具有超強穿透能力的SX1276芯片引腳圖:
2018-6-3 03:52 上傳
SX1278引腳圖:
2018-6-3 03:52 上傳
2018-6-3 03:51 上傳
LoRaTM Modem
168 dB maximum link budget
+20 dBm - 100 mW constant RF output vs. V supply
+14 dBm high efficiency PA
Programmable bit rate up to 300 kbps
High sensitivity: down to -148 dBm
Bullet-proof front end: IIP3 = -11 dBm
Excellent blocking immunity
Low RX current of 9.9 mA, 200 nA register retention
Fully integrated synthesizer with a resolution of 61 Hz
FSK, GFSK, MSK, GMSK, LoRaTMand OOK modulation
Built-in bit synchronizer for clock recovery
Preamble detection
127 dB Dynamic Range RSSI
Automatic RF Sense and CAD with ultra-fast AFC
Packet engine up to 256 bytes with CRC
Built-in temperature sensor and low battery indicator
KEY PRODUCT FEATURES
The SX1276/77/78 transceivers feature the LoRaTM long
range modem that provides ultra-long range spread
spectrum communication and high interference immunity
whilst minimising current consumption.
Using Semtech’s patented LoRaTM modulation technique
SX1276/77/78 can achieve a sensitivity of over -148dBm
using a low cost crystal and bill of materials. The high
sensitivity combined with the integrated +20 dBm power
amplifier yields industry leading link budget making it
optimal for any application requiring range or robustness.
LoRaTM also provides significant advantages in both
blocking and selectivity over conventional modulation
techniques, solving the traditional design compromise
between range, interference immunity and energy
consumption.
These devices also support high performance (G)FSK modes for systems including WMBus, IEEE802.15.4g. The SX1276/77/78 deliver exceptional phase noise, selectivity, receiver linearity and IIP3 for significantly lower current consumption than competing devices. GENERAL DESCRIPTION
sx1276_ag.pdf
2018-6-2 15:49 上傳
下載積分: 黑幣 -5
3.02 MB, 下載次數: 29, 下載積分: 黑幣 -5
