只需一步,快速開(kāi)始
查看: 2222|回復(fù): 0
STM32超聲波測(cè)距程序
ID:338925 發(fā)表于 2018-6-5 21:26 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include "timer.h"
  2. #include "usart.h"
  3. #include "sys.h"
  4. void TIM4_Cap_Init(u16 arr,u16 psc)
  5. {
  6.         GPIO_InitTypeDef        GPIO_InitStructure;
  7.         TIM_ICInitTypeDef  TIM4_ICInitStructure;
  8.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  9.         NVIC_InitTypeDef NVIC_InitStructure;
  10.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);        //使能TIM4時(shí)鐘
  11.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);  //使能GPIOB時(shí)鐘
  12.
  13.         /*TRIG觸發(fā)信號(hào)*/
  14.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  15.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;                //推挽輸出
  16.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8;
  17.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  18.         GPIO_ResetBits(GPIOB,GPIO_Pin_8);
  19.
  20.         /*ECOH回響信號(hào)*/
  21.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;                //浮空輸入
  22.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;
  23.         GPIO_Init(GPIOB, & GPIO_InitStructure);
  24.         GPIO_ResetBits(GPIOB,GPIO_Pin_9);
  25.         //初始化定時(shí)器4 TIM4
  26.         TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)定計(jì)數(shù)器自動(dòng)重裝值
  27.         TIM_TimeBaseStructure.TIM_Prescaler =psc;         //預(yù)分頻器
  28.         TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //不分頻
  29.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
  30.         TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
  31.
  32.         //初始化TIM4輸入捕獲參數(shù)
  33.         TIM4_ICInitStructure.TIM_Channel = TIM_Channel_4; //CC4S=01         選擇輸入端 IC4映射到TI4上
  34.   TIM4_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;        //上升沿捕獲
  35.   TIM4_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI4上
  36.   TIM4_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;         //配置輸入分頻,不分頻
  37.   TIM4_ICInitStructure.TIM_ICFilter = 0x03;//IC4F=0000 配置輸入濾波器 不濾波
  38.   TIM_ICInit(TIM4, &TIM4_ICInitStructure);
  39.
  40.         //中斷分組初始化
  41.         NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;  //TIM4中斷
  42.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占優(yōu)先級(jí)0級(jí)
  43.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;  //從優(yōu)先級(jí)0級(jí)
  44.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
  45.         NVIC_Init(&NVIC_InitStructure);  //根據(jù)NVIC_InitStruct中指定的參數(shù)初始化外設(shè)NVIC寄存器
  46.
  47.         TIM_ITConfig(TIM4,TIM_IT_Update|TIM_IT_CC4,ENABLE);//允許更新中斷 ,允許CC4IE捕獲中斷
  48.
  49.   TIM_Cmd(TIM4,ENABLE);
  50. }
  51. u8  TIM4CH4_CAPTURE_STA=0;        //輸入捕獲狀態(tài)
  52. u16        TIM4CH4_CAPTURE_VAL;        //輸入捕獲值-----用來(lái)記錄捕獲到下降沿的時(shí)候 TIM4 _CNT的值
  53. //定時(shí)器4中斷服務(wù)程序
  54. void TIM4_IRQHandler(void)
  55. {
  56.         if((TIM4CH4_CAPTURE_STA&0X80)==0)//還未成功捕獲
  57.         {
  58.                 if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
  59.
  60.                 {
  61.                         if(TIM4CH4_CAPTURE_STA&0X40)//已經(jīng)捕獲到高電平了
  62.                         {
  63.                                 if((TIM4CH4_CAPTURE_STA&0X3F)==0X3F)//高電平太長(zhǎng)了
  64.                                 {
  65.                                         TIM4CH4_CAPTURE_STA|=0X80;//標(biāo)記成功捕獲了一次
  66.                                         TIM4CH4_CAPTURE_VAL=0XFFFF;
  67.                                 }else TIM4CH4_CAPTURE_STA++;
  68.                         }
  69.                 }
  70.         if (TIM_GetITStatus(TIM4, TIM_IT_CC4) != RESET)//捕獲4發(fā)生捕獲事件
  71.                 {
  72.                         if(TIM4CH4_CAPTURE_STA&0X40)                //捕獲到一個(gè)下降沿
  73.                         {
  74.                                 TIM4CH4_CAPTURE_STA|=0X80;                //標(biāo)記成功捕獲到一次上升沿
  75.                                 TIM4CH4_CAPTURE_VAL=TIM_GetCapture4(TIM4);
  76.                            TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Rising); //CC4P=0 設(shè)置為上升沿捕獲
  77.                         }else        //還未開(kāi)始,第一次捕獲上升沿
  78.                         {
  79.                                 TIM4CH4_CAPTURE_STA=0;                        //清空
  80.                                 TIM4CH4_CAPTURE_VAL=0;
  81.                                  TIM_SetCounter(TIM4,0);
  82.                                 TIM4CH4_CAPTURE_STA|=0X40;                //標(biāo)記捕獲到了上升沿
  83.                            TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Falling);                //CC4P=1 設(shè)置為下降沿捕獲
  84.                         }
  85.                 }
  86.         }
  87.     TIM_ClearITPendingBit(TIM4, TIM_IT_CC4|TIM_IT_Update); //清除中斷標(biāo)志位
  88. }
