一個(gè)很高端的溫度傳感器
MLX90164引腳圖:
2018-5-28 03:09 上傳
2018-5-28 03:09 上傳
數(shù)據(jù)手冊(cè):
2 General Description
The MLX90614 is an Infra Red thermometer for non
contact temperature measurements. Both the IR sensitive
thermopile detector chip and the signal conditioning ASSP
are integrated in the same TO-39 can.
Thanks to its low noise amplifier, 17-bit ADC and
powerful DSP unit, a high accuracy and resolution of the
thermometer is achieved.
The thermometer comes factory calibrated with a digital
PWM and SMBus (System Management Bus) output.
As a standard, the 10-bit PWM is configured to
continuously transmit the measured temperature in range
of -20…120˚C, with an output resolution of 0.14˚C.
The factory default POR setting is SMBus.
Features and Benefits
Small size, low cost
Easy to integrate
Factory calibrated in wide temperature range:
-40…+125˚C for sensor temperature and
-70…+380˚C for object temperature.
High accuracy of 0.5° C over wide temperature
range (0…+50° C for both Ta and To)
High (medical) accuracy calibration
Measurement resolution of 0.02° C
Single and dual zone versions
SMBus compatible digital interface
Customizable PWM output for continuous
reading
Available in 3V and 5V versions
Simple adaptation for 8…16V applications
Sleep mode for reduced power consumption
Different package options for applications and
measurements versatility
Automotive grade
完整的pdf格式文檔51黑下載地址:
MLX90614.pdf
(4.57 MB, 下載次數(shù): 12)
2018-5-26 16:54 上傳
點(diǎn)擊文件名下載附件
溫度傳感器數(shù)據(jù)手冊(cè) 下載積分: 黑幣 -5
