查看: 1581|回復: 0
JAVA SOCKET 通信編程
ID:341350 發表于 2018-5-30 14:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  • package cn.itcast.framework.socket;
  • import java.io.BufferedReader;
  • import java.io.IOException;
  • import java.io.InputStreamReader;
  • import java.io.PrintWriter;
  • import java.net.ServerSocket;
  • import java.net.Socket;
  • //用JAVA SOCKET編程,讀服務器幾個字符,再寫入本地顯示?
  • //Server端程序:
  • public class Server {
  •     private ServerSocket serverSocket;
  •     private Socket socket;
  •     private BufferedReader in;
  •     private PrintWriter out;
  •     public Server(){
  •         try {
  •             serverSocket = new ServerSocket(10000);
  •             while(true){
  •                 socket = serverSocket.accept();
  •                 String RemoteIP = socket.getInetAddress().getHostAddress();
  •                 String RemotePort = ":"+socket.getLocalPort();
  •                 System.out.println("A client come in!IP:"+RemoteIP+RemotePort);
  •                 in = new BufferedReader(new InputStreamReader(socket.getInputStream()));
  •                 String line = in.readLine();
  •                 System.out.println("Client send is :"+line);
  •                 out = new PrintWriter(socket.getOutputStream(),true);
  •                 out.println("Your Message Received!");
  •                 out.close();
  •                 in.close();
  •                 socket.close();
  •         } catch (IOException e) {
  •             out.println("wrong");
  •     public static void main(String[] args){
  •         new Server();
  • public class Client {
  •     Socket socket;
  •     BufferedReader in;
  •     PrintWriter out;
  •     public Client(){
  •         try {
  •             System.out.println("Try to Connect to 127.0.0.1:10000");
  •             socket = new Socket("127.0.0.1",10000);
  •             System.out.println("The Server Connected!");
  •             System.out.println("Please enter some Character:");
  •             BufferedReader line = new BufferedReader(new InputStreamReader(System.in));
  •             out.println(line.readLine());
  •             System.out.println(in.readLine());
  •             out.close();
  •             in.close();
  •             socket.close();
  •             out.println("Wrong");
  •     public static void main(String [] args){
  •         new Client();
