只需一步,快速開(kāi)始
查看: 1856|回復(fù): 0
搶答器
ID:332040 發(fā)表于 2018-5-20 12:46 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
sbit k1=P1^0;
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
sbit k5=P1^4;
sbit k6=P1^5;
sbit k7=P1^6;
sbit k8=P1^7;  //選手按鍵
sbit beep=P3^6;   //蜂鳴器
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77};  //0-9代碼(共陰極)
uchar shiwei,gewei,xuanshou,count,i,second;
ucharscore1,score2,score3,score4,score5,score6,score7,score8;//選手1~8的分?jǐn)?shù)
uint t,m,n,a,a1,a2,a3,a4,a5,a6,a7,a8,k,m1,n2,m2,n2;
void Timer()
       TMOD|=0x01;
       TH0=0xd8;  //初值55536,計(jì)數(shù)10000次,每次1US,總計(jì)10ms
       TL0=0xf0;
       IE=0x82;  //這里是中斷優(yōu)先級(jí)控制EA=1(開(kāi)總中斷),ET0=1(定時(shí)器0允許中斷),這里用定時(shí)器0來(lái)定時(shí)
       TR0=1;
void tim(void) interrupt 1 using 1  //為定時(shí)中斷TR0
       TH0=0xd8;  //重新賦值
       TL0=0xf0;
       count++;
       if(count==100)//100*10ms=1
       count=0;
       second--;//秒減1
void delay(uint z)  //延時(shí)函數(shù)
       uintx,y;
       for(x=z;x>0;x--)
              for(y=110;y>0;y--);//延時(shí)1ms
void display (uchar shiwei,gewei,xuanshou)//顯示函數(shù)
       P2=0xfe;   //打開(kāi)顯示時(shí)間十位的位選低電平有效1111 1110
       P0=shiwei;//顯示十位
       delay(5);
       P2=0xfd; //個(gè)位位選1111 1101
       P0=gewei;
       delay(5);
       P2=0xf7;    //選手位選1111 0111
       P0=xuanshou;
       delay(5);
void dis(void)//調(diào)用顯示函數(shù)
       shiwei=tab[second/10];
       gewei=tab[second%10];
       xuanshou=tab;
       display(shiwei,gewei,xuanshou);
void init()   //初始化函數(shù)
       P2=0x04;//00000100
       P0=0x3f;//數(shù)碼管共陰0011 1111顯示0
       t=0;
       beep=0;//蜂鳴器
       i=0;
       second=29;
       score1=60;
       score2=60;
       score3=60;
       score4=60;
       score5=60;
       score6=60;
       score7=60;
       score8=60;
       a1=1;
       a2=1;
       a3=1;
       a4=1;
       a5=1;
       a6=1;
       a7=1;
       a8=1;
void main()//主函數(shù)
    init();//調(diào)用初始化函數(shù)
        if(k==1){ m=0;    if(k1==0){delay(5);if(k1==0);while(!k1);beep=1;delay(500);beep=0;}      //   違規(guī)搶答顯示號(hào)碼報(bào)警
                             while(t)
                            if(m==0)//開(kāi)關(guān),保證程序只執(zhí)行一次
                                   switch(t)
                                          case1:
                                                        TR0=0;i=1;second=score1;beep=1;delay(500);beep=0;
                                                        a1=0;a2=1;a3=1;a4=1;a5=1;a6=1;a7=1;a8=1;m=1;break;//有選手搶答時(shí)顯示選手號(hào)碼蜂鳴器響,時(shí)間為0ti對(duì)應(yīng)
                            if(k2==0){delay(5);if(k1==0);while(!k1);t=2;beep=1;delay(500);beep=0;}
                         if(k3==0){delay(5);if(k1==0);while(!k1);t=3;beep=1;delay(500);beep=0;}
                             if(k4==0){delay(5);if(k1==0);while(!k1);t=4;beep=1;delay(500);beep=0;}
                            if(k5==0){delay(5);if(k1==0);while(!k1);t=5;beep=1;delay(500);beep=0;}
                            if(k6==0){delay(5);if(k1==0);while(!k1);t=6;beep=1;delay(500);beep=0;}
                            if(k7==0){delay(5);if(k1==0);while(!k1);t=7;beep=1;delay(500);beep=0;}
                            if(k8==0){delay(5);if(k1==0);while(!k1);t=8;beep=1;delay(500);beep=0;}
       if(k==0)
              Timer();//中斷定時(shí)器打開(kāi)
              delay(10);
              while(!k);
                     dis();
                     m=0;
                     n=0;
                     if(second==29){beep=1;delay(500);beep=0;}
                     if(second==0){
                                                  TR0=0;n=1;
                                                 if(k1==0){delay(5);if(k1==0);while(!k1);t=1;beep=1;delay(500);beep=0;}       //   違規(guī)搶答顯示號(hào)碼報(bào)警
                                                    if(k8==0) {delay(5);if(k1==0);while(!k1);t=8;beep=1;delay(500);beep=0;}
                                           if(k==0)
                                                 {beep=1;delay(500);beep=0;second=29;TR0=1;m=1;}
                                            }//如果再次按下開(kāi)始按鈕,蜂鳴器響05秒,定時(shí)器打開(kāi),從29開(kāi)始倒計(jì)時(shí)
                     if(n==0)
                      if(k1==0) {delay(5);if(k1==0);while(!k1);t=1;}   //正常搶答顯示號(hào)碼
              elseif(k2==0) {delay(5);if(k2==0);while(!k2);t=2;}
              elseif(k3==0) {delay(5);if(k3==0);while(!k2);t=3;}
              elseif(k4==0) {delay(5);if(k4==0);while(!k2);t=4;}
              elseif(k5==0) {delay(5);if(k5==0);while(!k2);t=5;}
              elseif(k6==0) {delay(5);if(k6==0);while(!k2);t=6;}
              elseif(k7==0) {delay(5);if(k7==0);while(!k2);t=7;}
              elseif(k8==0) {delay(5);if(k8==0);while(!k2);t=8;}
              elseif(k==0)  {delay(5);if(k==0);while(!k);t=0;i=0;second=29;beep=1;delay(500);beep=0;TR0=1;}//從新開(kāi)始,從新啟動(dòng)。
       while(t)
                                   switch(t)
                                          case1:
                                                        TR0=0;i=1;second=0;beep=1;delay(500);beep=0;
                                          case2:
                                                        TR0=0;i=2;second=0;beep=1;delay(500);beep=0;
                                                        a2=0;a1=1;a3=1;a4=1;a5=1;a6=1;a7=1;a8=1;m=1;break;
                                          case3:
                                                        TR0=0;i=3;second=0;beep=1;delay(500);beep=0;
                                                        a3=0;a1=1;a2=1;a4=1;a5=1;a6=1;a7=1;a8=1;m=1;break;
                                          case4:
                                                        TR0=0;i=4;second=0;beep=1;delay(500);beep=0;
                                                        a4=0;a1=1;a2=1;a3=1;a5=1;a6=1;a7=1;a8=1;m=1;break;
                                          case5:
                                                        TR0=0;i=5;second=0;beep=1;delay(500);beep=0;
                                                        a5=0;a1=1;a2=1;a3=1;a4=1;a6=1;a7=1;a8=1;m=1;break;
                                          case6:
                                                        TR0=0;i=6;second=0;beep=1;delay(500);beep=0;
                                                        a6=0;a1=1;a2=1;a3=1;a4=1;a5=1;a7=1;a8=1;m=1;break;
                                          case7:
                                                        TR0=0;i=7;second=0;beep=1;delay(500);beep=0;
                                                        a7=0;a1=1;a2=1;a3=1;a4=1;a5=1;a6=1;a8=1;m=1;break;
                                          case8:
                                                        TR0=0;i=8;second=0;beep=1;delay(500);beep=0;
                                                        a8=0;a1=1;a2=1;a3=1;a4=1;a5=1;a6=1;a7=1;m=1;break;
              if(a1==0)//選手1的分?jǐn)?shù)
              second=score1;
                     dis();
                         if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score1+=5;}
           else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score1-=5;}
                     dis();
       elseif(a2==0)
              {   second=score2;
                     dis();
                            if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score2+=5;}
                 else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score2-=5;}
                     dis();
       elseif(a3==0)
              {     second=score3;
                     dis();
                            if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score3+=5;}
                 else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score3-=5;}
                     second=score3;
                     dis();
       elseif(a4==0)
                     second=score4;
                     dis();
                            if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score4+=5;}
                 else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score4-=5;}
                     second=score4;
                     dis();
       elseif(a5==0)
                     second=score5;
                     dis();
                            if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score5+=5;}
                 else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score5-=5;}
                     second=score5;
                     dis();
       elseif(a6==0)
                     second=score6;
                     dis();
                            if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score6+=5;}
                 else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score6-=5;}
                     second=score6;
                     dis();
       elseif(a7==0)
                     second=score7;
                     dis();
                            if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score7+=5;}
                 else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score7-=5;}
                     second=score7;
                     dis();
       elseif(a8==0)
                     second=score8;
                     dis();
                            if(m1==0){delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score8+=5;}
                 else if(m2==0){delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score8-=5;}
                     second=score8;
                     dis();
                     if(k==0){i=0;t=0;second=29;beep=1;delay(500);beep=0;TR0=1;}
                     while(!k);
