查看: 4176|回復: 0
數碼管掃描單片機源碼(共陰極和共陽極)
3.hex為共陽極
另一個為共陰極
  1. #include<reg51.h>
  2. #define SEG P0
  3. unsigned char SMGD[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x83,0xf8,0x80,0x98}; //共陰極 段顯0~9
  4. unsigned char SMGW[]={0x01,0x02,0x04,0x08};        //位選1~4
  5. unsigned int n;
  6. void delay(unsigned int i)         //延時函數
  7. {
  8.         while(i--);
  9. }
  10. void main(void)         //主函數
  11. {
  12.         unsigned char Temp;
  13.         while(1)
  14.         {
  15.                 switch (Temp%4)
  16.                 {
  17.
  18.                         case 0:P0 = SMGD[Temp%10];break;
  19.                         case 1:P0 = SMGD[Temp%10];break;
  20.                         case 2:P0 = SMGD[Temp%10];break;
  21.                         case 3:P0 = SMGD[Temp%10];break;
  22.
  23.                 }
  24.                 P0 =SMGW[Temp%4];
  25.                 Temp++;
  26.                 delay(50000);
  27.          }
  28. }
數碼管掃描(共陰極和共陽極).zip (23.25 KB, 下載次數: 11)
