查看: 3413|回復: 0
基于AT89C51定時器的使用
ID:342728 發表于 2018-6-1 17:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  #include<reg52.h>
#define uint  unsigned int
uint Count = 0;
uchar code table[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void Time0_Init()
        TMOD = 0x01;
        TH0  = 0x4c;
        TL0 = 0x00;
        ET0 = 1;
        EA = 1;
        TR0 = 1;
void Time0_Int() interrupt 1
        TH0  = 0x4c;
        TL0  = 0x00;
        Count++;
        uchar i = 0;
        Time0_Init();
        P2 = 0xfe;
                P0 = table[i % 10];
                if(Count == 20)
                        Count = 0;
                        i++;
