為了獲得一點(diǎn)黑幣,好下載,也是不擇手段了!
IDE-Version:
μVision V4
下載方式
·SWD JTAG
程序功能
·STM32 USB鼠標(biāo)實(shí)驗(yàn)
硬件連接
·將USB插到開發(fā)板上
實(shí)驗(yàn)現(xiàn)象
·可以使用KEY來控制電腦的鼠標(biāo)的方向
單片機(jī)源程序如下:
- * File : main.c
- * Hardware Environment:
- * Build Environment : RealView MDK-ARM Version: 4.32
- * Version : V1.0
- * By : mao
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- #include "usb_lib.h"
- #include "hw_config.h"
- #include "usb_pwr.h"
- #include "usart1.h"
- #include "Data.h"
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- /* Private function prototypes -----------------------------------------------*/
- u8 MsgCmd;
- void Delay (uint32_t nCount);
- void USB_SendString(u8 *str) //
- u8 ii=0;
- while(*str)
- Transi_Buffer[ii++]=*(str++);
- if (ii ==22) break;
- UserToPMABufferCopy(Transi_Buffer, ENDP2_TXADDR, 22);
- _SetEPTxStatus(ENDP2, EP_TX_VALID);
- * Function Name : main
- * Description : Main program
- * Input : None
- * Output : None
- * Return : None
- * Attention : None
- int main(void)
- Set_System();
- USB_Interrupts_Config();
- Set_USBClock();
- USB_Init();
- /* USART1 config 115200 8-N-1 */
- USART1_Config();
- NVIC_USART1_Configuration();
- MsgCmd=0;
- while (1)
- if(MsgCmd) //當(dāng)上位機(jī)發(fā)送數(shù)據(jù)以后,對(duì)MsgCmd置1
- Delay(50000); //沒有這個(gè)延時(shí),會(huì)少部分?jǐn)?shù)據(jù)?為什么?
- // while(EP_RX_NAK!=GetEPRxStatus(ENDP1));
- printf("\r\n進(jìn)入主函數(shù)");
- GET_CMD();
- * Function Name : Delay
- * Description : Delay Time
- * Input : - nCount: Delay Time
- * Output : None
- * Return : None
- for(; nCount != 0; nCount--)
- * Function Name : GPIO_Configuration
- * Description : Configure GPIO Pin
- * Input : None
- * Output : None
- * Return : None
- //void GPIO_Configuration(void)
- // GPIO_InitTypeDef GPIO_InitStructure;
- // RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB , ENABLE);
- // * LED1 -> PB15 , LED2 -> PB14 , LED3 -> PB13 , LED4 -> PB12
- // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
- // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- // GPIO_Init(GPIOB, &GPIO_InitStructure);
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- END FILE
usb下位機(jī)1(上位機(jī)發(fā),下位機(jī)收).rar
(407.71 KB, 下載次數(shù): 36)
2018-6-9 03:45 上傳
點(diǎn)擊文件名下載附件
