查看: 1805|回復: 0
PIC16F73產生SPWM波形
ID:335353 發表于 2018-5-21 23:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  • ; original File = C:\Users\前俊電子\Desktop\PIC16F73-2KW主板程序.txt
  •     processor 16F73
  •     #include <P16F73.INC>
  •     __config _CP_ALL & _BODEN_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC ; 0x3FAA
  • ;   __idlocs 0xFF, 0xFF, 0xFF, 0xFF
  • ; RAM-Variable
  • LRAM_0x20 equ 0x20
  • LRAM_0x22 equ 0x22
  • LRAM_0x25 equ 0x25
  • LRAM_0x26 equ 0x26
  • LRAM_0x27 equ 0x27
  • LRAM_0x29 equ 0x29
  • LRAM_0x30 equ 0x30
  • LRAM_0x31 equ 0x31
  • LRAM_0x32 equ 0x32
  • LRAM_0x33 equ 0x33
  • LRAM_0x34 equ 0x34
  • LRAM_0x35 equ 0x35
  • LRAM_0x36 equ 0x36
  • LRAM_0x37 equ 0x37
  • LRAM_0x38 equ 0x38
  • LRAM_0x39 equ 0x39
  • LRAM_0x3A equ 0x3A
  • LRAM_0x3C equ 0x3C
  • LRAM_0x3D equ 0x3D
  • LRAM_0x3E equ 0x3E
  • LRAM_0x3F equ 0x3F
  • LRAM_0x40 equ 0x40
  • LRAM_0x41 equ 0x41
  • LRAM_0x42 equ 0x42
  • LRAM_0x43 equ 0x43
  • LRAM_0x44 equ 0x44
  • LRAM_0x45 equ 0x45
  • LRAM_0x46 equ 0x46
  • LRAM_0x47 equ 0x47
  • LRAM_0x48 equ 0x48
  • LRAM_0x49 equ 0x49
  • LRAM_0x4A equ 0x4A
  • LRAM_0x4B equ 0x4B
  • LRAM_0x4C equ 0x4C
  • LRAM_0x4D equ 0x4D
  • LRAM_0x4E equ 0x4E
  • LRAM_0x4F equ 0x4F
  • LRAM_0x50 equ 0x50
  • LRAM_0x51 equ 0x51
  • LRAM_0x52 equ 0x52
  • LRAM_0x53 equ 0x53
  • LRAM_0x54 equ 0x54
  • LRAM_0x55 equ 0x55
  • LRAM_0x56 equ 0x56
  • LRAM_0x57 equ 0x57
  • LRAM_0x58 equ 0x58
  • LRAM_0x59 equ 0x59
  • LRAM_0x5A equ 0x5A
  • LRAM_0x5B equ 0x5B
  • LRAM_0x5C equ 0x5C
  • LRAM_0x5D equ 0x5D
  • LRAM_0x5E equ 0x5E
  • LRAM_0x5F equ 0x5F
  • LRAM_0x61 equ 0x61
  • LRAM_0x62 equ 0x62
  • LRAM_0x63 equ 0x63
  • LRAM_0x64 equ 0x64
  • LRAM_0x65 equ 0x65
  • LRAM_0x66 equ 0x66
  • LRAM_0x67 equ 0x67
  • LRAM_0x68 equ 0x68
  • LRAM_0x69 equ 0x69
  • LRAM_0x6A equ 0x6A
  • LRAM_0x6B equ 0x6B
  • LRAM_0x6C equ 0x6C
  • LRAM_0x6D equ 0x6D
  • LRAM_0x6E equ 0x6E
  • LRAM_0x71 equ 0x71
  • LRAM_0x74 equ 0x74
  • LRAM_0x77 equ 0x77
  • LRAM_0x79 equ 0x79
  • LRAM_0x7B equ 0x7B
  • LRAM_0x7D equ 0x7D
  • LRAM_0x7E equ 0x7E
  • LRAM_0x7F equ 0x7F
  • ; Program
  •     Org 0x0000
  • ;   Reset-Vector
  •     CLRF PCLATH          ; !!Bank Program-Page-Select
  •     GOTO LADR_0x0010     ; !!Bank!! 0x0010 - 0x0810
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  • ;   Interrupt-Vector
  •     GOTO LADR_0x04E7     ; !!Bank!! 0x04E7 - 0x0CE7
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  • LADR_0x0010
  •     BCF INTCON,GIE
  •     BCF STATUS,IRP
  •     BCF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  •     BSF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  •     MOVLW 0x02
  •     MOVWF TMR1L          ; !!Bank!! TMR1L - PCON - PMDATH - Unimplemented
  •     MOVLW 0x8F
  •     MOVWF TMR0           ; !!Bank!! TMR0 - OPTION_REG - TMR0 - OPTION_REG
  •     MOVLW 0x00
  •     MOVWF ADCON0         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  •     MOVLW 0xFF
  •     MOVWF PORTA          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  •     MOVLW 0x00
  •     MOVWF PORTB          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     MOVLW 0xF0
  •     MOVWF PORTC          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     MOVLW 0xF9
  •     MOVWF T2CON          ; !!Bank!! T2CON - PR2 - Unimplemented - Unimplemented
  •     BCF PIR1,1           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  •     BCF STATUS,RP0       ; !!Bank Register-Bank(0/1)-Select
  •     MOVLW 0x00
  •     MOVWF CCP1CON        ; !!Bank!! CCP1CON - Unimplemented - Unimplemented - Unimplemented
  •     MOVLW 0x00
  •     MOVWF CCPR1L         ; !!Bank!! CCPR1L - Unimplemented - Unimplemented - Unimplemented
  •     MOVLW 0x00
  •     MOVWF CCP2CON        ; !!Bank!! CCP2CON - Unimplemented - Unimplemented - Unimplemented
  •     MOVLW 0x00
  •     MOVWF CCPR2L         ; !!Bank!! CCPR2L - Unimplemented - Unimplemented - Unimplemented
  •     CLRF T2CON           ; !!Bank!! T2CON - PR2 - Unimplemented - Unimplemented
  •     BSF T2CON,2          ; !!Bank!! T2CON - PR2 - Unimplemented - Unimplemented
  •     MOVLW 0xFF
  •     MOVLW 0xBB
  •     MOVLW 0x39
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x36
  •     BSF PORTB,1          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BSF PORTB,6          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BSF PORTB,5          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BSF PORTB,7          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BSF PORTB,0          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  • LADR_0x003C
  •     BSF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     BCF PORTC,2          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     BCF PORTC,1          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     BSF PORTC,7          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     NOP
  •     NOP
  •     BTFSC PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     GOTO LADR_0x003C     ; !!Bank!! 0x003C - 0x083C
  •     NOP
  •     NOP
  •     DECFSZ LRAM_0x36,F
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x36
  • LADR_0x004A
  •     NOP
  •     NOP
  •     BTFSS PORTC,7        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     GOTO LADR_0x004A     ; !!Bank!! 0x004A - 0x084A
  •     NOP
  •     NOP
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x36
  •     CLRF LRAM_0x30
  •     CLRF LRAM_0x31
  •     CLRF LRAM_0x32
  •     CLRF LRAM_0x33
  •     CLRF LRAM_0x34
  •     CLRF LRAM_0x36
  •     CLRF LRAM_0x37
  •     CLRF LRAM_0x38
  •     CLRF LRAM_0x39
  •     CLRF LRAM_0x3A
  •     CLRF LRAM_0x3C
  •     CLRF LRAM_0x3D
  •     CLRF LRAM_0x3E
  •     CLRF LRAM_0x3F
  •     CLRF LRAM_0x40
  •     CLRF LRAM_0x41
  •     CLRF LRAM_0x42
  •     CLRF LRAM_0x43
  •     CLRF LRAM_0x44
  •     CLRF LRAM_0x45
  •     CLRF LRAM_0x46
  •     CLRF LRAM_0x47
  •     CLRF LRAM_0x48
  •     CLRF LRAM_0x49
  •     CLRF LRAM_0x4A
  •     CLRF LRAM_0x4B
  •     CLRF LRAM_0x4C
  •     CLRF LRAM_0x4D
  •     CLRF LRAM_0x4E
  •     CLRF LRAM_0x4F
  •     CLRF LRAM_0x50
  •     CLRF LRAM_0x52
  •     CLRF LRAM_0x53
  •     CLRF LRAM_0x54
  •     CLRF LRAM_0x55
  •     CLRF LRAM_0x6B
  •     CLRF LRAM_0x6C
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x6A
  •     MOVLW 0x50
  •     MOVWF LRAM_0x56
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x57
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x58
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x59
  •     MOVLW 0x9D
  •     MOVWF LRAM_0x5A
  •     MOVLW 0x01
  •     MOVWF LRAM_0x61
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5B
  •     BCF LRAM_0x63,0
  •     BCF LRAM_0x63,1
  •     BCF LRAM_0x63,2
  •     MOVLW 0x00
  •     MOVWF LRAM_0x64
  •     MOVLW 0x40
  •     MOVWF LRAM_0x65
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5C
  •     MOVLW 0x00
  •     MOVWF LRAM_0x5D
  • LADR_0x0098
  •     MOVLW 0xA0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVLW 0x00
  •     MOVWF INDF
  •     MOVLW 0xD0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVLW 0x20
  •     MOVWF INDF
  •     INCF LRAM_0x5D,F
  •     DECFSZ LRAM_0x5C,F
  •     GOTO LADR_0x0098     ; !!Bank!! 0x0098 - 0x0898
  •     NOP
  •     BCF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     BCF LRAM_0x37,0
  •     BSF LRAM_0x38,0
  •     CALL LADR_0x04E2     ; !!Bank!! 0x04E2 - 0x0CE2
  •     NOP
  •     NOP
  • LADR_0x00B1
  •     NOP
  •     BCF PORTB,1          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BCF PORTC,0          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     NOP
  •     BTFSS LRAM_0x6A,6
  •     GOTO LADR_0x00C6     ; !!Bank!! 0x00C6 - 0x08C6
  •     NOP
  •     BSF PORTC,6          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     NOP
  •     NOP
  •     BTFSS PORTC,6        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     GOTO LADR_0x00C1     ; !!Bank!! 0x00C1 - 0x08C1
  •     CLRF LRAM_0x6B
  •     BSF LRAM_0x6A,6
  •     GOTO LADR_0x00D3     ; !!Bank!! 0x00D3 - 0x08D3
  • LADR_0x00C1
  •     DECFSZ LRAM_0x6B,F
  •     CLRF LRAM_0x6B
  •     BCF LRAM_0x6A,6
  • LADR_0x00C6
  •     NOP
  •     NOP
  •     BTFSC PORTC,6        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     GOTO LADR_0x00CE     ; !!Bank!! 0x00CE - 0x08CE
  •     CLRF LRAM_0x6B
  •     BCF LRAM_0x6A,6
  • LADR_0x00CE
  •     CLRF LRAM_0x6B
  •     BSF LRAM_0x6A,6
  • LADR_0x00D3
  •     NOP
  •     BTFSS LRAM_0x6A,5
  •     GOTO LADR_0x00E6     ; !!Bank!! 0x00E6 - 0x08E6
  •     NOP
  •     BSF PORTC,5          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     NOP
  •     NOP
  •     BTFSS PORTC,5        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     GOTO LADR_0x00E0     ; !!Bank!! 0x00E0 - 0x08E0
  •     CLRF LRAM_0x6C
  •     BSF LRAM_0x6A,5
  •     GOTO LADR_0x00F5     ; !!Bank!! 0x00F5 - 0x08F5
  • LADR_0x00E0
  •     DECFSZ LRAM_0x6C,F
  •     CLRF LRAM_0x6C
  •     BCF LRAM_0x6A,5
  •     BCF PORTB,0          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  • LADR_0x00E6
  •     NOP
  •     NOP
  •     BTFSC PORTC,5        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     GOTO LADR_0x00EF     ; !!Bank!! 0x00EF - 0x08EF
  •     CLRF LRAM_0x6C
  •     BCF LRAM_0x6A,5
  • LADR_0x00EF
  •     CLRF LRAM_0x6C
  •     BSF LRAM_0x6A,5
  • LADR_0x00F5
  •     NOP
  •     GOTO LADR_0x0109     ; !!Bank!! 0x0109 - 0x0909
  •     NOP
  •     DECFSZ LRAM_0x57,F
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x57
  •     DECFSZ LRAM_0x58,F
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x58
  •     DECFSZ LRAM_0x59,F
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x59
  •     DECFSZ LRAM_0x5A,F
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x5A
  • LADR_0x0109
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x54
  •     BSF PORTC,4          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     NOP
  •     NOP
  •     BTFSS PORTC,4        ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  •     GOTO LADR_0x0114     ; !!Bank!! 0x0114 - 0x0914
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x53
  •     MOVWF LRAM_0x55
  •     GOTO LADR_0x0147     ; !!Bank!! 0x0147 - 0x0947
  • LADR_0x0114
  •     DECFSZ LRAM_0x53,F
  •     NOP
  • LADR_0x0117
  •     NOP
  •     CLRF LRAM_0x54
  • LADR_0x0119
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     MOVLW 0x00
  •     MOVWF T1CON          ; !!Bank!! T1CON - Unimplemented - Unimplemented - Unimplemented
  •     MOVLW 0x00
  •     MOVLW 0x8B
  •     MOVWF TMR1H          ; !!Bank!! TMR1H - Unimplemented - PMADRH - Unimplemented
  •     NOP
  •     BCF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BSF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BCF PORTB,5          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     NOP
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     NOP
  •     NOP
  •     GOTO LADR_0x0117     ; !!Bank!! 0x0117 - 0x0917
  •     NOP
  •     DECFSZ LRAM_0x54,F
  •     GOTO LADR_0x0119     ; !!Bank!! 0x0119 - 0x0919
  • LADR_0x013F
  •     NOP
  •     NOP
  •     GOTO LADR_0x013F     ; !!Bank!! 0x013F - 0x093F
  •     NOP
  •     NOP
  • LADR_0x0147
  •     NOP
  •     NOP
  •     NOP
  •     GOTO LADR_0x0150     ; !!Bank!! 0x0150 - 0x0950
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x36
  •     GOTO LADR_0x016F     ; !!Bank!! 0x016F - 0x096F
  • LADR_0x0150
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     NOP
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  • LADR_0x0165
  •     NOP
  •     NOP
  •     GOTO LADR_0x0165     ; !!Bank!! 0x0165 - 0x0965
  •     NOP
  • LADR_0x016F
  •     NOP
  •     MOVLW 0xC1
  •     BSF ADCON0,2         ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  • LADR_0x0175
  •     BTFSC ADCON0,2       ; !!Bank!! ADCON0 - ADCON1 - Unimplemented - Unimplemented
  •     GOTO LADR_0x0175     ; !!Bank!! 0x0175 - 0x0975
  •     MOVF ADRES,W         ; !!Bank!! ADRES - Unimplemented - Unimplemented - Unimplemented
  •     ADDWF LRAM_0x30,F
  •     MOVF STATUS,W
  •     MOVWF LRAM_0x35
  •     RRF LRAM_0x30,F
  •     BTFSS LRAM_0x35,0
  •     GOTO LADR_0x0181     ; !!Bank!! 0x0181 - 0x0981
  •     BSF LRAM_0x30,7
  •     GOTO LADR_0x0183     ; !!Bank!! 0x0183 - 0x0983
  • LADR_0x0181
  •     BCF LRAM_0x30,7
  • LADR_0x0183
  •     NOP
  •     MOVLW 0xC9
  • LADR_0x0189
  •     GOTO LADR_0x0189     ; !!Bank!! 0x0189 - 0x0989
  •     ADDWF LRAM_0x31,F
  •     MOVF STATUS,W
  •     MOVWF LRAM_0x35
  •     RRF LRAM_0x31,F
  •     BTFSS LRAM_0x35,0
  •     GOTO LADR_0x0195     ; !!Bank!! 0x0195 - 0x0995
  •     BSF LRAM_0x31,7
  •     GOTO LADR_0x0197     ; !!Bank!! 0x0197 - 0x0997
  • LADR_0x0195
  •     BCF LRAM_0x31,7
  • LADR_0x0197
  •     NOP
  •     MOVLW 0xD1
  • LADR_0x019C
  •     GOTO LADR_0x019C     ; !!Bank!! 0x019C - 0x099C
  •     ADDWF LRAM_0x32,F
  •     MOVF STATUS,W
  •     MOVWF LRAM_0x35
  •     RRF LRAM_0x32,F
  •     BTFSS LRAM_0x35,0
  •     GOTO LADR_0x01A7     ; !!Bank!! 0x01A7 - 0x09A7
  •     BSF LRAM_0x32,7
  •     GOTO LADR_0x01A9     ; !!Bank!! 0x01A9 - 0x09A9
  • LADR_0x01A7
  •     BCF LRAM_0x32,7
  • LADR_0x01A9
  •     NOP
  •     MOVLW 0xD9
  • LADR_0x01AE
  •     GOTO LADR_0x01AE     ; !!Bank!! 0x01AE - 0x09AE
  •     ADDWF LRAM_0x33,F
  •     MOVF STATUS,W
  •     MOVWF LRAM_0x35
  •     RRF LRAM_0x33,F
  •     BTFSS LRAM_0x35,0
  •     GOTO LADR_0x01B9     ; !!Bank!! 0x01B9 - 0x09B9
  •     BSF LRAM_0x33,7
  •     GOTO LADR_0x01BB     ; !!Bank!! 0x01BB - 0x09BB
  • LADR_0x01B9
  •     BCF LRAM_0x33,7
  • LADR_0x01BB
  •     NOP
  •     MOVLW 0xE1
  • LADR_0x01C0
  •     GOTO LADR_0x01C0     ; !!Bank!! 0x01C0 - 0x09C0
  •     ADDWF LRAM_0x34,F
  •     MOVF STATUS,W
  •     MOVWF LRAM_0x35
  •     RRF LRAM_0x34,F
  •     BTFSS LRAM_0x35,0
  •     GOTO LADR_0x01CB     ; !!Bank!! 0x01CB - 0x09CB
  •     BSF LRAM_0x34,7
  •     GOTO LADR_0x01CD     ; !!Bank!! 0x01CD - 0x09CD
  • LADR_0x01CB
  •     BCF LRAM_0x34,7
  • LADR_0x01CD
  •     NOP
  •     BTFSC LRAM_0x37,0
  •     GOTO LADR_0x01E9     ; !!Bank!! 0x01E9 - 0x09E9
  •     NOP
  •     BCF PORTB,7          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BTFSS LRAM_0x6A,6
  •     GOTO LADR_0x027B     ; !!Bank!! 0x027B - 0x0A7B
  •     NOP
  •     BTFSC LRAM_0x38,0
  •     GOTO LADR_0x0247     ; !!Bank!! 0x0247 - 0x0A47
  •     NOP
  •     MOVLW 0x46
  •     SUBWF LRAM_0x30,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x01E0     ; !!Bank!! 0x01E0 - 0x09E0
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x49
  •     GOTO LADR_0x01E4     ; !!Bank!! 0x01E4 - 0x09E4
  • LADR_0x01E0
  •     DECFSZ LRAM_0x49,F
  •     NOP
  • LADR_0x01E4
  •     NOP
  •     BTFSC LRAM_0x38,1
  •     GOTO LADR_0x02B8     ; !!Bank!! 0x02B8 - 0x0AB8
  •     NOP
  •     GOTO LADR_0x036A     ; !!Bank!! 0x036A - 0x0B6A
  • LADR_0x01E9
  •     BTFSS LRAM_0x6A,6
  •     GOTO LADR_0x01FE     ; !!Bank!! 0x01FE - 0x09FE
  •     MOVLW 0x4E
  •     SUBWF LRAM_0x30,W
  •     BTFSS STATUS,C
  •     NOP
  •     GOTO LADR_0x0202     ; !!Bank!! 0x0202 - 0x0A02
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x49
  •     DECFSZ LRAM_0x4C,F
  •     NOP
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x6D
  •     MOVLW 0x60
  •     MOVWF LRAM_0x6E
  •     NOP
  •     GOTO LADR_0x0208     ; !!Bank!! 0x0208 - 0x0A08
  • LADR_0x01FE
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x49
  •     MOVLW 0x80
  •     MOVWF LRAM_0x4C
  • LADR_0x0202
  •     NOP
  •     BTFSC LRAM_0x3A,0
  •     GOTO LADR_0x03BC     ; !!Bank!! 0x03BC - 0x0BBC
  •     NOP
  •     GOTO LADR_0x04B4     ; !!Bank!! 0x04B4 - 0x0CB4
  •     NOP
  • LADR_0x0208
  •     NOP
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     BSF PORTB,2          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     BCF LRAM_0x37,0
  •     BSF LRAM_0x38,0
  •     NOP
  •     NOP
  •     DECFSZ LRAM_0x6D,F
  •     NOP
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x6D
  •     DECFSZ LRAM_0x6E,F
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x6D
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x6E
  • LADR_0x022C
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     NOP
  •     NOP
  •     NOP
  •     GOTO LADR_0x022C     ; !!Bank!! 0x022C - 0x0A2C
  •     NOP
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x6D
  •     NOP
  •     GOTO LADR_0x04E0     ; !!Bank!! 0x04E0 - 0x0CE0
  • LADR_0x0247
  •     NOP
  •     DECFSZ LRAM_0x3E,F
  •     MOVLW 0x46
  •     SUBWF LRAM_0x30,W
  •     BTFSS STATUS,C
  •     MOVLW 0x04
  •     MOVWF LRAM_0x3E
  •     BCF LRAM_0x37,0
  •     BCF LRAM_0x38,0
  •     BSF LRAM_0x38,1
  •     MOVLW 0x00
  •     MOVWF LRAM_0x3C
  •     MOVLW 0x80
  •     MOVWF LRAM_0x3D
  •     MOVLW 0x00
  •     MOVWF LRAM_0x68
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x69
  • LADR_0x0260
  •     BSF PORTA,4          ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  •     NOP
  •     BTFSC PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  •     GOTO LADR_0x0260     ; !!Bank!! 0x0260 - 0x0A60
  •     NOP
  • LADR_0x0265
  •     NOP
  •     BTFSS PORTA,4        ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
  •     GOTO LADR_0x0265     ; !!Bank!! 0x0265 - 0x0A65
  •     NOP
  • LADR_0x026A
  •     NOP
  •     GOTO LADR_0x026A     ; !!Bank!! 0x026A - 0x0A6A
  •     NOP
  • LADR_0x026F
  •     NOP
  •     GOTO LADR_0x026F     ; !!Bank!! 0x026F - 0x0A6F
  •     NOP
  • LADR_0x0274
  •     NOP
  •     GOTO LADR_0x0274     ; !!Bank!! 0x0274 - 0x0A74
  •     BCF LRAM_0x39,0
  •     BSF LRAM_0x39,1
  • LADR_0x027B
  •     NOP
  •     BSF LRAM_0x37,0
  •     BSF LRAM_0x3A,0
  •     BSF LRAM_0x3F,1
  •     BCF LRAM_0x3F,0
  •     BCF LRAM_0x3F,2
  •     MOVLW 0x01
  •     MOVLW 0xFE
  •     MOVLW 0x0B
  •     MOVLW 0x01
  •     MOVWF LRAM_0x61
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5B
  •     BCF LRAM_0x63,0
  •     BCF LRAM_0x63,1
  •     BCF LRAM_0x63,2
  •     MOVLW 0x00
  •     MOVWF LRAM_0x64
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5C
  •     MOVLW 0x00
  •     MOVWF LRAM_0x5D
  • LADR_0x0299
  •     MOVLW 0xA0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVLW 0x00
  •     MOVWF INDF
  •     MOVLW 0xD0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVLW 0x20
  •     MOVWF INDF
  •     INCF LRAM_0x5D,F
  •     GOTO LADR_0x0299     ; !!Bank!! 0x0299 - 0x0A99
  •     NOP
  •     MOVLW 0x3C
  •     MOVLW 0x00
  •     MOVLW 0x3C
  •     MOVLW 0x00
  •     NOP
  •     BSF PIR1,0           ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  •     BSF INTCON,PEIE
  •     BSF INTCON,GIE
  •     NOP
  • LADR_0x02B8
  •     MOVLW 0x94
  •     SUBWF LRAM_0x32,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x02C8     ; !!Bank!! 0x02C8 - 0x0AC8
  •     NOP
  •     DECFSZ LRAM_0x4B,F
  •     GOTO LADR_0x02CA     ; !!Bank!! 0x02CA - 0x0ACA
  •     BCF LRAM_0x37,0
  •     BCF LRAM_0x38,0
  •     BCF LRAM_0x38,1
  • LADR_0x02C8
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x4B
  • LADR_0x02CA
  •     NOP
  •     NOP
  •     GOTO LADR_0x0309     ; !!Bank!! 0x0309 - 0x0B09
  •     MOVLW 0x04
  •     MOVWF LRAM_0x3E
  •     MOVLW 0x99
  •     SUBWF LRAM_0x33,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x02DA     ; !!Bank!! 0x02DA - 0x0ADA
  •     NOP
  • LADR_0x02DA
  •     MOVLW 0x8A
  •     SUBWF LRAM_0x32,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x02E0     ; !!Bank!! 0x02E0 - 0x0AE0
  •     NOP
  •     GOTO LADR_0x02E8     ; !!Bank!! 0x02E8 - 0x0AE8
  • LADR_0x02E0
  •     MOVLW 0x33
  •     SUBWF LRAM_0x33,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x02E6     ; !!Bank!! 0x02E6 - 0x0AE6
  •     NOP
  • LADR_0x02E6
  •     NOP
  •     GOTO LADR_0x02F9     ; !!Bank!! 0x02F9 - 0x0AF9
  • LADR_0x02E8
  •     MOVLW 0x01
  •     SUBWF LRAM_0x3C,F
  •     BTFSC STATUS,C
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x3C
  •     MOVLW 0x01
  •     SUBWF LRAM_0x3D,F
  •     MOVLW 0x8B
  •     SUBWF LRAM_0x3D,W
  •     BTFSC STATUS,C
  •     MOVLW 0x00
  •     MOVWF LRAM_0x3C
  •     MOVLW 0x8B
  •     MOVWF LRAM_0x3D
  • LADR_0x02F9
  •     MOVLW 0x01
  •     ADDWF LRAM_0x3C,F
  •     BTFSS STATUS,C
  •     MOVLW 0x01
  •     ADDWF LRAM_0x3D,F
  •     MOVLW 0xC5
  •     SUBWF LRAM_0x3D,W
  •     BTFSS STATUS,C
  •     NOP
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x3C
  •     MOVLW 0xC4
  •     MOVWF LRAM_0x3D
  • LADR_0x0309
  •     BTFSS LRAM_0x39,0
  •     GOTO LADR_0x033B     ; !!Bank!! 0x033B - 0x0B3B
  •     NOP
  •     NOP
  •     BTFSC LRAM_0x39,1
  •     GOTO LADR_0x0327     ; !!Bank!! 0x0327 - 0x0B27
  •     NOP
  •     BTFSS LRAM_0x68,5
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     BCF LRAM_0x68,5
  •     BSF LRAM_0x39,0
  •     BSF LRAM_0x39,1
  • LADR_0x0327
  •     NOP
  •     NOP
  •     MOVLW 0x01
  •     MOVF LRAM_0x3D,W
  •     MOVF LRAM_0x3C,W
  •     NOP
  •     BSF INTCON,PEIE
  •     BSF INTCON,GIE
  •     BCF LRAM_0x39,0
  •     BCF LRAM_0x39,1
  • LADR_0x033B
  •     NOP
  •     BTFSC LRAM_0x39,1
  •     GOTO LADR_0x0356     ; !!Bank!! 0x0356 - 0x0B56
  •     NOP
  •     BTFSS LRAM_0x68,5
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     NOP
  •     BCF LRAM_0x68,5
  •     BCF LRAM_0x39,0
  •     BSF LRAM_0x39,1
  • LADR_0x0356
  •     NOP
  •     NOP
  •     MOVLW 0x01
  •     MOVF LRAM_0x3D,W
  •     MOVF LRAM_0x3C,W
  •     NOP
  •     BSF INTCON,PEIE
  •     BSF INTCON,GIE
  •     BSF LRAM_0x39,0
  •     BCF LRAM_0x39,1
  • LADR_0x036A
  •     MOVLW 0x9E
  •     SUBWF LRAM_0x32,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x0394     ; !!Bank!! 0x0394 - 0x0B94
  •     NOP
  •     DECFSZ LRAM_0x4D,F
  •     GOTO LADR_0x0396     ; !!Bank!! 0x0396 - 0x0B96
  •     NOP
  • LADR_0x0372
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x8B
  •     NOP
  •     NOP
  •     NOP
  •     GOTO LADR_0x038B     ; !!Bank!! 0x038B - 0x0B8B
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x36
  •     GOTO LADR_0x0372     ; !!Bank!! 0x0372 - 0x0B72
  • LADR_0x038B
  • LADR_0x038D
  •     NOP
  •     NOP
  •     GOTO LADR_0x038D     ; !!Bank!! 0x038D - 0x0B8D
  •     NOP
  • LADR_0x0394
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x4D
  • LADR_0x0396
  •     MOVLW 0x80
  •     SUBWF LRAM_0x32,W
  •     BTFSC STATUS,C
  •     GOTO LADR_0x03A0     ; !!Bank!! 0x03A0 - 0x0BA0
  •     NOP
  •     GOTO LADR_0x03A2     ; !!Bank!! 0x03A2 - 0x0BA2
  •     BCF LRAM_0x37,0
  •     BSF LRAM_0x38,0
  • LADR_0x03A0
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x4B
  • LADR_0x03A2
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x8B
  •     NOP
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  • LADR_0x03BC
  •     NOP
  •     MOVLW 0xCC
  •     SUBWF LRAM_0x34,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x03DE     ; !!Bank!! 0x03DE - 0x0BDE
  • LADR_0x03C3
  •     NOP
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     BSF LRAM_0x3A,7
  •     BSF LRAM_0x37,0
  •     BCF LRAM_0x3A,0
  • LADR_0x03DE
  •     MOVLW 0x66
  •     SUBWF LRAM_0x34,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x03EE     ; !!Bank!! 0x03EE - 0x0BEE
  •     NOP
  •     DECFSZ LRAM_0x4F,F
  •     GOTO LADR_0x03F2     ; !!Bank!! 0x03F2 - 0x0BF2
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x4F
  •     DECFSZ LRAM_0x50,F
  •     NOP
  •     BSF LRAM_0x3A,7
  •     BSF LRAM_0x37,0
  •     BCF LRAM_0x3A,0
  • LADR_0x03EE
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x4F
  •     MOVLW 0x64
  •     MOVWF LRAM_0x50
  • LADR_0x03F2
  •     BTFSS LRAM_0x6A,5
  •     GOTO LADR_0x0401     ; !!Bank!! 0x0401 - 0x0C01
  •     MOVLW 0x62
  •     SUBWF LRAM_0x32,W
  •     BTFSC STATUS,C
  •     NOP
  •     DECFSZ LRAM_0x4A,F
  •     GOTO LADR_0x0403     ; !!Bank!! 0x0403 - 0x0C03
  •     NOP
  •     BCF LRAM_0x3A,7
  •     BSF LRAM_0x37,0
  •     BCF LRAM_0x3A,0
  • LADR_0x0401
  •     MOVLW 0xFF
  •     MOVWF LRAM_0x4A
  • LADR_0x0403
  •     BTFSS LRAM_0x63,0
  •     GOTO LADR_0x00B1     ; !!Bank!! 0x00B1 - 0x08B1
  •     NOP
  •     BCF LRAM_0x63,0
  •     DECFSZ LRAM_0x65,F
  •     MOVLW 0xA0
  •     MOVWF LRAM_0x56
  •     GOTO LADR_0x0410     ; !!Bank!! 0x0410 - 0x0C10
  •     DECFSZ LRAM_0x56,F
  •     NOP
  •     GOTO LADR_0x03C3     ; !!Bank!! 0x03C3 - 0x0BC3
  • LADR_0x0410
  •     MOVLW 0x02
  •     MOVWF LRAM_0x65
  •     MOVLW 0xD0
  •     SUBWF LRAM_0x31,W
  •     BTFSC STATUS,C
  •     GOTO LADR_0x0430     ; !!Bank!! 0x0430 - 0x0C30
  •     MOVLW 0xC0
  •     SUBWF LRAM_0x31,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x0472     ; !!Bank!! 0x0472 - 0x0C72
  •     MOVLW 0xC8
  •     SUBWF LRAM_0x31,W
  •     BTFSS STATUS,C
  •     GOTO LADR_0x0427     ; !!Bank!! 0x0427 - 0x0C27
  •     NOP
  •     MOVLW 0x10
  •     MOVWF LRAM_0x66
  •     DECFSZ LRAM_0x67,F
  •     MOVLW 0x10
  •     MOVWF LRAM_0x67
  •     MOVWF LRAM_0x66
  • LADR_0x0427
  •     NOP
  •     MOVLW 0x10
  •     MOVWF LRAM_0x67
  •     DECFSZ LRAM_0x66,F
  •     MOVLW 0x10
  •     MOVWF LRAM_0x66
  •     MOVWF LRAM_0x67
  • LADR_0x0430
  •     MOVLW 0x10
  •     SUBWF LRAM_0x64,W
  •     BTFSS STATUS,C
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     DECF LRAM_0x64,F
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5C
  •     MOVLW 0x00
  •     MOVWF LRAM_0x5D
  • LADR_0x043E
  •     MOVLW 0x08
  •     BSF STATUS,RP1       ; !!Bank Register-Bank(2/3)-Select
  •     MOVF LRAM_0x5D,W
  •     MOVWF PIR2           ; !!Bank!! PIR2 - PIE2 - PMADR - Unimplemented
  •     NOP
  •     NOP
  •     MOVF PIR1,W          ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  •     MOVWF LRAM_0x5E
  •     BCF STATUS,IRP
  •     MOVLW 0xA0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVF INDF,W
  •     MOVWF LRAM_0x5F
  •     MOVF LRAM_0x5E,W
  •     BCF STATUS,C
  •     SUBWF LRAM_0x5F,F
  •     BTFSC STATUS,C
  •     GOTO LADR_0x0462     ; !!Bank!! 0x0462 - 0x0C62
  •     BCF STATUS,IRP
  •     MOVLW 0xD0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     DECF INDF,F
  • LADR_0x0462
  •     BCF STATUS,IRP
  •     MOVLW 0xA0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVF LRAM_0x5F,W
  •     MOVWF INDF
  •     INCF LRAM_0x5D,F
  •     GOTO LADR_0x043E     ; !!Bank!! 0x043E - 0x0C3E
  •     NOP
  •     BSF INTCON,PEIE
  •     BSF INTCON,GIE
  • LADR_0x0472
  •     MOVLW 0xD0
  •     SUBWF LRAM_0x64,W
  •     BTFSC STATUS,C
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     INCF LRAM_0x64,F
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5C
  •     MOVLW 0x00
  •     MOVWF LRAM_0x5D
  • LADR_0x0480
  •     MOVLW 0x08
  •     MOVF LRAM_0x5D,W
  •     NOP
  •     NOP
  •     MOVWF LRAM_0x5E
  •     BCF STATUS,IRP
  •     MOVLW 0xA0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVF INDF,W
  •     MOVWF LRAM_0x5F
  •     MOVF LRAM_0x5E,W
  •     BCF STATUS,C
  •     ADDWF LRAM_0x5F,F
  •     BTFSS STATUS,C
  •     GOTO LADR_0x04A4     ; !!Bank!! 0x04A4 - 0x0CA4
  •     BCF STATUS,IRP
  •     MOVLW 0xD0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     INCF INDF,F
  • LADR_0x04A4
  •     BCF STATUS,IRP
  •     MOVLW 0xA0
  •     ADDWF LRAM_0x5D,W
  •     MOVWF FSR
  •     MOVF LRAM_0x5F,W
  •     MOVWF INDF
  •     INCF LRAM_0x5D,F
  •     GOTO LADR_0x0480     ; !!Bank!! 0x0480 - 0x0C80
  •     NOP
  •     BSF INTCON,PEIE
  •     BSF INTCON,GIE
  • LADR_0x04B4
  •     NOP
  •     NOP
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x8B
  •     NOP
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     BSF LRAM_0x37,0
  •     BCF LRAM_0x3A,0
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     MOVLW 0x00
  •     BTFSS LRAM_0x3A,7
  •     GOTO LADR_0x04DE     ; !!Bank!! 0x04DE - 0x0CDE
  •     NOP
  •     BCF PORTB,6          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  • LADR_0x04DE
  •     NOP
  • LADR_0x04E0
  •     NOP
  • LADR_0x04E2
  •     MOVLW 0x0F
  •     MOVWF LRAM_0x20
  • LADR_0x04E4
  •     DECFSZ LRAM_0x20,F
  •     GOTO LADR_0x04E4     ; !!Bank!! 0x04E4 - 0x0CE4
  •     RETURN
  • LADR_0x04E7
  •     MOVWF LRAM_0x25
  •     MOVF STATUS,W
  •     MOVWF LRAM_0x26
  •     MOVF FSR,W
  •     MOVWF LRAM_0x27
  •     BTFSS PIR1,0         ; !!Bank!! PIR1 - PIE1 - PMDATA - PMCON
  •     GOTO LADR_0x0549     ; !!Bank!! 0x0549 - 0x0D49
  •     CLRWDT
  •     BTFSC LRAM_0x37,0
  •     GOTO LADR_0x0512     ; !!Bank!! 0x0512 - 0x0D12
  •     NOP
  •     BTFSC LRAM_0x68,0
  •     GOTO LADR_0x0507     ; !!Bank!! 0x0507 - 0x0D07
  •     NOP
  •     DECFSZ LRAM_0x69,F
  •     GOTO LADR_0x04FC     ; !!Bank!! 0x04FC - 0x0CFC
  •     NOP
  • LADR_0x04FC
  •     BCF LRAM_0x68,0
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     BSF LRAM_0x68,5
  •     MOVLW 0x00
  • LADR_0x0507
  •     BSF LRAM_0x68,0
  •     BCF INTCON,PEIE
  •     BCF INTCON,GIE
  •     BCF PORTB,3          ; !!Bank!! PORTB - TRISB - PORTB - TRISB
  •     BSF LRAM_0x68,5
  •     MOVLW 0x00
  • LADR_0x0512
  •     MOVLW 0xFE
  •     MOVLW 0x25
  •     BTFSS LRAM_0x63,1
  •     GOTO LADR_0x052E     ; !!Bank!! 0x052E - 0x0D2E
  •     NOP
  •     DECFSZ LRAM_0x5B,F
  •     GOTO LADR_0x0527     ; !!Bank!! 0x0527 - 0x0D27
  •     MOVLW 0x00
  •     MOVWF LRAM_0x61
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5B
  •     BCF LRAM_0x63,1
  •     BTFSS LRAM_0x63,2
  •     GOTO LADR_0x0524     ; !!Bank!! 0x0524 - 0x0D24
  •     BCF LRAM_0x63,2
  •     GOTO LADR_0x0537     ; !!Bank!! 0x0537 - 0x0D37
  • LADR_0x0524
  •     BSF LRAM_0x63,2
  •     BCF PORTC,3          ; !!Bank!! PORTC - TRISC - Unimplemented - Unimplemented
  • LADR_0x0527
  •     MOVLW 0xD0
  •     ADDWF LRAM_0x61,W
  •     MOVWF FSR
  •     MOVF INDF,W
  •     MOVWF LRAM_0x62
  •     DECF LRAM_0x61,F
  •     GOTO LADR_0x053E     ; !!Bank!! 0x053E - 0x0D3E
  • LADR_0x052E
  •     MOVLW 0x27
  •     MOVWF LRAM_0x61
  •     MOVLW 0x28
  •     MOVWF LRAM_0x5B
  •     BSF LRAM_0x63,1
  •     BSF LRAM_0x63,0
  • LADR_0x0537
  •     MOVLW 0xD0
  •     ADDWF LRAM_0x61,W
  •     MOVWF FSR
  •     MOVF INDF,W
  •     MOVWF LRAM_0x62
  •     INCF LRAM_0x61,F
  • LADR_0x053E
  •     BTFSS LRAM_0x63,2
  •     GOTO LADR_0x0545     ; !!Bank!! 0x0545 - 0x0D45
  •     MOVF LRAM_0x62,W
  •     MOVLW 0x00
  • LADR_0x0545
  •     MOVF LRAM_0x62,W
  •     MOVLW 0x00
  • LADR_0x0549
  •     MOVF LRAM_0x27,W
  •     MOVWF FSR
  •     MOVF LRAM_0x26,W
  •     MOVWF STATUS
  •     MOVF LRAM_0x25,W
  •     RETFIE
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  •     ADDLW 0xFF
  • …………限于本文篇幅 余下代碼請從51黑下載附件…………
