查看: 2482|回復: 0
尋跡小車:用定時器寫了PWM波,能循跡,但是不能調速,求大神解答
回帖獎勵 10 黑幣 回復本帖可獲得 10 黑幣獎勵! 每人限 1 次
ID:295220 發表于 2018-5-29 21:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <reg52.h>
sbit IN1=P0^0;
sbit IN2=P0^1;
sbit IN3=P0^2;
sbit IN4=P0^3;
sbit L_PWM=P0^4;
sbit R_PWM=P0^5;
sbit hongwai_l1=P2^2;
sbit hongwai_r1=P2^3;
sbit hongwai_l2=P2^4;
sbit hongwai_r2=P2^5;
unsigned char l_tt=0;
unsigned char l_Lpwm=2;
unsigned char l_Rpwm=2;
void delay(int i)
    uchar t;
    for(;i>0;i--)
        for(t=110;t>0;t--);
void time0init()
TMOD|=0x01;
TH0=0xFF;                  //定時10us,使通過電機的PWM波的頻率為10khz
TL0=0xF6;
ET0=1;
EA=1;
TR0=1;
void time()interrupt 1
    TH0=0xFF;
    TL0=0xF6;
    l_tt++;
    if(l_tt==9)
        l_tt=0;
    if(l_tt<l_Lpwm)
        L_PWM=1;
        L_PWM=0;
    if(l_tt<l_Rpwm)
        R_PWM=1;
        R_PWM=0;
time0init();
  if(hongwai_l1==0&&hongwai_r1==0)
      IN1=1;
   IN2=0;
   IN3=1;
   IN4=0;
  if(hongwai_l1==1&&hongwai_r1==1)
      IN1=1;
   IN2=1;
   IN3=1;
   IN4=1;
   delay(200);
  if(hongwai_l1==0&&hongwai_r1==1)
   IN1=1;
   IN2=0;
   IN3=1;
   IN4=1;
    if(hongwai_l1==1&&hongwai_r1==0)
   IN1=1;
   IN2=1;
   IN3=1;
   IN4=0;
   if(hongwai_l1==0&&hongwai_r1==0&&hongwai_l2==1&&hongwai_r2==0)
       IN1=1;
       IN2=0;
       IN3=0;
       IN4=1;
       if(hongwai_l1==1)
       break;
       IN1=0;
       IN2=1;
       IN3=1;
       IN4=0;
       if(hongwai_r1==1)
       break;
我用電壓表測了一下使能端的電壓差,只有1.34V,求解
