查看: 1263|回復: 0
Arduino光控燈
ID:266867 發表于 2018-6-4 19:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
int led = 11;
int photocellPin=14;
int brightness = 0;
int fadeAmount = 50;
void setup() {
pinMode(led, OUTPUT);
void loop() {
int val=analogRead(photocellPin);
analogWrite(led,val);
brightness = brightness + fadeAmount;
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
