查看: 2135|回復: 1
求單片機音樂彩燈怎么加入按鍵奏樂程序
ID:339722 發表于 2018-5-28 16:04 | 顯示全部樓層 |閱讀模式
原程序如下
#include <reg52.h>
#define uint  unsigned int
sbit duan=P2^6;
sbit key1=P3^2;//按key1可切換花樣
sbit key2=P3^3;//按key2可切換歌曲
sbit fm=P3^7;//蜂鳴器連續的IO口
sbit P34=P3^4;//矩陣鍵盤的一列
uchar code huayang1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,
                                                0xfd,0xfb,0xf7,0xef,0xdf,0xbf};//花樣1
uchar code huayang2[]={0x7f,0xfe,0xbf,0xfd,0xdf,0xfb,0xef,0xf7,
                                                0xef,0xfb,0xdf,0xfd,0xbf,0xfe};//花樣2
uchar code huayang3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x0,
                                                0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};
char code huayang4[]={ 0x55,0xaa,0xcc,0x33,0x99,0x66,0x0f,0xf0};
uchar count1;//花樣標志
uchar count2;//歌曲標志
uchar timeh,timel,i;
//================簡譜====================
//編程規則:字節高位是簡譜,低位是持續時間,
//代表多少個十六分音符
//1-7代表中央C調,8-E代表高八度,0代表停頓
//最后的0是結束標志
uchar code lzlh[]={         //兩只老虎
0x14,0x14,0x24,0x34,0x14,0x14,0x24,0x34,0x14,
        0x34,0x44,0x58,0x34,0x44,0x58,
        0x53,0x61,0x53,0x41,0x34,0x14,
        0x14,0x54,0x18,
        0x14,0x54,0x18,
        0xFF         //歌曲結束標志
uchar code sb[]={ //送別
0x54,0x54,0x32,0x52,0x88,0x64,0x84,0x58,
        0x54,0x12,0x22,0x34,0x22,0x12,0x28,0x04,0x04,
        0x54,0x32,0x52,0x86,0x72,0x64,0x84,0x58,
        0x54,0x22,0x32,0x46,0xB2,0x18,0x04,0x04,
        0x64,0x84,0x88,0x74,0x62,0x72,0x88,
        0x62,0x72,0x82,0x62,0x62,0x52,0x32,0x12,0x28,0x04,0x04,
        0xFF
uchar code mlh[]={ //茉莉花
0x31,0x21,0x31,0x51,0x61,0x51,0x81,0x61,
        0x51,0x31,0x54,0x62,0x82,0x91,0x81,0x58,
                0x51,0x31,0x54,0x62,0x82,0x91,0xA1,0x91,
                0x61,0x52,0x52,0x22,0x31,0x51,0x31,0x21,0x11,0xD1,0x16,
                0x31,0x21,0x12,0x23,0x31,0x52,0x61,0x81,
                0x62,0x52,0x51,0x31,0x22,
                0x31,0x51,0x31,0x21,0x11,0x21,0xD4,0x12,
                0x23,0x31,0x11,0xD1,0x11,0xD1,0xC6,
                0xFF
uchar code xxx[]={ //小星星
0x12,0x12,0x52,0x52,0x62,0x62,0x54,0x42,
        0x42,0x32,0x32,0x22,0x21,0x14,
                0x52,0x52,0x42,0x42,0x32,0x32,0x24,0x52,
                0x12,0x12,0x52,0x52,0x62,0x62,0x64,0x42,
                0x32,0x32,0x22,0x22,0x14,
                0xFF
//==============簡譜音調對應的定時器初值=======
//適合11.0592M的晶振
uchar code cuzhi[]={
         0xff,0xff,//占位
         0xFC,0x8E,//中央C調1-7
         0xFC,0xED,
         0xFD,0x43,
         0xFD,0x6A,
         0xFD,0xB3,
         0xFD,0xF3,
         0xFE,0x2D,
         0xFE,0x47,        //高八度1-7
         0xFE,0x76,
         0xFE,0xA1,
         0xFE,0xC7,
         0xFE,0xD9,
         0xFE,0xF9,
         0xFF,0x16
uchar yinyue[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0x0,0x0};
//將音調轉化為對應的LED樣式
void delay1(uint z);        //延時1MS
void delay(uint z);        //延時165MS,即十六分音符
void song();
main()
{        uchar x;
        count1=0;//流水燈無花樣
        count2=1;//唱第一首歌
        P34=0;//選取矩陣鍵盤的一列
        EA=1;//開總中斷
        EX0=1;//開外部中斷0
        IT0=1;//外部中斷0下降沿觸發方式
        EX1=1;//開外部中斷1
        IT1=1;//外部中斷1下降沿觸發方式
        TMOD=0x01;//定時器0工作在方式1
        TH0=0;
        TL0=0;
        ET0=1;
                if(count1!=0)
                        switch(count1)
                                case 1:
                                        for(x=0;x<14;x++)
                                                duan=1;
                                                P2=huayang1[x];
                                                fm=1;
                                                delay1(300);
                                                duan=0;
                                                if(count1!=1)
                                                        break;
                                break;
                                case 2:
                                        for(x=0;x<14;x++)
                                                duan=1;
                                                P2=huayang2[x];
                                                fm=1;
                                                delay1(300);
                                                duan=0;
                                                if(count1!=2)
                                                        break;
                                break;
                                case 3:
                                        for(x=0;x<16;x++)
                                                duan=1;
                                                P2=huayang3[x];
                                                fm=1;
                                                delay1(300);
                                                duan=0;
                                                if(count1!=3)
                                                        break;
                                break;
                                case 4:
                                        for(x=0;x<8;x++)
                                                duan=1;
                                                P2=huayang4[x];
                                                fm=1;
                                                delay1(300);
                                                duan=0;
                                                if(count1!=4)
                                                        break;
                                break;
                        song();
                        delay1(1000);
void int0() interrupt 0
        EA=0;//關總中斷
        delay1(1);//去抖
        if(key1==0)
                count2=0;//不讓蜂鳴器唱歌
                TR0=0;
                count1++;
                if(count1==5)
                         count1=1;
        EA=1;//開總中斷
void int1() interrupt 2
        EA=0;//關總中斷
        delay1(1);//去抖
        if(key2==0)
                count1=0;//流水燈無花樣
                TR0=1;
                i=0;//從頭開始唱
                count2++;
                if(count2==3)
                         count2=1;
        EA=1;//開總中斷
void timer0() interrupt 1         //用于產生各種音調
        TH0=timeh;
        TL0=timel;
        fm=~fm;
void song()
        uint temp;
        uchar jp;//jp是簡譜
        i=0;
        {        if(count2==0)
                        break;
                if(count2==1)        //選曲
                         temp=lzlh[i];
                if(count2==2)
                        temp=sb[i];
                if(count2==2)
                    temp=mlh[i];
                if(count2==3)
                    temp=xxx[i];
                if(temp==0xff)
                        break;
                jp=temp/16; //取數的高4位
                duan=1;
                P2=yinyue[jp];
                duan=0;
                if(jp!=0)
                timeh=cuzhi[jp*2];
                timel=cuzhi[jp*2+1];
                TR0=0;
                fm=1;//關蜂鳴器
                delay(temp%16); //取數的低4位
                TR0=0;         //唱完一個音停10MS
                fm=1;
                delay1(10);
                TR0=1;
                i++;
        TR0=0;
        fm=1;
void delay(uint z)        //延時165MS,即十六分音符
{        uint x,y;
        for(x=z;x>0;x--)
                 for(y=19000;y>0;y--);
void delay1(uint z)        //延時1MS
{        uint x,y;
        for(x=z;x>0;x--)
                 for(y=112;y>0;y--);
