查看: 2285|回復: 1
程序網上找的。proteus仿真正常。實物連接用stc89c52和ds12864-6.方塊亂碼了。求解
ID:309192 發表于 2018-5-27 11:20 | 顯示全部樓層 |閱讀模式
#include <AT89X52.H>
#define uint  unsigned int    // 宏定義
#define DOWNTIME 80  //下落速度
#define MAXHANG 20
#define MAXLIE  16
#define MAXPIX  3
#define PUSHON  50
#define LCD P2    //定義引腳
#define E  P3_0
#define RW  P3_1
#define RS  P3_2
#define CS1 P3_4
#define CS2 P3_3
#define KEYROTATION P1_0
#define KEYLEFT P1_1
#define KEYRIGH P1_2
#define KEYDOWN P1_3
uchar gkey=0xff,keystate=0,t0ms1=0,t0ms=0,downtimegap=0;//定義變量
uchar miao=0,fen=0;
uchar downok;
bit keyflag,timeupdate,fashionupdate;
uchar idata cubeMap[MAXHANG][2];
typedef struct{                                    //定義結構體
               uchar code * box;
                           uchar cube : 4;
                           uchar state : 4;
                           char row;
                           char column;
                           } block;
block this;
uint score=0;
uchar speed=1;
uchar code bittable[8]={1,2,4,8,0x10,0x20,0x40,0x80};
uchar code cube[]=
0,4,0xe,0,  0,2,6,2,     0,7,2,0,     4,6,4,0,
0,8,0xe,0,  0,4,4,0xc,   0,0,0xe,2,   0,6,4,4,
0,0xe,8,0,  0,4,4,6,     0,1,7,0,     6,2,2,0,
0,0xc,6,0,  0,2,6,4,     0,6,3,0,     2,6,4,0,
0,6,0xc,0,  0,4,6,2,     0,3,6,0,     4,6,2,0,
0,0xf,0,0,  4,4,4,4,     0,0,0xf,0,   2,2,2,2,
0,6,6,0,    0,6,6,0,     0,6,6,0,     0,6,6,0
uchar code ascll[]=
//數字
    0x3E,0x51,0x49,0x45,0x3E, // -0-
    0x00,0x42,0x7F,0x40,0x00, // -1-
    0x62,0x51,0x49,0x49,0x46, // -2-
    0x21,0x41,0x49,0x4D,0x33, // -3-
    0x18,0x14,0x12,0x7F,0x10, // -4-
    0x27,0x45,0x45,0x45,0x39, // -5-
    0x3C,0x4A,0x49,0x49,0x31, // -6-
    0x01,0x71,0x09,0x05,0x03, // -7-
    0x36,0x49,0x49,0x49,0x36, // -8-
    0x46,0x49,0x49,0x29,0x1E, // -9-
    0x00,0x36,0x36,0x00,0x00, // -:-10
//next
    0x7F,0x04,0x08,0x10,0x7F, // -N-11
    0x7F,0x49,0x49,0x49,0x41, // -E-12
    0x63,0x14,0x08,0x14,0x63, // -X-13
    0x01,0x01,0x7F,0x01,0x01, // -T-14
//speed
    0x26,0x49,0x49,0x49,0x32, // -S-15
    0x7F,0x09,0x09,0x09,0x06, // -P-16
    0x7F,0x49,0x49,0x49,0x41, // -E-17
    0x7F,0x41,0x41,0x41,0x3E, // -D-18
//score
    0x3E,0x41,0x41,0x41,0x22, // -C-19
    0x3E,0x41,0x41,0x41,0x3E, // -O-20
    0x7F,0x09,0x19,0x29,0x46, // -R-21
    0x00,0x00,0x00,0x00,0x00,  // - -22
//GAME OVER
    0x3E,0x41,0x51,0x51,0x72, // -G-23
    0x7C,0x12,0x11,0x12,0x7C, // -A-24
    0x7F,0x02,0x0C,0x02,0x7F, // -M-25
    0x1F,0x20,0x40,0x20,0x1F, // -V-26
void lcdCmd(uchar cmd)      //向AMPIPE 128*64寫入命令
bit ea;
ea=EA;
EA=0;
E=0;
RW=0;
RS=0;
LCD=cmd;
E=1;
E=1;
E=0;
EA=ea;
void lcdWriteByte(uchar ch)   //向AMPIPE 128*64寫入1B的數據
E=0;
RS=1;
RW=0;
LCD=ch;
E=1;
E=1;
E=0;
void lcdSetPage(uchar page)  //設置AMPIPE 128*64的內部頁
  page &=0x7;
  page +=0xb8;
  lcdCmd(page);
void lcdSetColumn(uchar column)  //設置LCD的顯示列
  column &=0x3f;
  column +=0x40;
  lcdCmd(column);
void lcdPlayChar(uchar index,uchar page,uchar colume )//在LCD上顯示一個8*5的字符
uchar i,temp;
uint p;
p=5*index;
for(i=colume;i<colume+5;i++)
    if(i<64)
          CS1=0;
          CS2=1;
          temp=i;
          CS1=1;
          CS2=0;
          temp=i-64;
        lcdSetPage(page);
        lcdSetColumn(temp);
        lcdWriteByte(ascll[p++]);
void rectangle(void)    //顯示游戲邊界長方形
  uchar i,page;
  CS1=0;
  CS2=1;
  lcdSetPage(0);
  lcdSetColumn(2);
  E=0;
  RS=1;
  RW=0;
  LCD=0xff;
  E=1;
  E=1;
  E=0;
  for(i=3;i<51;i++)
     E=0;
     RS=1;
     RW=0;
     LCD=0x1;
     E=1;
     E=1;
     E=0;
  E=0;
  RS=1;
  RW=0;
  LCD=0xff;
  E=1;
  E=1;
  E=0;
for(page=1;page<7;page++)
  lcdSetPage(page);
  lcdSetColumn(2);
  E=0;
  RS=1;
  RW=0;
  LCD=0xff;
  E=1;
  E=1;
  E=0;
  for(i=3;i<51;i++)
     E=0;
     RS=1;
     RW=0;
     LCD=0x0;
     E=1;
     E=1;
     E=0;
  E=0;
  RS=1;
  RW=0;
  LCD=0xff;
  E=1;
  E=1;
  E=0;
  lcdSetPage(7);  //再次設置頁面和列信息
  lcdSetColumn(2);
  E=0;
  RS=1;
  RW=0;
  LCD=0x1f;
  E=1;
  E=1;
  E=0;
  for(i=3;i<51;i++)
     E=0;
     RS=1;
     RW=0;
     LCD=0x10;
     E=1;
     E=1;
     E=0;
  E=0;
  RS=1;
  RW=0;
  LCD=0x1f;
  E=1;
  E=1;
  E=0;
void lcdPutPix(uchar x, uchar y,uchar flag)  //在LCD上顯示一個點
  uchar i,dat,bitmask,nextbit;
  bit bflag,pflag,ea;
  x=x*MAXPIX;
  y=y*MAXPIX;
  bflag=0;
  pflag=0;
  i=y%8;
  if(i==0)
   bitmask=0x7;
  else if(i==1)
   bitmask=0xe;
  else if(i==2)
   bitmask=0x1c;
  else if(i==3)
   bitmask=0x38;
  else if(i==4)
   bitmask=0x70;
  else if(i==5)
   bitmask=0xe0;
  else if(i==6)
    bflag=1;
    bitmask=0xc0;
    nextbit=1;
  else if(i==7)
    bflag=1;
    bitmask=0x80;
    nextbit=3;
  if(x<62)
    CS1=0;
    CS2=1;
  else if(x>63)
    x-=64;
    CS1=1;
    CS2=0;
   pflag=1;
  lcdSetPage(y/8);
  for(i=x;i<x+MAXPIX;i++)
    if(pflag)
      if(i==62 || i==63)
         CS1=0;
         CS2=1;
         lcdSetPage(y/8);
      else if(pflag && i==64)
        CS1=1;
        CS2=0;
        lcdSetPage(y/8);
     lcdSetColumn(i);
     ea=EA;
     EA=0;
     E=0;
     LCD=0xff;
     RS=1;
     RW=1;
     E=1;
     E=0;
     E=1;
     dat=LCD;
     E=0;
     if(flag==1)
       dat|=bitmask;
       dat&=~bitmask;
     lcdSetColumn(i);
     E=0;
     RW=0;
     RS=1;
     LCD=dat;
     E=1;
     E=1;
     E=0;
     EA=ea;
if(bflag)
   lcdSetPage(y/8+1);
    if(pflag)
      if(i==62 || i==63)
        CS1=0;
        CS2=1;
        lcdSetPage(y/8+1);
        CS1=1;
        CS2=0;
        lcdSetPage(y/8+1);
     lcdSetColumn(i);
     ea=EA;
     EA=0;
     E=0;
     LCD=0xff;
     RS=1;
     RW=1;
     E=1;
     E=0;
     E=1;
     dat=LCD;
     E=0;
     if(flag==1)
       dat|=nextbit;
       dat&=~nextbit;
     lcdSetColumn(i);
     E=0;
     RW=0;
     RS=1;
     LCD=dat;
     E=1;
     E=1;
     E=0;
     EA=ea;
void lcdClear(void)  //清除
  uchar i,page;
  CS1=0;
  CS2=1;
  for(page=0;page<8;page++)
    lcdSetPage(page);
    lcdSetColumn(0);
    for(i=0;i<64;i++)
           lcdWriteByte(0);
  CS1=1;
  CS2=0;
    lcdSetPage(page);
    lcdSetColumn(0);
    for(i=0;i<64;i++)
           lcdWriteByte(0);
#define STAR 53
#define WIDE 6
void lcdIni(void)
lcdCmd(0x3f);   //顯示開
lcdCmd(0xc0);   // 起始行為第0行
lcdClear();
rectangle();
//NEXT
lcdPlayChar(11,0,STAR);
lcdPlayChar(12,0,STAR+1*WIDE);
lcdPlayChar(13,0,STAR+2*WIDE);
lcdPlayChar(14,0,STAR+3*WIDE);
//SPEED
lcdPlayChar(15,3,STAR);
lcdPlayChar(16,3,STAR+1*WIDE);
lcdPlayChar(17,3,STAR+2*WIDE);
lcdPlayChar(17,3,STAR+3*WIDE);
lcdPlayChar(18,3,STAR+4*WIDE);
//01
lcdPlayChar(0,4,STAR+2*WIDE);
lcdPlayChar(1,4,STAR+3*WIDE);
//SCORE
lcdPlayChar(15,5,STAR);
lcdPlayChar(19,5,STAR+1*WIDE);
lcdPlayChar(20,5,STAR+2*WIDE);
lcdPlayChar(21,5,STAR+3*WIDE);
lcdPlayChar(12,5,STAR+4*WIDE);
lcdPlayChar(0,6,STAR+1*WIDE);
lcdPlayChar(0,6,STAR+2*WIDE);
lcdPlayChar(0,6,STAR+3*WIDE);
lcdPlayChar(0,6,STAR+4*WIDE);
//TIME
lcdPlayChar(0,7,STAR);
lcdPlayChar(0,7,STAR+1*WIDE);
lcdPlayChar(10,7,STAR+2*WIDE);
lcdPlayChar(0,7,STAR+3*WIDE);
lcdPlayChar(0,7,STAR+4*WIDE);
void showScoreSpeed(void)   //顯示速度和分數
  uchar num[5];
  char i;
  uint temp;
  temp=score;
  for(i=0;i<5;i++)
     num[i]=temp%10;
         temp=temp/10;
  for(i=4;i>0;i--)
     if(num[i]==0)
          num[i]=22;
          break;
  for(i=4;i>-1;i--)
   lcdPlayChar(num[i],6,STAR+(4-i)*WIDE);
lcdPlayChar(speed/10,4,STAR+2*WIDE);
lcdPlayChar(speed%10,4,STAR+3*WIDE);
void timeServer(void)    //顯示時間
  if(timeupdate)
    timeupdate=0;
    lcdPlayChar(fen/10,7,STAR);
    lcdPlayChar(fen%10,7,STAR+1*WIDE);
    lcdPlayChar(miao/10,7,STAR+3*WIDE);
    lcdPlayChar(miao%10,7,STAR+4*WIDE);
  if(fashionupdate)
     fashionupdate=0;
     lcdPlayChar(22,7,STAR+2*WIDE);
void t0isr(void) interrupt 1    //T0中斷服務子函數
  uchar key;
  TH0=(65536-10000)/256;
  TL0=(65536-10000)%256;
  downtimegap++;
  t0ms=++t0ms%100;
  if(t0ms==0)
     timeupdate=1;
     miao=++miao%60;
         if(miao==0)
          fen=++fen%60;
  if(t0ms==50)
   fashionupdate=1;
  key=0xff;
  KEYLEFT=1;
  KEYRIGH=1;
  KEYROTATION=1;
  KEYDOWN=1;
  if(!KEYLEFT)
    key=0;
  if(!KEYRIGH)
    key=1;
  if(!KEYROTATION)
    key=2;
  if(!KEYDOWN)
    key=3;
switch(keystate)            //對按鍵狀態進行判斷
    case 0: if(key!=gkey)
                          gkey=key;
                          keystate=1;
                        break;
   case 1: if(key==gkey)
                           t0ms1=0;
                           keystate=2;
                           if(key!=0xff)
                             keyflag=1;
                     keystate=0;
                   break;
   case 2: if(key==gkey)
                           if(t0ms1<PUSHON)
                             t0ms1++;
                          keystate=0;
                          keyflag=0;
                          gkey=0xff;
                   break;
void showNextCube(uchar code * p,uchar x,uchar y)  //顯示下一個方塊
uchar i,j,temp;
  for(i=0;i<4;i++)
      temp=1;
      for(j=0;j<4;j++)
        if(p[i] & temp)
         lcdPutPix(x+j,y+i,1);
         lcdPutPix(x+j,y+i,0);
        temp<<=1;
void createCube(void)   // 生成一個方塊
  static uchar next;
  this.cube=next;
  next=TL0%7;
  this.row=0;
  this.column=6;
  this.state=0;
  this.box=cube+16*this.cube;
  showNextCube(cube+16*next,19,3);
void showCubeMap(void)   //顯示當前圖形
unsigned char hang,lie,temp;
for(hang=MAXHANG-1;hang>0;hang--)
   if(cubeMap[hang][0]==0 && cubeMap[hang][1]==0)
     break;
   for(lie=0;lie<(MAXLIE/8);lie++)
     temp=8*lie;
     if(cubeMap[hang][lie]&0x01)
       lcdPutPix(temp+1,hang,1);
     if(cubeMap[hang][lie]&0x02)
       lcdPutPix(temp+2,hang,1);
     if(cubeMap[hang][lie]&0x04)
       lcdPutPix(temp+3,hang,1);
     if(cubeMap[hang][lie]&0x08)
       lcdPutPix(temp+4,hang,1);
     if(cubeMap[hang][lie]&0x10)
       lcdPutPix(temp+5,hang,1);
     if(cubeMap[hang][lie]&0x20)
       lcdPutPix(temp+6,hang,1);
     if(cubeMap[hang][lie]&0x40)
       lcdPutPix(temp+7,hang,1);
     if(cubeMap[hang][lie]&0x80)
       lcdPutPix(temp+8,hang,1);
void writeCubeToMap(void)       //將當前方塊加入圖形
  uchar row,column,temp;
  uchar hang,lie;
  for(row=0;row<4;row++)
     temp=1;
     for(column=0;column<4;column++)
            if(this.box[row] & temp)
                   hang=this.row+row;
                   lie=this.column+column;
           cubeMap[hang][lie/8] |=bittable[lie%8];
               lcdPutPix(lie+1,hang,1);
                temp<<=1;
void clearCubeFromMap(void)    //從當前圖形中清除這個方塊
  uchar hang,lie;
     temp=1;
                   hang=this.row+row;
           cubeMap[hang][lie/8] &=~bittable[lie%8];
               lcdPutPix(lie+1,hang,0);
                temp<<=1;
uchar checkBorder(void)  //檢查當前方塊圖形是否達到了邊界,如果是則返回1,否則返回0
if(this.box[3]!=0 && this.row>(MAXHANG-4))
    return 1;
  else if(this.box[2]!=0 && this.row>(MAXHANG-3))
    return 1;
  else if(this.box[1]!=0 && this.row>(MAXHANG-2))
    return 1;
  else if(this.box[0]!=0 && this.row>(MAXHANG-1))
    return 1;
  if((this.box[0] & 0x01) || (this.box[1] & 0x01) || (this.box[2] & 0x01) ||(this.box[3] & 0x01) )
     if(this.column<0)
      return 1;
  else if((this.box[0] & 0x02) || (this.box[1] & 0x02) || (this.box[2] & 0x02) ||(this.box[3] & 0x02) )
     if(this.column<-1)
      return 1;
  else if((this.box[0] & 0x04) || (this.box[1] & 0x04) || (this.box[2] & 0x04) ||(this.box[3] & 0x04) )
     if(this.column<-2)
      return 1;
   else if((this.box[0] & 0x08) || (this.box[1] & 0x08) || (this.box[2] & 0x08) ||(this.box[3] & 0x08) )
     if(this.column<-3)
      return 1;
     if(this.column>(MAXLIE-4))
      return 1;
     if(this.column>(MAXLIE-3))
      return 1;
     if(this.column>(MAXLIE-2))
      return 1;
     if(this.column>(MAXLIE-1))
      return 1;
  return 0;
uchar checkClask(void)  //檢查是否要清除
  uchar hang,lie;
     temp=1;
                    hang=this.row+row;
                    if(cubeMap[hang][lie/8] & bittable[lie%8])
                          return 1;
                temp<<=1;
  return 0;
void checkMap(void)  //檢查當前的圖形邊緣
  uchar i,j,delete;
  bit full;
  full=0;
  delete=0;
  for(i=MAXHANG-1;i>0;i--)
     if(cubeMap[i][0]==0 && cubeMap[i][1]==0)
           break;
         if(cubeMap[i][0]==0xff && cubeMap[i][1]==0xff)
             delete++;
                 full=1;
                 for(j=i;j>0;j--)
                    cubeMap[j][0]=cubeMap[j-1][0];
                    cubeMap[j][1]=cubeMap[j-1][1];
                 i++;
                 cubeMap[0][0]=0;
                 cubeMap[0][1]=0;
if(full)
    if(delete==1)
          score++;
        else if(delete==2)
          score+=3;
        else if(delete==3)
          score+=8;
        else if(delete==4)
          score+=15;
        rectangle();
        showCubeMap();
    if(score<50)
         speed=1;
        else if(score<100)
         speed=2;
        else if(score<500)
         speed=3;
        else if(score<1000)
         speed=4;
        else if(score<5000)
         speed=5;
        else if(score<10000)
         speed=6;
        else if(score<20000)
         speed=7;
        else if(score<30000)
         speed=8;
        else if(score<40000)
         speed=9;
        else if(score<50000)
         speed=10;
        else if(score<60000)
         speed=11;
         speed=12;
        showScoreSpeed();
void moveLeft(void)   //控制游戲方塊向左移動
  clearCubeFromMap();
  this.column--;
  if(checkBorder() || checkClask())
    this.column++;
  writeCubeToMap();
void moveRigh(void)    //控制方塊向右移動
  clearCubeFromMap();
  this.column++;
    this.column--;
  writeCubeToMap();
void moveDown(void)    //向下快速移動方塊的函數
  clearCubeFromMap();
  this.row++;
    this.row--;
        downok=1;
   downok=0;
  writeCubeToMap();
  if(downok)
    checkMap();
void cubeRotation(void)    //方塊翻轉函數
  uchar temp;
  temp=this.state;
  clearCubeFromMap();
  this.state=++this.state%4;
  this.box=cube+16*this.cube+4*this.state;
     this.state=temp;
  writeCubeToMap();
void main(void)    //主函數
  TMOD=0x1;
  EA=1;
  ET0=1;
  TR0=1;
  lcdIni();
  for(t0ms=0;t0ms<MAXHANG;t0ms++)
     cubeMap[t0ms][0]=0;
     cubeMap[t0ms][1]=0;
     createCube();
         if(checkClask())
       rectangle();
#define SHOWSTAR 12
#define GAP 8
       lcdPlayChar(23,2,SHOWSTAR); //GAME
       lcdPlayChar(24,2,SHOWSTAR+GAP);
       lcdPlayChar(25,2,SHOWSTAR+2*GAP);
       lcdPlayChar(12,2,SHOWSTAR+3*GAP);
       lcdPlayChar(20,4,SHOWSTAR); //OVER
       lcdPlayChar(26,4,SHOWSTAR+GAP);
       lcdPlayChar(12,4,SHOWSTAR+2*GAP);
       lcdPlayChar(21,4,SHOWSTAR+3*GAP);
       t0ms=0;
       while(t0ms<95);//延時2秒
           t0ms=0;
       while(t0ms<95);
       ((void (code *) (void)) 0x0000) ( );
                timeServer();
            if(keyflag)
                   keyflag=0;
                   t0ms1=0;
                   if(gkey==0)
                     moveLeft();
                   if(gkey==1)
                     moveRigh();
                   if(gkey==2)
                     cubeRotation();
                   if(gkey==3)
                     moveDown();
       if(gkey==0 && t0ms1==PUSHON)
                  t0ms1-=10;
                  moveLeft();
       if(gkey==1 && t0ms1==PUSHON)
                  t0ms1-=10;
                  moveRigh();
       if(gkey==3 && t0ms1==PUSHON)
                  t0ms1-=10;
                  moveDown();
           if(downtimegap>(DOWNTIME-speed))
             moveDown();
                 downtimegap=0;
           if(downok)
                  downok=0;
                  break;
ID:636426 發表于 2019-11-12 21:25 | 顯示全部樓層
你好能不能發給我一份 ds12864-6的說明書,急用
