查看: 3130|回復: 1
別人寫的上位機調PID,單片機下位機程序,如何整合到自己的程序,只改UARTMA嗎?
ID:296924 發表于 2018-6-4 23:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
* wave.h
*  Created on: Nov 29, 2014
*      Author: ass
#ifndef WAVE_H_
#define WAVE_H_
#include "uart.h"
void Uart1_Send_AF(signed int aa,signed int bb,signed int cc,signed int dd,signed int ee,signed int ff,signed int gg,signed int hh);
unsigned char UART_Putc(unsigned char data);
void send_wave(void);
void printhh(void);
void print5n(unsigned int x);
void print4n(unsigned int x);
void print3n(unsigned int x);
void print2n(unsigned int x);
#endif /* WAVE_H_ */
#include "wave.h"
#include "uart.h"
#define tx_num        32
unsigned char TxBuffer[tx_num];
unsigned char count=0;
#define BYTE0(dwTemp)       (*(char *)(&dwTemp))
#define BYTE1(dwTemp)       (*((char *)(&dwTemp) + 1))
#define BYTE2(dwTemp)       (*((char *)(&dwTemp) + 2))
#define BYTE3(dwTemp)       (*((char *)(&dwTemp) + 3))
/**************************向物理串口發一個字節***************************************
__inline unsigned char UART_Putc(unsigned char data)                        //
        uart_send1(UART_1,data);
        return data;
unsigned char Uart1_Put_Char(unsigned char DataToSend)
        TxBuffer[count++] = DataToSend;
        return DataToSend;
unsigned char Uart1_Put_Int16(uint16_t DataToSend)
        unsigned char sum = 0;
        TxBuffer[count++] = BYTE1(DataToSend);
        TxBuffer[count++] = BYTE0(DataToSend);
        sum += BYTE1(DataToSend);
        sum += BYTE0(DataToSend);
        return sum;
        count=0;
        sum += Uart1_Put_Char(0x88);
        sum += Uart1_Put_Char(0xAF);
        sum += Uart1_Put_Char(0x1C);
        sum += Uart1_Put_Char(BYTE1(aa));//1
        sum += Uart1_Put_Char(BYTE0(aa));
        sum += Uart1_Put_Char(BYTE1(bb));//2
        sum += Uart1_Put_Char(BYTE0(bb));
        sum += Uart1_Put_Char(BYTE1(cc));//3
        sum += Uart1_Put_Char(BYTE0(cc));
        sum += Uart1_Put_Char(BYTE1(dd));//4
        sum += Uart1_Put_Char(BYTE0(dd));
        sum += Uart1_Put_Char(BYTE1(ee));//5
        sum += Uart1_Put_Char(BYTE0(ee));
        sum += Uart1_Put_Char(BYTE1(ff));//6
        sum += Uart1_Put_Char(BYTE0(ff));
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        sum += Uart1_Put_Char(BYTE1(gg));//7,4500->45'//這是姿態!!!
        sum += Uart1_Put_Char(BYTE0(gg));
        sum += Uart1_Put_Char(BYTE1(hh));//8
        sum += Uart1_Put_Char(BYTE0(hh));
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(0);
        Uart1_Put_Char(sum);
        char count_1=0;
        while(count_1<tx_num)
      UART_Putc(TxBuffer[count_1++]);
void printhh(void)
        UART_Putc(0x0d);                                //output'CR'
        UART_Putc(0x0A);                                //output'CR'
           UART_Putc((x/10000)+0x30);           //計算萬位數字
           UART_Putc(((x%10000)/1000)+0x30);    //計算千位數字
           UART_Putc(((x%1000)/100)+0x30);      //計算百位數字
           UART_Putc(((x%100)/10)+0x30);        //計算十位數字
           UART_Putc((x%10)+0x30);              //計算個位數字
          UART_Putc((x/1000)+0x30);    //計算千位數字
        UART_Putc((x/100)+0x30);      //計算百位數字
        UART_Putc((x/10)+0x30);        //計算十位數字
這好像是別人寫的下位機程序,但是我不知道怎么整合到自己的程序里想調PID,是只要改UARTMA嗎?具體的怎么改?望大佬不吝賜教。
ID:318095 發表于 2018-6-5 09:22 | 只看該作者
上位機一般都是用c++寫的 ,單片機程序一般用c語言或匯編。 你這個程序沒有主函數也不是匯編語言,看著不像是下位機用的。
