查看: 2421|回復: 0
51單片機漸亮漸暗 跑馬燈的實現
ID:341815 發表于 2018-5-30 22:35 | 顯示全部樓層 |閱讀模式
  1.     #include <reg52.h>
  2.     #include <intrins.h>
  3.     #include <string.h>
  4.
  5.     void liushui();
  6.     void rjl();    //漸亮
  7.     void rja();    //漸暗
  8.     void huaxin();
  9.     void huaxin2();
  10.     void huaxin3();
  11.     void zkb(unsigned char d);
  12.     void ys1ms(unsigned int s);  //延時聲明,修改s的數值,就可以改變時間
  13.
  14.     unsigned char code table[11]={0xff,0xff ,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0xff};
  15.     unsigned char code table6[11]={0xff,0xff ,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xff};
  16.     unsigned char code table2[8]={0x7f,0x3f ,0x1f,0x0f,0x07,0x03,0x01,0x00};
  17.     unsigned char code table3[8]={0xfe,0xfc ,0xf8,0xf0,0xe0,0xc0,0x80,0x00};
  18.     unsigned char code table4[9]={0x00,0x01 ,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};
  19.     unsigned char code table5[9]={0x00,0x80 ,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};
  20.
  21.     unsigned char i;
  22.     unsigned char j;
  23.     unsigned char k;
  24.     unsigned char m;
  25.
  26.     int main()
  27.     {
  28.         EA=1;//打開中斷,使用中斷方便調試查看模式
  29.         EX0=1; //允許外部中斷0中斷
  30.         EX1=1; //允許外部中斷1中斷
  31.         PX0=1; // 外部中斷0位高優先級
  32.         while(1)  //無限循環
  33.         {
  34.             liushui();   ////////////////////
  35.             ys1ms(50);
  36.             huaxin2();
  37.             ys1ms(50);
  38.             rja();
  39.             ys1ms(100);
  40.
  41.             huaxin();    ////////////////////
  42.             rjl();
  43.             rja();
  44.             ys1ms(100);
  45.
  46.             huaxin3();   ////////////////////
  47.             rja();
  48.             ys1ms(100);
  49.
  50.         }
  51.          return 0;
  52.     }
  53.
  54.     void liushui()
  55.     {
  56.
  57.             for(i = 9; i > 0; i--)
  58.             {
  59.                 P1 = table[ i];
  60.     [ i]            ys1ms(50);
  61.     [ i]        }
  62.     [ i]        for(i = 2; i <= 10; i++)
  63.     [ i]        {
  64.     [ i]            P0 = table[ i];
  65.     [ i][ i]             ys1ms(50);
  66.     [ i][ i]        }
  67.     [ i][ i]        for(i = 9; i > 0; i--)
  68.     [ i][ i]        {
  69.     [ i][ i]            P2 = table[ i];
  70.                  ys1ms(50);
  71.             }
  72.             for(i = 9; i > 0; i--)
  73.             {
  74.                 P3 = table[ i];
  75.                  ys1ms(50);
  76.             }
  77.
  78.     }
  79.
  80.      void ys1ms(unsigned int s)    //定時器精確延時1毫秒函數,改變S數值即改變時間
  81.      {
  82.         TR0=1;
  83.         while(s!=0)
  84.         {
  85.             TH0=-(7629/256);
  86.             TL0=-(7629%256);
  87.             while(TF0!=1);
  88.             TF0=0;
  89.             s--;
  90.         }
  91.         TR0=0;
  92.      }
  93.
  94.      /****************************************************************************/
  95.     void rjl()  //漸亮函數
  96.     {
  97.         unsigned char a, b;//a控制延時長度 b控制循環周期
  98.         P0 = 0xff;
  99.         P1 = 0xff;
  100.         P2 = 0xff;
  101.         P3 = 0xff;
  102.         a = 0;
  103.             for (b=250; b>0; b--)   //循環周期設置
  104.             {
  105.                 a++;
  106.                 zkb (a);      //延時長度隨a而改變
  107.                 P0 = 0xff;
  108.                 P1 = 0xff;
  109.                 P2 = 0xff;
  110.                 P3 = 0xff;
  111.                 a = ~a;         //a值取反,決定燈滅時的占空比
  112.                 zkb (a);
  113.                 P0 = 0x00;
  114.                 P1 = 0x00;
  115.                 P2 = 0x00;
  116.                 P3 = 0x00;
  117.                 a = ~a;         //a值取反 使a回到原值繼續循環
  118.              }
  119.      }
  120.     /****************************************************************************/
  121.     void rja()  //漸暗函數
  122.     {
  123.         unsigned char a, b;//a控制延時長度 b控制循環周期
  124.         P0 = 0x00;
  125.         P1 = 0x00;
  126.         P2 = 0x00;
  127.         P3 = 0x00;            //亮起LED
  128.         a = 0;
  129.             for (b=250; b>0; b--)
  130.             {
  131.                 a++;
  132.                 zkb (a);
  133.                 P0 = 0x00;
  134.                 P1 = 0x00;
  135.                 P2 = 0x00;
  136.                 P3 = 0x00;
  137.                 a = ~a;
  138.                 zkb (a);
  139.                 P0 = 0xff;
  140.                 P1 = 0xff;
  141.                 P2 = 0xff;
  142.                 P3 = 0xff;
  143.                 a = ~a;
  144.             }
  145.     }
  146.     void huaxin()
  147.     {
  148.         for(j = 0; j < 2; j++)
  149.         {
  150.             for(i = 0; i < 8; i++)
  151.             {
  152.                 P1 = table2[ i];
  153.                 P3 = table3[ i];
  154.                 ys1ms(50);
  155.             }
  156.             for(i = 0; i < 8; i++)
  157.             {
  158.                 P0 = table3[ i];
  159.                 P2 = table3[ i];
  160.                  ys1ms(50);
  161.             }
  162.             for(i = 0; i < 9; i++)
  163.             {
  164.                 P2 = table5[ i];
  165.                 P0 = table5[ i];
  166.                 ys1ms(50);
  167.             }
  168.             for(i = 0; i < 9; i++)
  169.             {
  170.                 P3 = table5[ i];
  171.                 P1 = table4[ i];
  172.                  ys1ms(50);
  173.             }
  174.             ys1ms(100);
  175.         }
  176.     }
  177.     void huaxin2()
  178.     {
  179.             for(i = 0; i < 8; i++)
  180.             {
  181.                 P1 = table2[ i];
  182.                 ys1ms(50);
  183.             }
  184.             for(i = 0; i < 8; i++)
  185.             {
  186.                 P0 = table3[ i];
  187.                  ys1ms(50);
  188.             }
  189.              for(i = 0; i < 8; i++)
  190.             {
  191.                 P2 = table2[ i];
  192.
  193.                 ys1ms(50);
  194.             }
  195.             for(i = 0; i < 8; i++)
  196.             {
  197.                 P3 = table2[ i];
  198.
  199.                  ys1ms(50);
  200.             }
  201.     }
  202.     void huaxin3()
  203.     {
  204.         k = 0;
  205.         for(m = 0; m < 2; m++)
  206.         {
  207.             for(j = 0; j < 4; j++)
  208.             {
  209.                 for(i = 9; i > 0; i--)
  210.                 {
  211.                     P1 = table[ i];
  212.                     P0 = table6[ i];
  213.                     P2 = table[ i];
  214.                     P3 = table[ i];
  215.                     ys1ms(50);
  216.                 }
  217.             }
  218.
  219.                 for(i = 0; i < 8; i++)
  220.                 {
  221.                     P1 = table2[ i];
  222.                     P0 = table3[ i];
  223.                     P2 = table2[ i];
  224.                     P3 = table2[ i];
  225.                     ys1ms(50);
  226.                 }
  227.             if(k == 0)
  228.             {
  229.                 for(i = 0; i < 8; i++)
  230.                 {
  231.                     P1 = table5[ i];
  232.                     P0 = table4[ i];
  233.                     P2 = table5[ i];
  234.                     P3 = table5[ i];
  235.                     ys1ms(50);
  236.                 }
  237.             }
  238.                 ys1ms(100);
  239.                 k++;
  240.         }
  241.     }
  242.     /****************************************************************************/
  243.     void zkb(unsigned char d)   //占空比函數,由d決定延時長度
  244.     {
  245.         unsigned char i;
  246.         while( --d != 0)
  247.         {
  248.             for(i = 0; i < 1; i++);   //占空比時間設置
  249.         }
  250.     }
