查看: 5249|回復: 12
12684顯示問題
ID:318113 發表于 2018-6-3 21:29 | 顯示全部樓層 |閱讀模式
這個怎么回事
ID:7485 發表于 2018-6-4 08:53 | 顯示全部樓層
就給一個這樣的圖,弄不清楚是怎么回事。你的程序呢?一般這樣的情況應該是程序的問題。
ID:325966 發表于 2018-6-4 09:21 | 顯示全部樓層
開始沒設置好,另外你用的是帶字庫還是不帶字庫的液晶屏。你是程序問題,可以進仿真一步步調,不難。
ID:318113 發表于 2018-6-4 11:09 | 顯示全部樓層
ahshmj 發表于 2018-6-4 08:53
#include <reg51.h>
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add     0xb8//頁地址
#define LCDCol_Add     0x40//列地址
#define Start_Line     0xC0//行地址
/*****液晶顯示器的端口定義*****/
#define data_ora P0 /*液晶數據總線*/
sbit LCDMcs=P2^4 ;    /*片選1*/
sbit LCDScs=P2^3 ;    /*片選2*/
sbit LCDDi=P2^0 ;     /*數據/指令 選擇*/
sbit LCDRW=P2^1 ;     /*讀/寫 選擇*/
sbit LCDEnable=P2^2 ;     /*讀/寫 使能*/
unsigned char code Bmp1[]=
  源文件 / 文字 : 來自剪貼板!武漢理工大學
  寬×高(像素): 128×16
  字模格式/大小 : 單色點陣液晶字模,縱向取模,字節倒序/256字節
  數據轉換日期  : 2010-7-29 17:52:57
  顯示的漢字:武漢理工大學
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x20,0x20,0x24,0x24,0x24,0xE4,0x24,0x20,0x20,0xFE,0x20,0x24,0x28,0x20,
0x00,0x20,0xC2,0x0C,0x80,0x60,0x04,0x7C,0x84,0x04,0x04,0xC4,0x3E,0x04,0x00,0x00,
0x88,0x88,0xF8,0x88,0x88,0x00,0xFC,0x24,0x24,0xFC,0x24,0x24,0xFE,0x04,0x00,0x00,
0x08,0x08,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x20,
0x20,0x20,0x20,0x20,0xFE,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x40,0x30,0x10,
0x52,0x5C,0x50,0x52,0x5C,0x50,0xD8,0x56,0x10,0x50,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x20,0x60,0x3F,0x20,0x20,0x1F,0x12,0x12,0x10,0x07,0x18,0x20,0x40,0x78,
0x00,0x04,0x04,0x7E,0x41,0x40,0x20,0x10,0x0B,0x04,0x0B,0x10,0x20,0x60,0x20,0x00,
0x10,0x30,0x1F,0x08,0x48,0x40,0x4B,0x49,0x49,0x7F,0x49,0x49,0x6B,0x40,0x08,0x20,
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x40,0x40,
0x20,0x10,0x08,0x06,0x01,0x02,0x04,0x08,0x10,0x20,0x60,0x20,0x00,0x04,0x04,0x04,
0x04,0x04,0x24,0x44,0x3F,0x05,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp2[]=
  源文件 / 文字 : 信息工程學院
  寬×高(像素): 128×16
  數據轉換日期  : 2010-7-29 18:34:04
  顯示的漢字:信息工程學院
0x00,0x80,0x40,0xF0,0x0E,0x00,0x28,0x28,0x28,0x2A,0x2C,0x28,0x28,0x28,0x08,0x00,
0x00,0x00,0x00,0xF8,0xA8,0xAC,0xAA,0xA8,0xA8,0xA8,0xFC,0x08,0x00,0x00,0x00,0x00,
0x08,0x08,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x24,
0xA4,0xFC,0x26,0x24,0x00,0x7C,0x24,0x24,0x24,0x24,0x7C,0x00,0x00,0x40,0x30,0x10,
0x52,0x5C,0x50,0x52,0x5C,0x50,0xD8,0x56,0x10,0x50,0x30,0x00,0x00,0xFC,0x04,0x64,
0x9C,0x20,0x58,0x48,0x4A,0x4C,0x48,0x48,0x18,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x7F,0x00,0x00,0x01,0x7D,0x25,0x25,0x25,0x25,0x7D,0x01,0x00,0x00,
0x00,0x20,0x18,0x03,0x3A,0x42,0x46,0x5A,0x42,0x42,0x73,0x00,0x08,0x30,0x00,0x20,
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x08,0x06,
0x01,0x7F,0x01,0x42,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,0x04,0x04,0x04,
0x04,0x04,0x24,0x44,0x3F,0x05,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x7F,0x04,0x08,
0x47,0x41,0x21,0x1F,0x01,0x01,0x3F,0x41,0x41,0x79,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp3[]=
  源文件 / 文字 : 通信工程
  寬×高(像素): 128×
  數據轉換日期  : 2010-7-29 18:36:04
  顯示漢字:通信工程
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x42,
0xCC,0x00,0x00,0xF4,0x54,0x5C,0xF4,0x5C,0x56,0xF4,0x00,0x00,0x00,0x80,0x40,0xF0,
0x0E,0x00,0x28,0x28,0x28,0x2A,0x2C,0x28,0x28,0x28,0x08,0x00,0x00,0x08,0x08,0x08,
0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x24,0xA4,0xFC,0x26,
0x24,0x00,0x7C,0x24,0x24,0x24,0x24,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x10,
0x0F,0x10,0x20,0x5F,0x42,0x42,0x5F,0x42,0x52,0x5F,0x40,0x40,0x00,0x00,0x00,0x7F,
0x00,0x00,0x01,0x7D,0x25,0x25,0x25,0x25,0x7D,0x01,0x00,0x00,0x20,0x20,0x20,0x20,
0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x08,0x06,0x01,0x7F,0x01,
0x42,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp4[]=
  源文件 / 文字 : 0606班
  寬×高(像素): 128×16
  數據轉換日期  : 2010-7-29 18:37:59
  顯示的漢字:0606班
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,
0x20,0x10,0x10,0x30,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,
0x20,0x10,0x10,0x30,0x00,0x00,0x44,0x44,0xFC,0x44,0x04,0xC0,0x00,0xFE,0x84,0x84,
0xFC,0x84,0x84,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,0x00,0x1F,
0x22,0x21,0x21,0x21,0x1E,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,0x00,0x1F,
0x22,0x21,0x21,0x21,0x1E,0x00,0x10,0x10,0x0F,0x48,0x28,0x11,0x08,0x27,0x20,0x20,
0x3F,0x20,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
函數功能:LCD延時程序
入口參數:t
出口參數:
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
狀態檢查,LCD是否忙
void CheckState()
   unsigned char dat,DATA;//狀態信息(判斷是否忙)
   LCDDi=0; // 數據\指令選擇,D/I(RS)="L" ,表示 DB7∽DB0 為顯示指令數據
   LCDRW=1; //R/W="H" ,E="H"數據被讀到DB7∽DB0
   do
      DATA=0x00;
      LCDEnable=1;        //EN下降源
          LCDdelay(2);//延時
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat; //僅當第7位為0時才可操作(判別busy信號)
    while(!(dat==0x00));
函數功能:寫命令到LCD程序,RS(DI)=L,RW=L,EN=H,即來一個脈沖寫一次
入口參數:cmdcode
出口參數:
void write_com(unsigned char cmdcode)
    CheckState();//檢測LCD是否忙
        LCDDi=0;
        LCDRW=0;
        P0=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函數功能:LCD初始化程序
入口參數:
出口參數:
void init_lcd()
        LCDdelay(100);
        LCDMcs=1;//剛開始關閉兩屏
        LCDScs=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);         //寫初始化命令
        write_com(Page_Add+0);
        write_com(Start_Line+0);
        write_com(LCDCol_Add+0);
        write_com(LCDLCDDisp_On);
函數功能:寫數據到LCD程序,RS(DI)=H,RW=L,EN=H,即來一個脈沖寫一次
入口參數:LCDDispdata
出口參數:
void write_data(unsigned char LCDDispdata)
        LCDDi=1;
        LCDRW=0;
        P0=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函數功能:清除LCD內存程序
入口參數:pag,col,hzk
出口參數:
void Clr_Scr()
        unsigned char j,k;
        LCDMcs=0; //左、右屏均開顯示
        LCDScs=0;
        for(k=0;k<8;k++)//控制頁數0-7,共8頁
                write_com(Page_Add+k); //每頁每頁進行寫
                  for(j=0;j<64;j++)  //每頁最多可寫32個中文文字或64個ASCII字符
                      write_com(LCDCol_Add+j);
                        write_data(0x00);//控制列數0-63,共64列,寫點內容,列地址自動加1
函數功能:左屏位置顯示
入口參數:page,column,hzk
出口參數:
void Bmp_Left_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<64;i++)
                        write_data(Bmp[128*j+i]);
函數功能:右屏位置顯示
出口參數:
void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        for(j=0;j<2;j++)
                for(i=64;i<128;i++)
        init_lcd();
        Clr_Scr();
        LCDMcs=0; //左屏開顯示
        LCDScs=1;
        Bmp_Left_Disp(0,0,Bmp1);// Bmp1為某個漢字的首地址
    Bmp_Left_Disp(2,0,Bmp2);
    Bmp_Left_Disp(4,0,Bmp3);
    Bmp_Left_Disp(6,0,Bmp4);
    LCDMcs=1; //右屏開顯示
        LCDScs=0;
    Bmp_Right_Disp(0,0,Bmp1);
    Bmp_Right_Disp(2,0,Bmp2);
    Bmp_Right_Disp(4,0,Bmp3);
    Bmp_Right_Disp(6,0,Bmp4);
#include <reg51.h>
  寬×高(像素): 128×16
  顯示的漢字:武漢理工大學
  源文件 / 文字 : 信息工程學院
  寬×高(像素): 128×16
  顯示的漢字:信息工程學院
  源文件 / 文字 : 通信工程
  寬×高(像素): 128×
  顯示漢字:通信工程
  源文件 / 文字 : 0606班
  寬×高(像素): 128×16
  顯示的漢字:0606班
函數功能:LCD延時程序
入口參數:t
出口參數:
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
狀態檢查,LCD是否忙
void CheckState()
   do
      DATA=0x00;
          LCDdelay(2);//延時
          dat=DATA;
      LCDEnable=0;
入口參數:cmdcode
出口參數:
        LCDDi=0;
        LCDRW=0;
        P0=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函數功能:LCD初始化程序
入口參數:
出口參數:
void init_lcd()
        LCDdelay(100);
        LCDMcs=1;//剛開始關閉兩屏
        LCDScs=1;
        LCDdelay(100);
入口參數:LCDDispdata
出口參數:
        LCDDi=1;
        LCDRW=0;
        P0=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函數功能:清除LCD內存程序
入口參數:pag,col,hzk
出口參數:
void Clr_Scr()
        unsigned char j,k;
        LCDScs=0;
函數功能:左屏位置顯示
出口參數:
        for(j=0;j<2;j++)
                for(i=0;i<64;i++)
函數功能:右屏位置顯示
出口參數:
        for(j=0;j<2;j++)
                for(i=64;i<128;i++)
        init_lcd();
        Clr_Scr();
        LCDMcs=0; //左屏開顯示
        LCDScs=1;
    LCDMcs=1; //右屏開顯示
        LCDScs=0;
這是程序
ID:96682 發表于 2018-6-4 17:07 | 顯示全部樓層
可以肯定使用圖片取模模式了
ID:318113 發表于 2018-6-4 22:08 | 顯示全部樓層
wc86110 發表于 2018-6-4 17:07
可以肯定使用圖片取模模式了
可以聯系下你么?
ID:96682 發表于 2018-6-4 23:16 | 顯示全部樓層
去熟悉一下取模軟件就知道咋回事了
ID:318113 發表于 2018-6-5 10:48 來自觸屏版 | 顯示全部樓層
wc86110 發表于 2018-6-4 23:16
去熟悉一下取模軟件就知道咋回事了
不是這個原因吧
ID:296837 發表于 2018-6-5 13:45 | 顯示全部樓層
取模的時候的問題或者刷新的問題。首先你用不同的取模方式試試,先試一個一個的字,不需要那么多,看看是不是取模的問題。再看看是不是LCD的驅動問題。PS:你的LCD驅動是抄的吧,你不覺得自己應該改一下,而且你的驅動和字應該單獨做成頭文件或者放一起的時候一塊一塊的,不要這樣亂,看起來有點暈,一會驅動一會字的,分開,中間隔開明顯一點。
ID:296837 發表于 2018-6-5 14:13 | 顯示全部樓層
#include <reg51.h>
/***函數功能:LCD延時程序***************/
/******狀態檢查,LCD是否忙*************************************/
/*******寫命令到LCD程序,RS(DI)=L,RW=L,EN=H,即來一個脈沖寫一次**************/
/*****寫數據到LCD程序,RS(DI)=H,RW=L,EN=H,即來一個脈沖寫一次*****************/
/*******LCD初始化程序************/
/****清除LCD內存程序************/
/*****左屏位置顯示**********************/
/****右屏位置顯示******************/
        init_lcd();初始化
        Clr_Scr();清屏
        LCDMcs=0; //左屏開顯示
        LCDScs=1;
    LCDMcs=1; //右屏開顯示
        LCDScs=0;
delay(10);//延時
這個程序結構沒什么問題,但是感覺怪怪的,清屏要全部清除,顯示要延時一會,不然會亂。看了你的程序也可能是沒有延時。我的程序加了延時,就最后面這里。你可以加了試試。
ID:318113 發表于 2018-6-6 00:19 | 顯示全部樓層
hk0506 發表于 2018-6-5 14:13
#include
不行呀
ID:295783 發表于 2018-6-6 15:49 | 顯示全部樓層
