查看: 1868|回復: 0
c8051f020的spi通信代碼
ID:348051 發表于 2018-6-9 10:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
// Program Description:
// This program configures a C8051F02x as a 4-wire SPI Single Master.
// The SPI clock in this example is limited to 320 kHz when used with the
// SPI0_Slave code example.  During a SPI_Read, the slave needs some time to
// interpret the command and write the appropriate data to the SPI0DAT
// register, and the slave no longer has enough time to complete the
// SPI_READ_BUFFER command with a clock greater than 320 kHz.  For faster SPI
// clocks, a dummy byte between the command and the first byte of Read data
// will be required.
// This example is intended to be used with the SPI0_Slave example.
// Pinout:
// P0.0 - SPI SCK    (digital output, push-pull)
// P0.1 - SPI MISO   (digital input, open-drain)
// P0.2 - SPI MOSI   (digital output, push-pull)
// P0.3 - SPI NSS    (digital input, open-drain)
// P0.7 - SLAVE_SEL  (digital output, push-pull) This pin should be routed
//        to NSS on the slave
// P1.6 - LED        (digital output, push-pull)
// all other port pins unused.
// How To Test:
// 1) Download the code to a F020-TB that is connected as above to
//    another device running the SPI0_Slave code.
// 2) Verify that the J3 jumper is populated.
// 3) Run the code.
// 4) If the communication passes, the LEDs on both the Master and Slave
//    boards will blink slowly. If it fails, the LEDs will be OFF.
// Target:         C8051F02x
// Tool chain:     Keil C51 7.50 / Keil EVAL C51
// Command Line:   None
// Release 1.0
//    -Initial Revision (TP)
//    -14 DEC 2006
// Includes
#include <C8051F040.h>                 // SFR declarations
// Global Constants
#define SYSCLK             16000000    // Internal oscillator frequency in Hz
#define SPI_CLOCK          320000      // Maximum SPI clock
                                       // The SPI clock is a maximum of 320 kHz
                                       // when this example is used with
                                       // the SPI0_Slave code example.
#define MAX_BUFFER_SIZE    8           // Maximum buffer Master will send
// Instruction Set
#define  SLAVE_LED_ON      0x01        // Turn the Slave LED on
#define  SLAVE_LED_OFF     0x02        // Turn the Slave LED off
#define  SPI_WRITE         0x04        // Send a byte from the Master to the
                                       // Slave
#define  SPI_READ          0x08        // Send a byte from the Slave to the
                                       // Master
#define  SPI_WRITE_BUFFER  0x10        // Send a series of bytes from the
                                       // Master to the Slave
#define  SPI_READ_BUFFER   0x20        // Send a series of bytes from the Slave
                                       // to the Master
#define  ERROR_OCCURRED    0x40        // Indicator for the Slave to tell the
                                       // Master an error occurred
sbit LED = P1^6;                       // LED='1' means ON
sbit SLAVE_SEL = P0^7;                 // Slave select pin (NSS)
// Global Variables
unsigned char SPI_Data = 0xA5;
unsigned char SPI_Data_Array[MAX_BUFFER_SIZE] = {0};
bit Error_Flag = 0;
unsigned char Command = 0x00;
bit Transfer_In_Progress = 0;
// Function Prototypes
void Watchdog_Init (void);
void Oscillator_Init (void);
void Port_Init (void);
void SPI0_Init (void);
void Init_Device (void);
void SPI_LED_On (void);
void SPI_LED_Off (void);
void SPI_Byte_Write (void);
void SPI_Byte_Read (void);
void SPI_Array_Write (void);
void SPI_Array_Read (void);
void Delay (void);
void Short_Delay (void);
// main() Routine
void main (void)
   unsigned char test_value = 0x55;
   unsigned char test_array[MAX_BUFFER_SIZE] = {1,2,3,4,5,6,7,8};
   unsigned char i;
   Init_Device ();                     // Initializes hardware peripherals
   EA = 1;                             // Enable global interrupts
   LED = 0;
   // TEST BEGIN --------------------------------------------------------------
   SPI_Data = test_value;
   // Write a value
   SPI_Byte_Write ();
   while (Transfer_In_Progress);       // Wait until the Write transfer has
                                       // finished
   // Read the same value back
   SPI_Data = 0x00;
   SPI_Byte_Read ();
                                       // finished
   // Check if the sent value and returned value match
   if (SPI_Data != test_value)
      Error_Flag = 1;
   // Copy test_array into SPI_Data_Array
   for (i = 0; i < MAX_BUFFER_SIZE; i++)
      SPI_Data_Array[i] = test_array[i];
   // Send the array to the slave
   SPI_Array_Write ();
                                       // finished
   // Clear SPI_Data_Array for the SPI_Buffer_Read function
      SPI_Data_Array[i] = 0;
   // Read the array back from the slave
   SPI_Array_Read ();
                                       // finished
   // Check if the received array matches the sent array
      if (SPI_Data_Array[i] != test_array[i])
         Error_Flag = 1;
   // END OF TEST -------------------------------------------------------------
   while (1)
      // If no error has occurred, blink the LEDs on the Master and Slave
      // boards
      if (Error_Flag == 0)
         LED = 1;
         SPI_LED_On ();
                                       // finished
         Delay ();
         SPI_LED_Off ();
         LED = 0;
                                       // finished
         Delay ();
// Initialization Subroutines
// Watchdog_Init
// Return Value : None
// Parameters   : None
// This function disables the watchdog timer.
   WDTCN     = 0xDE;                   // Disable the Watchdog Timer
   WDTCN     = 0xAD;
// Oscillator_Init
// This function initializes the system clock to use the internal oscillator
// at 16 MHz.
   OSCICN = 0x07;                      // Set the internal oscillator to
                                       // 16 MHz
// Port_Init
// This function configures the crossbar and GPIO ports.
// P0.0  -  SCK  (SPI0), Push-Pull,  Digital
// P0.1  -  MISO (SPI0), Open-Drain, Digital
// P0.2  -  MOSI (SPI0), Push-Pull,  Digital
// P0.3  -  NSS  (SPI0), Open-Drain, Digital
// P0.7  -  SLAVE_SEL,   Push-Pull,  Digital
// P1.6  -  LED,         Push-Pull,  Digital (LED D3 on Target Board)
void PORT_Init (void)
   P0MDOUT = 0x85;                     // Make SCK, MOSI, and SLAVE_SEL
                                       // push-pull
   P1MDOUT = 0x40;                     // Make the LED push-pull
   XBR0 = 0x02;                        // Enable the SPI on the XBAR
   XBR2 = 0x40;                        // Enable the XBAR and weak pull-ups
// SPI0_Init
// Configures SPI0 to use 4-wire Single Master mode. The SPI timing is
// configured for Mode 0,0 (data centered on first edge of clock phase and
// SCK line low in idle state).
void SPI0_Init()
   SPI0CFG   = 0x07;                   // CKPHA = '0', CKPOL = '0'
                                       // SPI transmits 8 bits
   SPI0CN    = 0x03;                   // Master, SPI enabled
   // SPI clock frequency equation from the datasheet
   SPI0CKR   = (SYSCLK/(2*SPI_CLOCK))-1;
   EIE1 |= 0x01;                       // Enable SPI interrupts
   SLAVE_SEL = 1;                      // De-select the slave
// Init_Device
// Calls all device initialization functions.
   Watchdog_Init ();                   // Disable the Watchdog Timer first
   Oscillator_Init ();
   Port_Init ();
   SPI0_Init ();
// Interrupt Service Routines
// SPI_ISR
// Handles all error checks and single-byte writes.
// Note: SPI_WRITE_ARRAY is not handled by this ISR in order to take
// advantage of double-buffering (checking the TXBMT flag) using polling.
// Typical Write:
//              | 1st sent | 2nd sent | 3rd sent |   ...    | last sent |
//  Master NSSv | Command  |   Data1  |   Data2  |   ...    |   DataN   |  NSS^
//  Slave       |   N/A    |    N/A   |    N/A   |   ...    |    N/A    |
// Typical Read:
//  Master NSSv | Command  |   dummy  |   dummy  |   ...    |   dummy   |  NSS^
//  Slave       |   N/A    |   Data1  |   Data2  |   ...    |   DataN   |
void SPI_ISR (void) interrupt 6
   static unsigned char array_index = 0;
   static char state = 0;
   if (WCOL == 1)
      // Write collision occurred
      WCOL = 0;                        // Clear the write collision flag
      Error_Flag = 1;
      // SPIF is set when the Master has finished the transfer, but the Slave
      // is not necessarily ready to continue the sequence.
      SLAVE_SEL = 1;                   // De-select the slave so it can
                                       // process the last transfer
      Short_Delay();                   // All the slave a little time to
      if (SPI0DAT == ERROR_OCCURRED)
         // This example recognizes when an error occurs, but does not include
         // any error handling.  The transfer can be aborted or rescheduled,
         // if desired.
         Error_Flag = 1;
      // When the Master first enters the ISR, the SPIF flag should be set from
      // sending the Command byte.  This ISR handles the remaining steps of the
      // SPI transfer process.
      // <state> == 0: writing or reading 1 byte of data
      // <state> == 1: for READ commands (first time, only a dummy byte is
      //               sent but the second time, the data must be read from
      //               SPI0DAT)
      // <state> == 2: NSS = 1 to end the transfer, final byte read
      if (state == 0)
         switch (Command)
            case SLAVE_LED_ON:
            case SLAVE_LED_OFF:
               // Not expecting any data back
               Transfer_In_Progress = 0; // Allow a new transfer to begin
               break;
            case SPI_WRITE:
               SLAVE_SEL = 0;          // Reselect the slave
               SPI0DAT = SPI_Data;
               state = 2;              // Advance to the final state (only
                                       // writing one byte)
               break;
            case SPI_READ:
               SPI0DAT = 0xFF;         // Send a dummy byte so the Slave can
                                       // send the data
                                       // reading one byte)
               break;
            case SPI_WRITE_BUFFER:
               array_index = 0;        // Clear the data counter
               SPI0DAT = SPI_Data_Array[array_index]; // Write the bytes in
                                       // the array to the Slave
               array_index++;
               state = 1;
               break;
            case SPI_READ_BUFFER:
                                       // start sending the data
               state = 1;              // Advance to the next state where the
                                       // data can be received
                                       // The data from the slave is not
                                       // available until after the second
                                       // transfer is completed.
                                       // The dummy byte allows the slave to
                                       // send data, since the Master controls
                                       // SCK.
               break;
            default:
               state = 2;              // Any errors in the Command parsing
                                       // should go to state 2 where NSSMD0
                                       // is de-asserted
      else if (state == 1)             // This state is for ARRAY
      {                                // commands.
                                       // For READ_ARRAY, the data must be read
                                       // after the first dummy byte is sent.
                                       // For WRITE_ARRAY, the data counter
                                       // must be cleared before sending the
                                       // first byte.
         switch (Command)
               array_index++;
               if (array_index == MAX_BUFFER_SIZE)
                  state = 2;           // Advance to the final state when
                                       // all bytes are written
               break;
               SPI_Data_Array[array_index] = SPI0DAT;
               SPI0DAT = 0xFF;
               array_index++;
               if (array_index == (MAX_BUFFER_SIZE-1))
                  state = 2;
               break;
            default:
                                       // is de-asserted
      else if (state == 2)
         switch (Command)
            case SPI_READ:
               SPI_Data = SPI0DAT;     // Read the data from the slave
               break;
               SPI_Data_Array[array_index] = SPI0DAT; // Read the last data
                                                      // without sending a
                                                      // dummy byte
               break;
         state = 0;                    // Reset the state
      SPIF = 0;                        // Clear the SPIF flag
// Support Routines
// SPI_LED_On
// Turns the LED on the SPI Slave on.  The slave does not respond to this
// command, so the command consists of:
// Command = SLAVE_LED_ON
// Length = 1 byte (the command itself)
   while (Transfer_In_Progress);       // Wait until the SPI is free, in case
                                       // it's already busy
   Transfer_In_Progress = 1;           // Indicate a transfer is ongoing
   SLAVE_SEL = 0;                      // Select the slave
   Command = SLAVE_LED_ON;
   SPI0DAT = Command;
   // The rest of this command will be handled by the SPI ISR, which will
   // trigger when SPIF is set from sending the Command
// SPI_LED_Off
// Turns the LED on the SPI Slave off.  The slave does not respond to this
// Command = SLAVE_LED_OFF
   Command = SLAVE_LED_OFF;
   SPI0DAT = Command;
// SPI_Byte_Write
// Note: SPI_Data must contain the data to be sent before calling this
// function.
// Writes a single byte to the SPI Slave.  The slave does not respond to this
// Command = SPI_WRITE
// Length = 1 byte of command, 1 byte of data
   Command = SPI_WRITE;
   SPI0DAT = Command;
// SPI_Byte_Read
// Note: SPI_Data will contain the data received after calling this function.
// Reads a single byte from the SPI Slave.  The command consists of:
// Command = SPI_READ
   Command = SPI_READ;
   SPI0DAT = Command;
// SPI_Array_Write
// Note: SPI_Data_Array must contain the data to be sent before calling this
// function.
// Writes an array of values of size MAX_BUFFER_SIZE to the SPI Slave.  The
// command consists of:
// Command = SPI_WRITE_BUFFER
// Length = 1 byte of command, MAX_BUFFER_SIZE bytes of data
   Command = SPI_WRITE_BUFFER;
   SPI0DAT = Command;
// SPI_Array_Read
// Note: SPI_Data_Array will contain the data received after calling this
// function.
// Command = SPI_READ_BUFFER
   Command = SPI_READ_BUFFER;
   SPI0DAT = Command;
// Delay
// Delay for little while (used for blinking the LEDs)
void Delay (void)
   unsigned long count;
   for (count = 200000; count > 0; count--);
// Short_Delay
// Delay for little while (used between transfers with the Slave)
   unsigned char count;
   for (count = 200; count > 0; count--);
// End Of File
