查看: 5806|回復: 1
51單片機蜂鳴器生日快樂歌
ID:341039 發表于 2018-6-2 22:27 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
sbit BEEP=P2^1;
void Music(uchar number);
void delay10us(uchar time);
void delay50us(uchar time);
uchar code SOUNDLONG[]=       //控制音調
  18,6,24,24,24,48,
  18,6,24,24,24,48,
  18,6,24,24,24,24,24,
  18,6,24,24,24,48,0
uchar code SOUNDTONE[]=       //控制音色
212,212,190,212,159,169,
212,212,190,212,142,159,
212,212,106,126,159,169,190,
119,119,126,159,142,159,0        //生日快樂end
void Play_Music()
  uint k,n;
  uint SoundLong,SoundTone;
  uint i,j,m;
  do
     if(i>=25) i=0;
     SoundLong=SOUNDLONG[i];
     SoundTone=SOUNDTONE[i];
     i++;
     for(n=0;n<SoundLong;n++)
      for(k=0;k<12;k++)
           BEEP=0;
           for(m=0;m<SoundTone;m++);
           BEEP=1;
      delay50us(6);
  }while((SOUNDLONG[i]!=0)||(SOUNDTONE[j]!=0));
//延時程序
  uchar a,b,c;
  for(a=0;a<time;a++)
     for(b=0;b<10;b++)
     for(c=0;c<120;c++);
  uchar a,b;
  for(a=0;a<time;a++)
    for(b=0;b<6;b++);
   Play_Music();       //生日快樂
   delay10us(250);
ID:430234 發表于 2018-11-30 18:35 | 顯示全部樓層
非常感謝!
