查看: 2897|回復: 0
16X16點陣上面實現(xiàn)倒計時的單片機程序
ID:341254 發(fā)表于 2018-5-30 11:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  •                   LED點陣實驗 (顯示數(shù)字)        *
  •                 行:高電平有效,低16位  列:低電平有效,高16位
  • #include <REG51.H>
  • #include <intrins.h>
  • #define  NOP() _nop_()  // 定義空指令 ,這個函數(shù)在庫 <intrins.h> 中
  • //SPI IO
  • sbit MOSIO = P3^4;
  • sbit R_CLK = P3^5;
  • sbit S_CLK = P3^6;
  • //變量聲明
  • unsigned long column;   //點陣列
  • unsigned long row;      //點陣行
  • unsigned long dt;
  • //點陣顯示數(shù)組
  • unsigned char code tab0[] = {0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,
  •                              0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
  • unsigned char code tab1[] = {0,0,0,0,0,0,8,24,14,36,8,66,8,66,8,66,8,66,8,66,8,66,8,36,62,24,0,0,0,0,0,0};
  • unsigned char code tab2[] = {0,0,0,0,0,0,24,24,36,36,66,66,66,66,66,66,66,100,66,88,66,64,66,64,36,36,24,28,0,0,0,0} ;
  • unsigned char code tab3[] = {0,0,0,0,0,0,24,60,36,66,66,66,66,66,66,36,66,24,66,36,66,66,66,66,36,66,24,60,0,0,0,0};
  • unsigned char code tab4[] = {0,0,0,0,0,0,24,126,36,34,66,34,66,16,66,16,66,8,66,8,66,8,66,8,36,8,24,8,0,0,0,0};
  • unsigned char code tab5[] = {0,0,0,0,0,0,24,56,36,36,66,2,66,2,66,26,66,38,66,66,66,66,66,66,36,36,24,24,0,0,0,0};
  • unsigned char code tab6[] = {0,0,0,0,0,0,24,126,36,2,66,2,66,2,66,26,66,38,66,64,66,64,66,66,36,34,24,28,0,0,0,0};
  • unsigned char code tab7[] = {0,0,0,0,0,0,24,32,36,48,66,40,66,36,66,36,66,34,66,34,66,126,66,32,36,32,24,120,0,0,0,0};
  • unsigned char code tab8[] = {0,0,0,0,0,0,24,60,36,66,66,66,66,32,66,24,66,32,66,64,66,64,66,66,36,34,24,28,0,0,0,0};
  • unsigned char code tab9[] = {0,0,0,0,0,0,24,60,36,66,66,66,66,66,66,32,66,32,66,16,66,8,66,4,36,66,24,126,0,0,0,0};
  • unsigned char code tab10[] = {0,0,0,0,0,0,24,8,36,14,66,8,66,8,66,8,66,8,66,8,66,8,66,8,36,8,24,62,0,0,0,0};
  • unsigned char code tab11[] = {0,0,0,0,0,0,24,24,36,36,66,66,66,66,66,66,66,66,66,66,66,66,66,66,36,36,24,24,0,0,0,0};
  • unsigned char code tab12[] = {0,0,0,0,0,0,60,28,34,34,34,65,1,65,1,65,1,65,113,65,33,65,34,65,34,34,28,28,0,0,0,0};
  • //函數(shù)聲明
  • void HC595SendData(  unsigned char BT3, unsigned char BT2,unsigned char BT1,unsigned char BT0);
  • /*************主函數(shù)*****************************/
  • void main(void)
  •    int k,i,ms;
  •    i = 16;        //顯示時間
  •    while(1)
  •      for(ms = i; ms > 0; ms--)
  •        for(k = 0; k < 16; k++)        //親
  •          HC595SendData(~tab1[2*k +1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]);
  •          HC595SendData(0xff,0xff,0,0);        //清屏
  •        for(k = 0; k < 16; k++)        //愛
  •          HC595SendData(~tab2[2*k +1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //的
  •          HC595SendData(~tab3[2*k +1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //顧
  •          HC595SendData(~tab4[2*k +1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //客
  •          HC595SendData(~tab5[2*k +1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //歡
  •          HC595SendData(~tab6[2*k +1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //迎
  •          HC595SendData(~tab7[2*k +1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //使
  •          HC595SendData(~tab8[2*k +1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //用
  •          HC595SendData(~tab9[2*k +1],~tab9[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //普
  •          HC595SendData(~tab10[2*k +1],~tab10[2*k],tab0[2*k],tab0[2*k + 1]);
  •        for(k = 0; k < 16; k++)        //中
  •          HC595SendData(~tab11[2*k +1],~tab11[2*k],tab0[2*k],tab0[2*k + 1]);
  •          while(1)
  •              HC595SendData(~tab12[2*k +1],~tab12[2*k],tab0[2*k],tab0[2*k + 1]);
  •          }        //清屏
  • ** 函數(shù)名稱: HC595SendData
  • ** 功能描述: 向SPI總線發(fā)送數(shù)據(jù)
  •   unsigned char i;
  •   for(i = 0; i < 32; i++)
  •    if(i > 23 )
  •       if((BT0 << (i - 24)) & 0x80)
  •             MOSIO = 1;
  •           else
  •             MOSIO = 0;
  •    else if(i > 15 & i < 24 )
  •         if((BT1 << (i - 16)) & 0x80)  //set dataline high  0X80000000  最高位與SendVal左移的最高位 進行邏輯運算
  •             MOSIO = 1;                                          // 如果為真 MOSIO = 1
  •         else
  •             MOSIO = 0;
  •     else if(i < 16 & i > 7 )
  •       if((BT2 << (i - 8)) & 0x80)
  •             MOSIO = 1;
  •           else
  •             MOSIO = 0;
  •         else
  •                   if((BT3 << i) & 0x80)  //set dataline high  0X80000000  最高位與SendVal左移的最高位 進行邏輯運算
  •         else
  •             MOSIO = 0;
  •         S_CLK = 0;
  • //        NOP();        //產(chǎn)生方形波
  •         S_CLK = 1;
  •   R_CLK = 0; //set dataline low
  •   R_CLK = 1; //片選
[color=rgb(51, 102, 153) !important]復制代碼
下面是顯示漢字的程序:
  • *                         LED點陣實驗 (顯示數(shù)字)        *
  • //SPI IO
  • //變量聲明
  • unsigned long dt;
  • //點陣顯示數(shù)組
  • unsigned char code tab1[] = {96,2,28,10,16,18,16,2,254,63,16,2,16,18,112,18,24,10,22,10,16,36,16,42,16,49,156,32,0,0,0,0};
  • unsigned char code tab2[] = {0,30,252,9,72,8,144,4,254,63,66,32,252,31,32,0,240,15,80,4,136,2,4,1,194,6,56,56,0,0,0,0};
  • unsigned char code tab3[] = {144,0,144,0,208,63,72,32,40,16,12,2,10,2,136,10,136,18,72,18,72,34,40,34,8,2,136,3,0,0,0,0};
  • unsigned char code tab4[] = {0,0,0,0,60,240,102,156,67,130,0,0,0,0,0,0,0,0,0,0,48,24,96,8,192,7,0,0,0,0,0,0};
  • //函數(shù)聲明
  • void main(void)
  •    int k,i,ms;
  •    i = 16;        //顯示時間
  •    while(1)
  •        for(k = 0; k < 16; k++)        //我
  •        for(k = 0; k < 16; k++)        //你
  •          for(ms = 30; ms > 0; ms--)
  •        for(k = 0; k < 16; k++)        //笑臉
  •   unsigned char i;
  •    if(i > 23 )
  •             MOSIO = 1;
  •           else
  •             MOSIO = 0;
  •         else
  •             MOSIO = 0;
  •             MOSIO = 1;
  •           else
  •             MOSIO = 0;
  •         else
  •         else
  •             MOSIO = 0;
  •         S_CLK = 0;
  •         S_CLK = 1;
  •   R_CLK = 1; //片選
