只需一步,快速開(kāi)始
查看: 1603|回復(fù): 0
紅綠燈
ID:343606 發(fā)表于 2018-6-2 17:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
sbit RED_A=P1^0;     //東西向紅燈
sbit YEL_A=P1^1;      //東西向黃燈
sbit GRE_A=P1^2;     //東西向綠燈
sbit RED_B=P1^3;     //南北向紅燈
sbit YEL_B=P1^4;      //南北向黃燈
sbit GRE_B=P1^5;     //南北向綠燈
uchar Time_Count=0,Flash_Count=0,Operation_Type=1;     //分別用于計(jì)中斷次數(shù),計(jì)閃爍次數(shù)(2倍),保存當(dāng)前狀態(tài)值
void time0() interrupt 1    //T0定時(shí)器中斷服務(wù)函數(shù)
TH0=(65536-50000)/256;    //重置定時(shí)器初值
TL0=(65536-50000)%256;
switch(Operation_Type)   //根據(jù)狀態(tài)值執(zhí)行相應(yīng)語(yǔ)句
  case 1: RED_A=0;YEL_A=0;GRE_A=1;   //東西向綠燈亮
               RED_B=1;YEL_B=0;GRE_B=0;   //南北向紅燈亮
               if(++Time_Count!=100)return;   //5s時(shí)間未到退出switch語(yǔ)句
         Time_Count=0;                  //5s時(shí)間到計(jì)數(shù)值清零
         Operation_Type=2;             //狀態(tài)轉(zhuǎn)移值變?yōu)?,準(zhǔn)備狀態(tài)轉(zhuǎn)移
         break;               //退出switch語(yǔ)句
case 2: if(++Time_Count!=8)return;   //400ms未到退出switch語(yǔ)句
                Time_Count=0;
           YEL_A=!YEL_A;GRE_A=0;  //東西向黃燈閃,綠燈滅
           if(++Flash_Count!=10)return;   //閃爍5次未到退出
           Flash_Count=0;    //閃爍次數(shù)清零
           Operation_Type=3;   //狀態(tài)轉(zhuǎn)移值變?yōu)?,準(zhǔn)備狀態(tài)轉(zhuǎn)移
           break;
  case 3: RED_A=1;YEL_A=0;GRE_A=0;   //東西向紅燈亮
               RED_B=0;YEL_B=0;GRE_B=1;   //南北向綠燈亮
          if(++Time_Count!=100)return;    //5s未到退出
           Time_Count=0;
   Operation_Type=4;   //狀態(tài)轉(zhuǎn)移值變?yōu)?,準(zhǔn)備狀態(tài)轉(zhuǎn)移
          break;
  case 4: if(++Time_Count!=8)return;   //0.4s未到退出
                Time_Count=0;
           YEL_B=!YEL_B;GRE_B=0;   //南北向黃燈閃爍,綠燈滅
           Flash_Count=0;
           Operation_Type=1;   //重新轉(zhuǎn)移到狀態(tài)1
           break;
  TMOD=0x01;
  ET0=1;
  EA=1;
  TH0=(65536-50000)/256;    //定時(shí)50ms初值
  TR0=1;   //啟動(dòng)T0定時(shí)器
  while(1);
#include<reg52.h>
sbit RED_A=P1^0;
sbit YEL_A=P1^1;
sbit GRE_A=P1^2;
sbit RED_B=P1^3;
sbit YEL_B=P1^4;
sbit GRE_B=P1^5;
         Time_Count=0;
         Operation_Type=2;
         break;
                Time_Count=0;
           Flash_Count=0;
           Operation_Type=3;
           break;
           Time_Count=0;
   Operation_Type=4;
          break;
                Time_Count=0;
           Flash_Count=0;
           Operation_Type=1;
           break;
  TMOD=0x01;
  ET0=1;
  EA=1;
  TR0=1;
  while(1);
