查看: 3796|回復: 0
按鍵控制數碼管加減演示
ID:165487 發表于 2018-6-4 10:01 | 顯示全部樓層 |閱讀模式
   #include<reg51.h>
#include<intrins.h>
//段碼
uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
//待顯示的3位緩沖
uchar Num_Buffer[]={0,0,0};
//按鍵代碼,按鍵計數
uchar Key_Code,Key_Counts=0;
//延時
void DelayMS(uint x)
        uchar i;
        while(x--) for(i=0;i<120;i++);
//顯示函數
void Show_Counts_ON_DSY()
        uchar i,j=0x01;
        Num_Buffer[2]=Key_Counts/100;
        Num_Buffer[1]=Key_Counts/10%10;
        Num_Buffer[0]=Key_Counts%10;
        for(i=0;i<3;i++)
                j=_cror_(j,1);
                P0=0xff;
                P0=DSY_CODE[Num_Buffer[i]];
                P2=j;
                DelayMS(1);
//主程序
        uchar i;
        P0=0xff;
        P1=0xff;
        P2=0x00;
        Key_Code=0xff;
                Show_Counts_ON_DSY();
                P1=0xff;
                Key_Code=P1;
                //有鍵按下時,數碼管刷新顯示30次,該行代碼同時起到延時作用
                if(Key_Code!=0xff)
                for(i=0;i<30;i++) Show_Counts_ON_DSY();
                switch(Key_Code)
                        case 0xfe:        if(Key_Counts<255) Key_Counts++;
                                                break;
                        case 0xfd:        if(Key_Counts>0) Key_Counts--;
                                                break;
                        case 0xfb:        Key_Counts=0;
                Key_Code=0xff;
