查看: 1445|回復: 0
單片機軌道測速源代碼
ID:344059 發表于 2018-6-3 16:31 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
sbit p0=P2^5;
sbit p1=P2^1;
sbit p2=P2^2;
sbit p3=P2^3;
sbit p11=P1^1;//SUDUXINHAO
sbit p12=P1^2;//LED1
sbit p13=P1^3;//LED2
sbit p14=P1^4;//LED3
sbit p10=P1^0;//SHILIXINHAO
sbit p30=P3^0;//laba
sbit k1=P3^1;
sbit k2=P3^2;
sbit k3=P3^3;
sbit k4=P3^4;
sbit p23=P2^3;
sbit p24=P2^4;
uchar code led[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar code led0[10]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
uint x,y,z,q,w,e,num2,t,v;
void delay(uint z);
void init();
void ledinit();
void init()
        TMOD=0x01;
        TH0=(65536-5000)/256;
        TL0=(65536-5000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        num2=0;
void ledinit()
        p0=1;
        p1=1;
        p2=1;
        p3=1;
        init();
                v=(25000/t)*36;
                x=v/100;
                y=v%100;
                z=x/10;//min shi
                q=x%10;//min ge
                w=y/10;//miao shi
                e=y%10;//miao ge
                ledinit();
                p0=0;
                P0=led[z];//min shi
                delay(1);
                ledinit();
                p1=0;
                P0=led[q];//min ge
                delay(1);
                ledinit();
                p2=0;
                P0=led0[w];
                delay(1);//miao shi
                ledinit();
                p3=0;
                P0=led[e];
                delay(1);//miao ge
                if(p11==0)
                {p12=0;p13=0;p14=0;p30=0;}
                if(p10==0)
                {p12=0;p13=1;p14=0;p30=1;}
        if(k1==0){p23=1;p24=0;}        //zhengzhuan
        if(k1==0){p23=0;p24=1;}//fanzhuan
        if(k1==0){p23=1;p24=1;}//shache
        if(k1==0){p23=0;p24=0;}//tingzhi
void delay(uint z)//Ñóê±1ms
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void time0() interrupt 1 using 1//¶¨ê±ÖD¶Ï
        uint num1,num2;
        TH0|=(65536-918)/256;
        TL0|=(65536-918)%256;
        num1++;
        if(num1==1)
                num1=0;
                if(p11==0)
                {num2++;
                t=num2;
                {num2=0;}
