部樓層
新到的開發板有B50610PHY芯片,搜了半天終于找到datasheet了,感謝樓主無私奉獻
